monk
15 October 2022 13:56
1
Hello
i was just the testing with live usb and booted with nvidia graphics on boot screen.
I am not able to use the the nvidia graphics card. nvidia-settings and nvidi-smi both give errors. i have done nothing till now. just made a bootable disk from iso and booted my machine, opened the konsole and typed the above commands.also twice downloaded the iso and used rufus to create the bootable disk. balena gives error when creating the bootable usb.
how is this possible
filo
15 October 2022 14:01
2
Please provide your garuda-inxi, as requested in the topic template.
By-the-way, you could install with free drivers, then switch to the proprietary drivers later...
monk
15 October 2022 14:03
3
Thanks for a quick reply.
I will try with free driver and install it. still if i have problems will get back with the issue and the info you asked shortly.
thanks again
monk
15 October 2022 14:17
4
what do you suggest i should install the nvidia drivers just after booting from install or should i setup everything and then install it?
monk
15 October 2022 14:54
5
ok so installed. the garuda installer ran and asked to installed non free nvidia drivers and and i let it.
after reboot i can see couple of problems on a brand new install
first the top bar transparency is gone!!!
second nvidia driver throwing errors:
╰─λ nvidia-smi
No devices were found
[🔴] × nvidia-settings
Gtk-Message: 20:22:09.475: Failed to load module "appmenu-gtk-module"
ERROR: A supplied argument is invalid
(nvidia-settings:3678): GLib-GObject-CRITICAL **: 20:22:10.865: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** (nvidia-settings:3678): CRITICAL **: 20:22:10.866: ctk_powermode_new: assertion '(ctrl_target != NULL) && (ctrl_target->h != NULL)' failed
ERROR: nvidia-settings could not find the registry key file or the X server is not accessible. This file
should have been installed along with this driver at
/usr/share/nvidia/nvidia-application-profiles-key-documentation. The application profiles will
continue to work, but values cannot be prepopulated or validated, and will not be listed in the help
text. Please see the README for possible values and descriptions.
garuda-inxi ::
Kernel: 6.0.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=24d57aa5-806c-459a-9092-8b30bc85a35e rw rootflags=subvol=@
quiet
cryptdevice=UUID=6fced7a2-41b3-4012-be75-764a359fd8ce:luks-6fced7a2-41b3-4012-be75-764a359fd8ce
root=/dev/mapper/luks-6fced7a2-41b3-4012-be75-764a359fd8ce quiet splash
resume=/dev/mapper/luks-8c6296be-fbfc-49ba-9f93-a70613f477d6 loglevel=3
Desktop: KDE Plasma v: 5.26.0 tk: Qt v: 5.15.6 info: latte-dock
Type: Laptop System: Micro-Star product: GF63 Thin 9SC v: REV:1.0
Mobo: Micro-Star model: MS-16R3 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16R3IMS.108 date: 03/26/2020
ID-1: BAT1 charge: 40.9 Wh (96.9%) condition: 42.2/51.3 Wh (82.4%)
volts: 12.7 min: 11.4 model: MSI Corp. MS-16R3 type: Li-ion serial: N/A
status: not charging
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2300 high: 2600 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 2600 2: 800 3: 2600
4: 2600 5: 2600 6: 2600 7: 2600 8: 2600 9: 800 10: 2600 11: 2600 12: 2600
bogomips: 62399
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nvidia v: 520.56.06
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
2022-10) arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie:
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f91 class-ID: 0302
unloaded: nouveau,nvidia alternate: fbdev,intel,nv,vesa dri: iris
Monitor-1: eDP-1 model: AU Optronics 0x21ed built: 2016 res: 1920x1080
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa
22.2.1 direct render: Yes
Sound API: ALSA v: k6.0.1-zen2-1-zen running: yes
driver: btusb v: 0.8 bus-ID: 1-14:2 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 924.07 GiB used: 15.08 GiB (1.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1032 size: 476.94 GiB block-size: physical: 512 B
rev: 20140000 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SQ500S37480G
type: SSD serial: <filter> rev: 3102 scheme: GPT
ID-1: / raw-size: 459.66 GiB size: 459.66 GiB (100.00%) used: 15.08 GiB
(3.3%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-6fced7a2-41b3-4012-be75-764a359fd8ce
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 752 KiB
ID-3: /home raw-size: 459.66 GiB size: 459.66 GiB (100.00%) used: 15.08
GiB (3.3%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 459.66 GiB size: 459.66 GiB (100.00%) used: 15.08
ID-5: /var/tmp raw-size: 459.66 GiB size: 459.66 GiB (100.00%) used: 15.08
ID-1: swap-1 type: zram size: 15.43 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.98 GiB used: 0 KiB (0.0%)
mapped: luks-8c6296be-fbfc-49ba-9f93-a70613f477d6
System Temperatures: cpu: 49.0 C pch: 56.0 C mobo: N/A
Processes: 306 Uptime: 13m wakeups: 1 Memory: 15.43 GiB used: 2.3 GiB
(14.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1360
libs: 339 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
Garuda (2.6.8-1):
System install date: 2022-10-15
Last full system update: 2022-10-15
monk
15 October 2022 16:30
6
so installed on similar machine. and the top bar is not transparent even on fresh install and boot even before updating. nvidia drivers are borked on both.
also do you guys add homepage to firedragon during setup process after install?
SGS
15 October 2022 16:45
7
Sometimes it works, sometimes it doesn’t. Make a report to KDE, we can’t change it.
monk
15 October 2022 16:46
8
yeah what can us do. any tips
filo
15 October 2022 16:48
9
Try resetting Latte to deafult settings from Garuda Assistant.
Chances are low, but give it a try...
monk
15 October 2022 16:50
10
been there. done that,.
this time there is no desktop. its hung up.
looks like i have to use the hammer.
filo
15 October 2022 16:53
11
Everything stuck? No way to logoff and on or reboot? Does ctrl+alt+T give you a terminal? Or switching to a tty to reboot?
filo
15 October 2022 16:56
13
Sorry I have no clue.
I'm not a Nvidia user, I read of several Nvidia drivers issues lately, but didn't follow that up...
monk
15 October 2022 16:59
14
i thought it will be easy. but luck has it i have to do everything from scratch. that i would have the control.
thanks guys. see you later.
sorry garuda looks like we are not made for each other.
cheers
SGS
15 October 2022 17:08
15
No problems here on two PC with three DE’s, but you use a laptop search for prime or something like this in forum.
monk:
monk
15 October 2022 17:26
16
just looked at prime or is it optimus?. it borked my mosh server.
samba is a story in itself.
with this much work i am dishing out my own distro
system
Closed
29 October 2022 17:27
17
