Hello,
I have an external HDD hard disk,
in the last week I could not able to mount I'm and use him on my system.
Here is the error:
```text
Kernel: 5.16.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=55658808-b83c-4d28-8135-ed014f528479
rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
resume=UUID=63d03045-7298-4cd9-ba53-1b263f17f066 loglevel=3
Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ROG Strix G731GT_G731GT v: 1.0
Mobo: ASUSTeK model: G731GT v: 1.0 serial: <superuser required> UEFI: American Megatrends
v: G731GT.307 date: 04/28/2020
ID-1: BAT0 charge: 40.1 Wh (100.0%) condition: 40.1/50.5 Wh (79.4%) volts: 12.5 min: 12.5
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: not charging
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 801 high: 816 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 816 5: 800 6: 800 7: 800 8: 800 9: 800
10: 800 11: 800 12: 800 bogomips: 62399
mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK driver: i915 v: kernel
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
loaded: modesetting,nvidia gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x084e built: 2018 res: 1920x1080 hz: 60 dpi: 128
gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.3.7 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a370 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb
v: 0.8
bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 2.29 TiB used: 803.62 GiB (34.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB
rev: 002C temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Extreme Portable SSD
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: SSD serial: <filter>
rev: 1012 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital model: WD10SPZX-22Z10T0
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: HDD rpm: 5400 serial: <filter>
scheme: MBR
ID-1: / raw-size: 444.26 GiB size: 444.26 GiB (100.00%) used: 92.57 GiB (20.8%) fs: btrfs
ID-2: /boot/efi raw-size: 350 MiB size: 349.3 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 444.26 GiB size: 444.26 GiB (100.00%) used: 92.57 GiB (20.8%) fs: btrfs
ID-4: /var/log raw-size: 444.26 GiB size: 444.26 GiB (100.00%) used: 92.57 GiB (20.8%)
fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-5: /var/tmp raw-size: 444.26 GiB size: 444.26 GiB (100.00%) used: 92.57 GiB (20.8%)
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
maj-min: 259:3
ID-2: swap-2 type: zram size: 15.48 GiB used: 5.5 MiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 40.0 C pch: 49.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3000
Processes: 368 Uptime: 39m wakeups: 1 Memory: 15.48 GiB used: 4.84 GiB (31.3%) Init: systemd
v: 250 tool: systemctl Compilers: gcc: 11.2.0 Packages: pacman: 1855 lib: 551
Client: shell wrapper v: 5.1.16-release inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2022-03-20
Last full system update: 2022-03-25 ↻
