Ongoing issues with new install image regardless of which image version to install.
I got an Alienware x17r1.
CPU: 11th Gen Intel i7-11800H (16) @ 4.6GHz
GPU: NVIDIA GeForce RTX 3070 Mobile / Max-Q and
GPU: Intel TigerLake-H GT1 [UHD Graphics]
Memory: 5.32GiB / 30.99GiB
GUI: KDE (tried with other images same issue)
Issue 1:
You last working image to even make it to the install screen was 220308. Any image version after this hangs after selecting boot with open source or proprietary regardless witch option I pick. I read it in your earlier post the Nvidia Optimus Manager was removed from the install image. Can there be a connection? Was image 220308 the last one using it? Is there a connection here? Not sure what Garuda team did after this image but non of them even make it to the install screen. I was hoping to wait a few new images to see if it will be resolved but non of them fix it.
Issue 2: Alienware x17R1 have a hybrid video card system as shows in the above specs detail. I also tried switching off the the hybrid graphics in my BIOS so only the dedicated graphics my NVIDA RTX 370 shows up. Same problem, Garuda image after 220308 won't even boot.
Issue 3: I never deleted the last working image 220308 from the beginning of the year and that's how I can still use Garuda on my laptop. The problem is using the last working image Garuda seem to only use my onboard: Intel TigerLake-H GT1 [UHD Graphics] while when I check in the system the RTX card also shows up but never switches for me to able to use them. Anything I run only uses the Intel GPU. When the system already installed and fully updated going into BIOS and switching hybrid graphics off the system won't even boot just hangs like it did on the install image until I turn BIOS hybrid graphics back on again. I also ran Manjaro and Ubuntu on this system both boots and works with hybrid graphics on Garuda looks like a very dedicated team to make a top Linux but it's pretty sad being advertised as a gaming Linux while Manjaro and Ubuntu runs my hardware flawlessly yet Garuda not only haven't been able to identify this issue but going backwards as it won't work at all after image 220308.
As I said, I installed from last working image 220308 and been using Garuda like this hoping one of the updates in the future will fix the GPU issue. Meanwhile when I play on steam I need to boot into Manjaro or Ubuntu that switches to my dedicated gpu when I play games which Garuda still doesn't do.
I'm reaching out here to see how the community response as I love Garuda Linux looks and speed (KDE) and I love to make it as my main OS but having a "gaming" Linux which can't handle my vidoe cards kind of defeats the purpose. Doesn't it? Gaming Linux which doesn't work with a gaming laptop (Alienware) what a joke.
Please guys look into it. Looking forward to the responses I get to see how the Garuda community response to users.
I would pass over the ISO image issue for now, as I understand that you currently have your system installed (using the old image) and I believe updated.
If the current problem with the installed system is that you cannot boot with proprietary drivers, you should take a look here (add the ibt=off kernel boot parameter, due to a known Nvidia problem with the latest Intel processors) any many other releated topics.
On the other hand, if you have problems installing proprietary drivers, you should provide more information, like what error messages you get.
This is fine, however you should familiarize yourself with the forum and search functions. You will definitely find a lot of useful information. In fact, your profile shows that you have not searched muchâŠ
filo wrote a nice and detailed response but IMO all of the problems have the same cause. Open the file /etc/default/grub with a text editor, add ibt=off to the end of the lines which start with GRUB_CMDLINE_LINUX and GRUB_CMDLINE_LINUX_DEFAULT, save, run
grub-mkconfig -o /boot/grub/grub.cfg
and reboot.
I prefer to blame Nvidia who couldnât be bothered to fix this issue which is known and has a known solution for 3 months.
I have tried your suggestion added the ibt=off, updated then restart.
The computer briefly showed my Garuda loading screen but before it fully loaded for me to log in the screen when black and crashed. It bricked my system. Luckily I booted into Manjaro reversed the added line, restarted Garuda and quickly switched to CLI updated grub again hit restarted and saved my OS now back to square one. To clarify some of your points.
Yes, the system up to date and I been running it like this from the last working Image from Late May.
My system is running 4 OS Garuda, Manjaro, Ubuntu and Windows 11 and having my hybrid graphics setting ON in the BIOS. As all operating system except Garuda running it smoothly.
As I mentioned I briefly turned hybrid off to check if the existing Install and the newest downloaded image could handle with only the dedicated graphics on only. I'm afraid both failed the newest image would get pass the installation select screen. Regardless selecting proprietary or nouveau both stuck even before making it to the loading screen. With the existing install also stuck the same way until I go and turn the hybrid graphics back on. Assuming the system only able to use the onboard Intel driver. Note this is only the case with using the old 220308 image. Anything newer image won't even start regardless of hybrid graphics ON or OFF in the BIOS settings.
My working install is running the proprietary driver at the moment but I'm pretty sure it only runs the onboard Intel GPU very likely ignoring the dedicated RTX 370.
If you can give me a detailed breakdown step by step what to do to fish out the error messages you looking for very happy to do so.
It would be my pleasure to help improving the Garuda experience by giving as much info as I can.
I been a Manjaro users for years but started heavily favoring Garuda the end goal would be that we make Garuda handles the Alienware hardware as smooth as Manjaro or Ubuntu without eventually needed to open up the terminal. Until we get there where happy to give you feedback especially over Manjaro as it also based on Arch Linux therefore a lot of bugs can't be blamed on Arch if it works well under Manjaro. Lastly I have looked at some Garuda forums before with my friend in Germany also using Garuda Linux but had almost no activity on this account yet. I appreciate your professionalism and kindness.
I really appreciate your step by step instructions how on how to try to fix it, unfortunately it brick the system and the fallback kernel didn't work either. Had to log into Manjaro re-edit the grub back to where it was. Rest of the story in my above reply.
As for the Nvidia issues YESSSS, the big finger still applies to Nvidia from Linus Tolvalds. They mess up the driver updates and still a nightmare if you trying to use wayland. The thing is that Manjaro and Ubuntu seem to somehow still make it work. I prefer using AMD CPU,GPU because of Linux support. My home PC is all AMD. However Alienware X series only come with Nvidia GPU and the moment. Staying overseas for this year only having the Alienware X17 I need to make this Nvidia work which in most cases started to work better and better with Linux distros given only with baby steps as Nvidia poor support. Despite Nvidia shortcomings let's make Garuda the best of Linuxes that can handle any hardware.
Okay, please for the moment provide, from Garuda, your garuda-inxi.
That way, someone more technical than me (I am essentially a moderator and do not use Nvidia cards) can suggest the next steps.
In addition, I believe that
I edited your post to format the text from terminal.
This means that the driver is installed but not loaded.
Maybe you could try a
sudo dkms autoinstall
and check the status and the referenced logs in the (likely) case of errors.
Maybe reboot before that, since the last symbol here indicates that the system has not yet been rebooted after the last update.
Finally, always in the logic of providing information to those I hope will follow in the troubleshooting , could you please specify how the Nvidia were installed (e.g. HW assistant (Garuda Welcome - > Garuda Settings Manager - > Hardware Configuration) or what?
If the sudo dkms autoinstall doesnât help, and untill we get better technical support, my last suggestion would be to try reinstalling with the same command executed by the HW assistant:
Sorry Filo I just copy paste from terminal. Let me know what is the best way to paste it here.
To Answer your questions:
I have installed Garuda from last working image 220308 by selecting the option "Boot allowing proprietary drivers (NVIDIA)
When Garuda started the first time Assistant went through the usual software I want to install with Garuda. This process included with a message that system will install latest NVIDIA proprietary drivers. clicked yes.
From this point when I updated on a daily basis with command garuda-update if there was a new driver available it was automatically loaded and I can still see to this day when a newer version comes through the update.
trying sudo dkms autoinstall - getting this error message:
Error! Could not locate dkms.conf file.
File: /var/lib/dkms/nvidia/515.57/source/dkms.conf does not exist.
McFly: Upgrading McFly DB to version 3, please waitâŠthread âmainâ panicked at âMcFly error: Unable to add cmd_tpl to commands (duplicate column name: cmd_tpl)â, src/history/schema.rs:41:17
note: run with RUST_BACKTRACE=1 environment variable to display a backtrace
- When I tried sudo mhwd -a pci nonfree 0300 here is what I got:
Using config âvideo-nvidia-prime-render-offloadâ for device: 0000:01:00.0 (0300:10de:24dd) Display controlle
r nVidia Corporation GA104M [GeForce RTX 3070 Mobile / Max-Q]
Using config âvideo-nvidia-prime-render-offloadâ for device: 0000:00:02.0 (0300:8086:9a60) Display controlle
r Intel Corporation TigerLake-H GT1 [UHD Graphics]
Installing video-nvidia-prime-render-offloadâŠ
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia-prime-render-offload/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
:: Synchronizing package databasesâŠ
garuda downloadingâŠ
core downloadingâŠ
extra downloadingâŠ
community downloadingâŠ
multilib downloadingâŠ
chaotic-aur downloadingâŠ
blackarch downloadingâŠ
resolving dependenciesâŠ
looking for conflicting packagesâŠ
:: garuda-nvidia-prime-config and garuda-optimus-manager-config are in conflict. Remove garuda-optimus-manager
-config? [y/N] error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Error: pacman failed!
Error: script failed!
- clearly garuda-nvidia-prime-config and garuda-optimus-manager-config are in conflict
naturally you would say just remove optimus-manager-config that will reinstall you driver. However to my understanding from past forums Garuda Image 220308 was the last one that loaded in optimus-manager by default. Every new Garuda image after 220308 I try to install, does not even make it to the boot screen regardless of me leaving hybrid graphics ON or OFF in BIOS. Based on this I have a feeling removing optimus-manager and let the driver reinstall will break my system as it always done in the past with every new Garuda Image after 220308.
Happy to upload pictures how my hardware configurations show at the moment also some install errors to help the team with the answers. Unfortunately I get the message New users can't upload pictures.
Thank you Filo, Here is the image how my hardware configuration looks at the moment. Really had to dumb down the picture to be accepted by the upload. Still visible enough.
I also gave a quick try to the latest Garuda Image 220822 to see if there is any improvements with MHWD. Fails as any other Image after 220308 to make it to the boot screen.
