Nvidia driver conflict running garuda-health --fix
I’m new to Linux so don’t really know what I’m doing, I updated recently and the Nvidia drivers broke, there is a lot of flickering. It says when I update that it’s using the wrong profile, and to run -garuda-health --fix to resolve that but whenever I do that it fails with this:
Detecting hardware...
Detected GPU: Product: NVIDIA Corporation GA104 GeForce RTX 3070, PCI ID: 01:00.0, Vendor ID: 10de
NVIDIA GPU detected, added: garuda-hardware-profile-nvidia.
Installing packages: garuda-hardware-profile-nvidia garuda-hardware-profile-standard-x11
resolving dependencies...
:: garuda-hardware-profile-nvidia-2.0.1-1 and garuda-hardware-profile-nvidia-580xx-2.0.1-1 are in conflict (GARUDA-HARDWARE-PROFILE-NVIDIA). Remove garuda-hardware-profile-nvidia-580xx? [y/N] y
:: garuda-hardware-profile-nvidia-2.0.1-1 and opencl-nvidia-580xx-580.119.02-2 are in conflict. Remove opencl-nvidia-580xx? [y/N] y
:: garuda-hardware-profile-nvidia-2.0.1-1 and lib32-opencl-nvidia-580xx-580.119.02-1 are in conflict. Remove lib32-opencl-nvidia-580xx? [y/N] y
:: garuda-hardware-profile-nvidia-2.0.1-1 and nvidia-580xx-dkms-580.119.02-2 are in conflict. Remove nvidia-580xx-dkms? [y/N] y
:: nvidia-utils-590.48.01-2 and nvidia-580xx-utils-580.119.02-2 are in conflict (nvidia-libgl). Remove nvidia-580xx-utils? [y/N] y
:: unable to satisfy dependency 'opencl-nvidia' required by garuda-hardware-profile-nvidia
:: unable to satisfy dependency 'lib32-opencl-nvidia' required by garuda-hardware-profile-nvidia
:: removing opencl-nvidia-580xx breaks dependency 'opencl-driver' required by hcxkeys
I’m hoping I don’t have to completely reinstall Garuda or something like that, here’s my inxi output
  Kernel: 6.12.65-1-lts arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=7cf76ba8-2f63-4a8c-a66b-55d78ad1c068 rw rootflags=subvol=@
    quiet loglevel=3
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.51 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
  Mobo: ASUSTeK model: TUF GAMING B460M-PLUS (WI-FI) v: Rev 1.xx
    Firmware: UEFI vendor: American Megatrends v: 0708 date: 07/23/2020
  Info: model: Intel Core i7-10700F bits: 64 type: MT MCP arch: Comet Lake
    model-id: 0xA5 (165) stepping: 5 microcode: 0x100
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB
    desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 800 min/max: 800/4800 scaling: driver: intel_pstate
    governor: performance cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
    7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800
    16: 800 bogomips: 92838
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
  Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Gigabyte driver: nvidia
    v: 580.119.02 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
    off: HDMI-A-2 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2484
  Display: x11 server: X.Org v: 21.1.21 compositor: xfwm4 v: 4.20.0 driver:
    X: loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
    gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
    s-diag: 584mm (22.99")
  Monitor-1: HDMI-A-2 mapped: HDMI-1 note: disabled model: E241-A1
    serial: <filter> built: 2012 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.119.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.4.335 layers: 12 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3070 driver: nvidia v: 580.119.02
    device-ID: 10de:2484 surfaces: N/A device: 1 type: cpu name: llvmpipe
    (LLVM 21.1.6 256 bits) driver: mesa llvmpipe v: 25.3.3-arch1.2 (LLVM
    gpu: nvidia-settings,nvidia-smi x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Comet Lake PCH-V cAVS vendor: ASUSTeK driver: snd_hda_intel
    chip-ID: 8086:a3f0 class-ID: 0403
  Device-2: NVIDIA GA104 High Definition Audio vendor: Gigabyte
    link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b
  Device-3: Razer USA BlackShark V2 X USB
    lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 1532:0557 class-ID: 0300
  API: ALSA v: k6.12.65-1-lts status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d55 class-ID: 0200
    speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:6 chip-ID: 8087:0029
  Local Storage: total: 6.39 TiB used: 3.27 TiB (51.2%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 004C temp: 32.9 C scheme: GPT
    model: WD60EDAZ-11BMZB0 size: 5.46 TiB block-size: physical: 4096 B
    logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1030 scheme: GPT
    used: 515.15 GiB (54.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: zram size: 31.25 GiB used: 512 KiB (0.0%) priority: 100
  System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 51 C
  Memory: total: 32 GiB available: 31.25 GiB used: 5.92 GiB (18.9%)
  Processes: 436 Power: uptime: 56m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.42 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 259
  Packages: 2276 pm: pacman pkgs: 2230 libs: 484 tools: octopi,paru,yay
    pm: flatpak pkgs: 46 Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash
    v: 5.3.9 running-in: xfce4-terminal inxi: 3.3.40
Garuda (2.11.1-1):
  System install date:     2025-06-30
  Last full system update: 2026-01-13
  Relevant software:       snapper NetworkManager dracut nvidia-580xx-dkms garuda-hardware-profile-nvidia-580xx garuda-hardware-profile-standard
I think if you remove garuda-hardware-profile-nvidia-580xx first, the rest should work when you execute garuda-health --fix. I’m pretty sure that’s been the resolution when others’ have posted similar issues. I’d search the forum also just to be sure.
Pacman dependency resolution is… Frustrating, recently. I’ll see what can be done about this.
Hey, this issue should be fixed. After a garuda-update, garuda-health should be able to apply the suggestion.
It did fix the dependency loop, but it’s still flickering after update.
    quiet loglevel=3
  Speed (MHz): avg: 4700 min/max: 800/4800 scaling: driver: intel_pstate
    governor: performance cores: 1: 4700 2: 4700 3: 4700 4: 4700 5: 4700 6: 4700
    7: 4700 8: 4700 9: 4700 10: 4700 11: 4700 12: 4700 13: 4700 14: 4700
    15: 4700 16: 4700 bogomips: 92838
    v: 590.48.01 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
    X: loaded: nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
    gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 590.48.01
    memory: 7.81 GiB
    name: NVIDIA GeForce RTX 3070 driver: nvidia v: 590.48.01
  Local Storage: total: 6.39 TiB used: 3.29 TiB (51.5%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 004C temp: 37.9 C scheme: GPT
    used: 529.96 GiB (55.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 75.0 C mobo: N/A gpu: nvidia temp: 46 C
  Memory: total: 32 GiB available: 31.25 GiB used: 5.22 GiB (16.7%)
  Processes: 490 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.45 GiB
  Packages: 2280 pm: pacman pkgs: 2234 libs: 484 tools: octopi,paru,yay
Garuda (2.12.0-1):
  Last full system update: 2026-01-14
There is unfortunately nothing obvious I can see from your inxi that would cause flickering. The correct NVIDIA drivers are installed and working.
You could try reverting to a previous NVIDIA driver version or switching to a desktop environment that does not rely on X11.
sudo pacman -S garuda-hardware-profile-nvidia-580xx
Be sure to upgrade your BIOS to the latest version. You are missing extremely important updates. Very outdated BIOS can cause flickering eventually. (one of the BIOS updates mentioned " Add ReSize BAR ON/OFF button and improve its compatibility for NVIDIA RTX30 series graphics cards")
https://www.asus.com/motherboards-components/motherboards/tuf-gaming/tuf-gaming-b460m-plus-wi-fi/helpdesk_bios?model2Name=TUF-GAMING-B460M-PLUS-WI-FI
