Can’t mount my ntfs partitions in dolphin Or Any Other way . I tried Everything the web has to offer ,
An error occurred while accessing 'Data Drive', the system responded: The requested operation has failed: Error mounting /dev/sda1 at /run/media/tenuka_2009/Data Drive: wrong fs type, bad option, bad superblock on /dev/sda1, missing codepage or helper program, or other error
An error occurred while accessing 'Basic data partition', the system responded: The requested operation has failed: Error mounting /dev/sda4 at /run/media/tenuka_2009/B6A2A928A2A8EDD5: wrong fs type, bad option, bad superblock on /dev/sda4, missing codepage or helper program, or other error
─tenuka_2009@tenuka in ~
╰─λ garuda-inxi
root=UUID=16b2abf5-32f4-484b-b473-b8cba32443d9 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: Acer product: Aspire A315-56 v: V1.27
Mobo: IL model: Sleepy_IL v: V1.27 serial: <superuser required>
UEFI: Insyde v: 1.27 date: 07/07/2022
ID-1: BAT1 charge: 23.4 Wh (100.0%) condition: 23.4/36.7 Wh (63.9%)
volts: 12.1 min: 11.3 model: LGC AC14B18 type: Li-ion serial: N/A
status: full
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xBC
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 600 high: 1201 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 1201 2: 400 3: 400 4: 400
bogomips: 9523
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56
Device-2: Quanta [] driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-7:2 chip-ID: 0408:a031 class-ID: 0e02
Monitor-1: eDP-1 res: 1366x768 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ICL GT1)
device-ID: 8086:8a56 memory: 3.54 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
UHD Graphics (ICL GT1) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:8a56 surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3
chip-ID: 04ca:3015 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
Local Storage: total: 931.51 GiB used: 7.49 GiB (0.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1J scheme: GPT
ID-1: / raw-size: 51.35 GiB size: 51.35 GiB (100.00%) used: 7.47 GiB (14.5%)
fs: btrfs dev: /dev/sda5 maj-min: 8:5
used: 25.9 MiB (5.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 51.35 GiB size: 51.35 GiB (100.00%)
used: 7.47 GiB (14.5%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-4: /var/log raw-size: 51.35 GiB size: 51.35 GiB (100.00%)
ID-5: /var/tmp raw-size: 51.35 GiB size: 51.35 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.62 GiB used: 28.8 MiB (0.8%) priority: 100
Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
or lm-sensors.
Processes: 213 Uptime: 16m wakeups: 3 Memory: total: 4 GiB
available: 3.62 GiB used: 2.23 GiB (61.7%) Init: systemd v: 254
pm: pacman pkgs: 1216 libs: 358 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
System install date: 2024-02-11
Last full system update: 2024-02-11
Is partially upgraded: Yes
Wow, that must have taken a long time! I take it you have already tried ntfsfix
, then?
I mean no need to read the wiki for this issue , although it would be nice if you do so if you’re curious .
I would recommend you to run this and see if it fixes the issue:
sudo ntfsfix -d /dev/sda2
Then try mounting it.
If It mounts successfully then see if it persists after a reboot.
https://man.archlinux.org/man/ntfsfix.8.en
Bro
12 February 2024 04:41
3
Install the ntfs-3g
pkg if not already installed, please.
system
Closed
14 February 2024 07:25
7
