How can I get the message to go away on Wayland Gnome? Usually the notifications work fine but sometimes they get stuck like this one in the screenshot.
Kernel: 5.18.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=746085a3-1efd-44d0-9e3f-bea3af666d4d rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 nvidia-drm.modeset=1
Desktop: GNOME v: 42.2 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Desktop System: Gigabyte product: X470 AORUS ULTRA GAMING v: N/A
Mobo: Gigabyte model: X470 AORUS ULTRA GAMING-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F3
date: 08/08/2018
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ gen: 2
built: 2018-21 process: GF 12nm family: 0x17 (23) model-id: 8 stepping: 2
microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2887 high: 4007 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3522 2: 2088
3: 2515 4: 3860 5: 2795 6: 2743 7: 4007 8: 2337 9: 2211 10: 3282 11: 3186
12: 2107 bogomips: 86396
Device-1: NVIDIA TU106 [GeForce RTX 2070] vendor: Micro-Star MSI
driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
off: DP-2,HDMI-A-1 empty: DP-1,DP-3,Unknown-1 bus-ID: 09:00.0
chip-ID: 10de:1f02 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-10:9 chip-ID: 046d:082d
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
display-ID: 0
Monitor-1: DP-2 model: Acer X34 serial: <filter> built: 2013
res: 3440x1440 dpi: 109 gamma: 1.2 size: 798x335mm (31.42x13.19")
diag: 865mm (34.1") modes: max: 3440x1440 min: 640x480
Monitor-2: HDMI-A-1 model: Sony TV 01 serial: <filter> built: 2013
res: 1920x1080 dpi: 47 gamma: 1.2 size: 1040x585mm (40.94x23.03")
diag: 1193mm (47") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2
v: 4.6.0 NVIDIA 515.48.07 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 1-10:9 chip-ID: 046d:082d pcie:
gen: 3 class-ID: 0102 speed: 8 GT/s serial: <filter> lanes: 16
bus-ID: 09:00.1 chip-ID: 10de:10f9 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
Device-3: Logitech HD Pro Webcam C920 type: USB
Sound Server-1: ALSA v: k5.18.3-zen1-1-zen running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
Local Storage: total: 2.75 TiB used: 311.73 GiB (11.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 PRO 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7
temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 2T00
type: SSD serial: <filter> rev: 00RL scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 155.86 GiB (8.4%)
used: 580 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
used: 155.86 GiB (8.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 62.75 GiB used: 0 KiB (0.0%) priority: 100
Message: No sensor data found. Is lm-sensors configured?
Processes: 418 Uptime: 23h 45m wakeups: 1 Memory: 62.75 GiB
used: 12.76 GiB (20.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 alt: 11 Packages: pacman: 1786
lib: 468 flatpak: 0 Shell: fish v: 3.4.1 running-in: tmux: inxi: 3.3.17
e[1;34mGaruda (2.6.3-2):e[0m
e[1;34m System install date:e[0m 2021-12-26
e[1;34m Last full system update:e[0m 2022-06-13 e[1;31m↻
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m Probably (Run as root to verify)
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m bluetooth-autoconnect.service systemd-coredump@0-64281-0.service
