I have been trying to get my system to run with the nvidia drivers for a discrete Nvidia 5090 adapter (founders edition if it matters). And cant seem to get it to work.
I installed the system, and when I startup I try to run
nvidia-smi
No devices were found
Is it too new and do I simply need to wait a bit? or is there some other way to get my system to run the nvidia drivers?
Here is the output of my garuda-inxi:
root=UUID=8bb8d754-1157-4d6f-bb9c-be884eda8bae rw rootflags=subvol=@
Type: Desktop System: OriginPC product: Genesis v: N/A
Mobo: ASUSTeK model: ROG MAXIMUS XII HERO (WI-FI) v: Rev 1.xx
UEFI: American Megatrends v: 2701 date: 12/26/2022
Info: model: Intel Core i9-10900K bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xFC
Topology: cpus: 1x dies: 1 clusters: 10 cores: 10 threads: 20 tpc: 2
smt: enabled cache: L1: 640 KiB desc: d-10x32 KiB; i-10x32 KiB L2: 2.5 MiB
desc: 10x256 KiB L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 800 min/max: 800/5300 scaling: driver: intel_pstate
17: 800 18: 800 19: 800 20: 800 bogomips: 147994
Device-1: NVIDIA GB202 [GeForce RTX 5090] driver: nvidia v: 570.133.07
alternate: nouveau,nvidia_drm non-free: N/A status: unknown device ID pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 5 speed: 32 GT/s
bus-ID: 01:00.0 chip-ID: 10de:2b85 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: Unknown-1 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96
size: 508x285mm (20x11.22") diag: 582mm (22.93") modes: 1920x1080
API: EGL v: 1.5 platforms: device: 0 drv: swrast surfaceless: drv: swrast
wayland: drv: swrast x11: drv: swrast inactive: gbm
API: OpenGL v: 4.5 vendor: mesa v: 25.0.2-arch1.2 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 19.1.7 256 bits)
device-ID: ffffffff:ffffffff memory: 61.2 GiB unified: yes
display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 11 device: 0 type: cpu name: llvmpipe
(LLVM 19.1.7 256 bits) driver: N/A device-ID: 10005:0000
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 5 speed: 32 GT/s bus-ID: 01:00.1
chip-ID: 10de:22e8 class-ID: 0403
Device-3: Texas Instruments PCM2903B Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 1-9.1.2.4:18 chip-ID: 08bb:29b3 class-ID: 0300
Device-4: Elgato Systems GmbH Wave XLR driver: snd-usb-audio type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9.1.3.4:22
chip-ID: 0fd9:007d class-ID: fe01 serial: <filter>
API: ALSA v: k6.13.8-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4d class-ID: 0200
Device-3: Aquantia AQC111 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 1d6a:11b1 class-ID: 0200
temp: 74.8 C
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:12 chip-ID: 8087:0026
Local Storage: total: 20.1 TiB used: 30.15 GiB (0.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: FireCuda 520 SSD
ZP2000GM30002 size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: STNSC014
temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 PRO 2TB
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 QVO 4TB
ID-5: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 QVO 4TB
ID-6: /dev/sde maj-min: 8:64 vendor: Samsung model: SSD 850 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-7: /dev/sdf maj-min: 8:80 vendor: Samsung model: SSD 850 PRO 1TB
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: MBR
ID-8: /dev/sdg maj-min: 8:96 vendor: Crucial model: CT4000X10PROSSD9
size: 3.64 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: N/A fw-rev: 1000
used: 30.15 GiB (3.2%) fs: btrfs dev: /dev/sde2 maj-min: 8:66
used: 608 KiB (0.2%) fs: vfat dev: /dev/sde1 maj-min: 8:65
ID-1: swap-1 type: zram size: 62.67 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 20
System Temperatures: cpu: 45.2 C mobo: N/A
Memory: total: 64 GiB note: est. available: 62.67 GiB used: 6.35 GiB (10.1%)
Processes: 416 Power: uptime: 21m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2497 libs: 618 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.1
System install date: 2025-03-25
Last full system update: 2025-03-25 ↻
