NTFS partititon - Mount error - looking for some suggestions
Hi Team,
I’m using garuda linux more than 4years and satisfied with that.
Recent days, I’m facing issues (can’t mount ntfs partition)
so, i would like to know why this is happening, btw, I’m using new ssd
I’m using 1TB of ssd - 200GB for garuda (Btrfs) and 700GB for personal space (ntfs)
everytime i used to paste these command to mount
sudo ntfsfix /dev/nvme0n1p3
sudo mount -t ntfs /dev/nvme0n1p3 /mnt
any permanent solution for this?
i need to format my disk or i have to change to different partition?
like ext4 or btrfs
any suggestions regarding this?
just want to know how to fix it
for more info
Kernel: 6.5.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=eddfc2bf-f824-464d-b001-d27ff9e017d0 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Laptop System: Acer product: Aspire A715-42G v: V1.10
Mobo: LN model: Azalea_CAS v: V1.10 serial: <superuser required>
UEFI: Insyde v: 1.10 date: 07/28/2022
ID-1: BAT1 charge: 29.9 Wh (100.0%) condition: 29.9/47.8 Wh (62.5%)
volts: 12.3 min: 11.2 model: LGC AP18C8K type: Li-ion serial: <filter>
status: full
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 826 high: 1623 min/max: 400/4056 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 1421
4: 400 5: 400 6: 400 7: 1354 8: 1371 9: 400 10: 1623 11: 1354 12: 400
bogomips: 50304
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Acer Incorporated ALI driver: nvidia v: 535.104.05
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f9d class-ID: 0302
Device-2: AMD Lucienne vendor: Acer Incorporated ALI driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
active: eDP-1 empty: HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 46.0 C
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 0408:a061
class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0xdf87 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: AMD Radeon Graphics
(renoir LLVM 16.0.6 DRM 3.54 6.5.4-zen2-1-zen) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: N/A alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.5.4-zen2-1-zen status: kernel-api with: aoss
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0029
Local Storage: total: 931.51 GiB used: 364.74 GiB (39.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 39.9 C
ID-1: / raw-size: 180 GiB size: 180 GiB (100.00%) used: 68.03 GiB (37.8%)
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 180 GiB size: 180 GiB (100.00%)
used: 68.03 GiB (37.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 180 GiB size: 180 GiB (100.00%)
ID-5: /var/tmp raw-size: 180 GiB size: 180 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.96 GiB used: 156 MiB (1.0%) priority: 100
System Temperatures: cpu: 54.8 C mobo: N/A gpu: amdgpu temp: 48.0 C
Processes: 316 Uptime: 27m wakeups: 1 Memory: total: 16 GiB note: est.
available: 14.96 GiB used: 3.55 GiB (23.7%) Init: systemd v: 254
pm: pacman pkgs: 1548 libs: 498 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date:     2023-09-05
Last full system update: 2023-09-22
I have seen a couple other places (here, here) where it has been mentioned running ntfsfix before mounting an NTFS drive has been needed. There must be a bug somewhere.
If you are not accessing these drives with a Windows system, you should change the filesystem. Some people (:wink:) still consider NTFS support on Linux experimental.
In general, switching to ext4 or Btrfs will give you better reliability, faster performance, and access to more features when accessing the disk from Linux.
Thanks for your suggestions sir :slight_smile:
which one you prefer mostly?
ext4 or btrfs
so ext4 can able access from windows?
I’m not good in these stuffs. so, i listen to the experts advice…
Why the hell are you mounting the windows partition like this I use ntfs for storage in 20 years never had a problem apart from when i did not close windows down properly and the file system was locked by windows.
i found these command helpful for me and solved issues.
i use Garuda as my primary and sometimes just want to access files from windows in emergency cases thats it.
There is a bug in the NTFS driver, which was mentioned in the thread. I even posted a couple links where other folks have the same issue. Try to keep up. :wink:
The main reason to choose Btrfs over ext4 would be to use Btrfs-specific features (filesystem snapshots, Btrfs send/receive, etc). If you don’t think you’ll be using those extra features I would just go with ext4.
But they are not solving issues only making issues worse
their is no bug in the ntfs-3g driver non at all i use it daily for the last 20 years the fault is users nothing more. the reason i use it is because i duel boot and mount the drives at start up. I suggest its you that needs to keep up use ntfs -3g driver not some alpha driver in the kernel
Technically I’m not good in stuffs.
anyway now i decided to move to btrfs…
Incase if you found any article regarding this, just share it
i really appreciate that :slight_smile:
My friend, I believe he is already using ntfs-3g driver. If he was using the new kernel driver, he would be mounting “ntfs3” not “ntfs”.
You can’t be sure of that, The only reason for mounting problems on ntfs drives is a corrupt drive caused by windows, or a locked drive again caused by windows locking the file system. User not shutting down correctly
you are saying that i dualboot windows & garuda and i didnt shutdown my windows correctly?
https://wiki.archlinux.org/title/NTFS-3G
The mount type ntfs-3g does not need to be explicitly specified in Arch. The mount command by default will use /usr/bin/mount.ntfs which is symlinked to /usr/bin/ntfs-3g after the ntfs-3g package is installed.
I’m not arguing with you on what the cause of the problem is. I’m telling you that you’re wrong about him not using ntfs-3g.
What error message do you get if you don’t use the ntfsfix command before mounting?
Wrong fs type, bad option, bad superblock on a harddisk missing codepage or helper program, or other error
something like this
You are assuming i have never stated what driver is being used neither has the user. Either way he seems to have problems with the windows file system locking him out.
I would suggest if he must have a file system compatible with windows to use the Exfat file system
At this point perhaps one of the various CD/USB-based general repair applications, which includes repairing ntfs partitions, might be of use?
Agree. As the user dual boots windows, perhaps just running a chkdsk next time u boot Windows will suffice
I have not seen OP decisively say he has Windows installed.
But then OP says
Unless and until OP can be more decisive, the point of this topic seems moot.
I having this same issue.
It’s strange that my one WD 5TB NTFS partition mounts fine but my Toshiba 1TB NTFS gives the above error.
That is consistent with what we have seen so with this issue, that some hardware is affected and some not. Go ahead and try using ntfsfix as described in the OP and see if it restores you access to the drive. It may be necessary to do it every time until whatever bug gets fixed upstream.
