Installing video-nvidia-470xx-dkms...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia-470xx-dkms/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
garuda downloading...
core downloading...
extra downloading...
community downloading...
multilib downloading...
chaotic-aur downloading...
resolving dependencies...
warning: cannot resolve "nvidia-470xx-utils", a dependency of "garuda-nvidia-470xx-config"
warning: cannot resolve "nvidia-470xx-settings", a dependency of "garuda-nvidia-470xx-config"
warning: cannot resolve "opencl-nvidia-470xx", a dependency of "garuda-nvidia-470xx-config"
warning: cannot resolve "nvidia-470xx-utils", a dependency of "lib32-nvidia-470xx-utils"
warning: cannot resolve "lib32-nvidia-470xx-utils", a dependency of "garuda-nvidia-470xx-config"
warning: cannot resolve "nvidia-470xx-dkms", a dependency of "garuda-nvidia-470xx-config"
:: The following package cannot be upgraded due to unresolvable dependencies:
:: Do you want to skip the above package for this upgrade? [y/N] error: failed to prepare transaction (could not satisfy dependencies)
:: unable to satisfy dependency 'nvidia-470xx-utils' required by garuda-nvidia-470xx-config
:: unable to satisfy dependency 'nvidia-470xx-settings' required by garuda-nvidia-470xx-config
:: unable to satisfy dependency 'opencl-nvidia-470xx' required by garuda-nvidia-470xx-config
:: unable to satisfy dependency 'nvidia-470xx-utils' required by lib32-nvidia-470xx-utils
:: unable to satisfy dependency 'lib32-nvidia-470xx-utils' required by garuda-nvidia-470xx-config
:: unable to satisfy dependency 'nvidia-470xx-dkms' required by garuda-nvidia-470xx-config
Error: pacman failed!
Error: script failed!
root=UUID=eb6d707d-d737-4a5e-af0a-6c62565e3737 rw [email protected]
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Desktop System: Hewlett-Packard product: HP Z420 Workstation v: N/A
serial: <superuser required> Chassis: type: 6 serial: <superuser required>
Mobo: Hewlett-Packard model: 1589 v: 0.00 serial: <superuser required>
UEFI-[Legacy]: Hewlett-Packard v: J61 v03.96 date: 10/29/2019
Info: model: Intel Xeon E5-1650 0 bits: 64 type: MT MCP arch: Sandy Bridge
level: v2 built: 2010-12 process: Intel 32nm family: 6 model-id: 0x2D (45)
stepping: 7 microcode: 0x71A
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3723 high: 3800 min/max: 1200/3800 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3591 2: 3800 3: 3593
4: 3800 5: 3800 6: 3800 7: 3800 8: 3511 9: 3800 10: 3800 11: 3800 12: 3591
bogomips: 76615
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: NVIDIA GK107GL [Quadro K600] driver: nouveau v: kernel non-free:
series: 470.xx+ status: legacy-active (EOL~2023/24) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-18 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 2 speed: 5 GT/s ports: active: DP-1 empty: DVI-I-1
bus-ID: 05:00.0 chip-ID: 10de:0ffa class-ID: 0300 temp: 69.0 C
compositor: kwin_x11 driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau display-ID: :0
Monitor-1: DP-1 model: Samsung C27F390 serial: <filter> built: 2021
res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.3 Mesa 22.2.3 renderer: NVE7 direct render: Yes
Device-1: Intel C600/X79 series High Definition Audio
chip-ID: 8086:1d20 class-ID: 0403
Device-2: NVIDIA GK107 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 2 speed: 5 GT/s
bus-ID: 05:00.1 chip-ID: 10de:0e1b class-ID: 0403
Sound Server-2: PipeWire v: 0.3.60 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: e040 bus-ID: 00:19.0 chip-ID: 8086:1502
Hardware-1: Intel C600/X79 series SATA RAID Controller driver: ahci v: 3.0
port: e020 bus-ID: 00:1f.2 chip-ID: 8086:2826 rev: N/A class-ID: 0104
Local Storage: total: 2.3 TiB used: 22.07 GiB (0.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix
model: SC300 HFS512G32MND-3210A size: 476.94 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 1P00 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HUA722020ALA330
45W6276 59Y1813IBM size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: A3HH scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Cruzer Glide
size: 14.91 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.26 scheme: MBR
ID-1: / raw-size: 476.93 GiB size: 476.93 GiB (100.00%)
used: 22.07 GiB (4.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 476.93 GiB size: 476.93 GiB (100.00%)
ID-3: /var/log raw-size: 476.93 GiB size: 476.93 GiB (100.00%)
ID-4: /var/tmp raw-size: 476.93 GiB size: 476.93 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.55 GiB used: 11.8 MiB (0.1%)
System Temperatures: cpu: 59.0 C mobo: N/A gpu: nouveau temp: 69.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 6630
Processes: 318 Uptime: 1d 2h 17m wakeups: 0 Memory: 15.55 GiB
used: 3.33 GiB (21.4%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1836
libs: 516 tools: octopi,pamac,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-27
Last full system update: 2022-11-28 ↻
╭─[email protected] in ~ took 1s
You took a kernel update so you'll need to reboot, then try again.
system
Closed
1 December 2022 04:14
3
