Hello Garuda users and helpers.
I bought a NvidiaRtx3070ti, I installed it in my pc, when I power on my computer, all the windows, fonts and are so big, I tried to change the size of windows and everything but sometimes it is impossible because the menus are big and I can not read all the options(due to big the size of the fonts).
what can I do?
garuda-inxi output:
Kernel: 6.0.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc
v: 12.2.0 parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=57fa5352-78b9-463d-96d4-044bcc833724 rw
[email protected] quiet quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI)
v: Rev X.0x serial: <superuser required> UEFI: American Megatrends
v: 4022 date: 10/19/2021
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0
microcode: 0x8701021
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4049 high: 4050 min/max: 2200/4979
boost: enabled scaling: driver: acpi-cpufreq governor: performance
cores: 1: 4050 2: 4050 3: 4050 4: 4050 5: 4050 6: 4050 7: 4050
8: 4050 9: 4050 10: 4049 11: 4050 12: 4047 13: 4050 14: 4049
15: 4050 16: 4050 bogomips: 129601
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
ssse3 svm
Type: retbleed mitigation: untrained return thunk; SMT enabled
with STIBP protection
Type: spec_store_bypass mitigation: Speculative Store Bypass
disabled via prctl
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user
pointer sanitization
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional,
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: ASUSTeK
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm
non-free: 520.xx+ status: current (as of 2022-10) arch: Ampere
code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2
speed: 5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 08:00.0 chip-ID: 10de:2482 class-ID: 0300
Device-2: Microdia USB 2.0 Camera type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-1:2 chip-ID: 0c45:6367
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 3924x1080 s-dpi: 305
s-size: 327x90mm (12.87x3.54") s-diag: 339mm (13.35")
Monitor-1: DP-2 pos: primary,left res: 1920x1080 hz: 60 dpi: 90
size: 544x303mm (21.42x11.93") diag: 623mm (24.52") modes: N/A
Monitor-2: HDMI-1 pos: right res: 1920x1080 hz: 60 dpi: 305
size: 160x90mm (6.3x3.54") diag: 184mm (7.23") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce
RTX 3070 Ti/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 5-1:2 pcie:
chip-ID: 0c45:6367 class-ID: 0102 gen: 4 serial: <filter>
speed: 16 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 10de:228b
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Microdia USB 2.0 Camera type: USB
Sound API: ALSA v: k6.0.9-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2526
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB
driver: btusb v: 0.8 bus-ID: 3-5:3 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 5.23 TiB used: 538.14 GiB (10.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate
model: ST2000DM008-2FR102 size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 62B3
ID-3: /dev/sdc maj-min: 8:32 vendor: Gigabyte
model: GP-GSTFS30512GTTD size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 13.2 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD10EZEX-00ER1A0 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: N/A
serial: <filter> rev: 0A80 scheme: MBR
ID-5: /dev/sde maj-min: 8:64 vendor: Seagate model: ST31000528AS
speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC46
ID-6: /dev/sdf maj-min: 8:80 vendor: Toshiba model: DT01ACA100
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A750
scheme: MBR
ID-1: / raw-size: 308.03 GiB size: 308.03 GiB (100.00%)
used: 26.27 GiB (8.5%) fs: btrfs dev: /dev/sde5 maj-min: 8:69
used: 636 KiB (0.2%) fs: vfat dev: /dev/sde3 maj-min: 8:67
ID-3: /home raw-size: 585.94 GiB size: 575.67 GiB (98.25%)
used: 511.87 GiB (88.9%) fs: ext4 dev: /dev/sde4 maj-min: 8:68
ID-4: /var/log raw-size: 308.03 GiB size: 308.03 GiB (100.00%)
ID-5: /var/tmp raw-size: 308.03 GiB size: 308.03 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.25 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 58.1 C mobo: N/A gpu: nvidia temp: 52 C
Processes: 369 Uptime: 2h 48m wakeups: 0 Memory: 31.26 GiB
used: 6.18 GiB (19.8%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman
pkgs: 1897 libs: 535 tools: gnome-software,octopi,pamac,paru
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-26
Last full system update: 2022-11-26 ↻
thank you in advance.
and I have a doubt, how can I enable the windows key on my keyboard for showing me the menu?
