Notification sound playing randomly
  Kernel: 6.12.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
    root=UUID=4e5e4ee8-967e-4533-82da-eacbf1bca064 rw rootflags=subvol=@ quiet
    resume=UUID=b6a278ec-210f-42f2-9d70-12b624740488 loglevel=3 ibt=off
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0 wm: kwin_wayland vt: 1
  Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x serial: <superuser required>
    part-nu: SKU uuid: <superuser required> UEFI: American Megatrends v: 2403 date: 06/16/2021
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3 level: v3 note: check
    built: 2022 process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x21 (33) stepping: 0
    microcode: 0xA201016
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 6 threads: 12 tpc: 2 smt: enabled cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3713 min/max: 550/4651 boost: enabled scaling: driver: amd-pstate-epp
    governor: performance cores: 1: 3713 2: 3713 3: 3713 4: 3713 5: 3713 6: 3713 7: 3713 8: 3713
    9: 3713 10: 3713 11: 3713 12: 3713 bogomips: 88793
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900 XTX/7900 GRE/7900M]
    vendor: Sapphire PULSE driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
    built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2,HDMI-A-1 off: HDMI-A-2
    empty: DP-1,Writeback-1 bus-ID: 0a:00.0 chip-ID: 1002:744c class-ID: 0300
  Device-2: Sonix USB Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 1-9.1:10 chip-ID: 26e0:3c13 class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4 compositor: kwin_wayland
    driver: X: loaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3840x1080
    display-ID: 0
  Monitor-1: DP-2 pos: right res: 1920x1080 size: N/A modes: N/A
  Monitor-2: HDMI-A-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
    gbm: drv: kms_swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.7-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 7900 GRE (radeonsi navi31 LLVM 18.1.8 DRM 3.59
    6.12.1-zen1-1-zen) device-ID: 1002:744c memory: 15.62 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.3.295 layers: 15 device: 0 type: discrete-gpu name: AMD Radeon RX 7900 GRE
    (RADV NAVI31) driver: mesa radv v: 24.2.7-arch1.1 device-ID: 1002:744c
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.4
    chip-ID: 1022:1487 class-ID: 0403
  Device-3: Generalplus Usb Audio Device driver: hid-generic,snd-usb-audio,usbhid type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9.3:11 chip-ID: 1b3f:2008 class-ID: 0300
  Device-4: GYROCOM C&C Fiio E10 driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:4 chip-ID: 1852:7022 class-ID: 0102
  API: ALSA v: k6.12.1-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
  Server-1: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse status: active
    tools: p
actl,pw-cat,pw-cli,wpctl
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3 class-ID: 0200
  IF: enp7s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
  IF-ID-1: ham0 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-3: virbr1 state: down mac: <filter>
  IF-ID-4: virbr2 state: down mac: <filter>
  Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0029 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2 lmp-v: 11 status:
  Local Storage: total: 6.35 TiB used: 2 TiB (31.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB size: 1.82 TiB
    fw-rev: 5B2QGXA7 temp: 38.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 980 1TB size: 931.51 GiB
    fw-rev: 3B4QFXO7 temp: 30.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G size: 447.13 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: T1A3
  ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
    fw-rev: 4B6Q scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD10EZEX-08WN4A0 size: 931.51 GiB
    fw-rev: 1A02 scheme: GPT
  ID-6: /dev/sdd maj-min: 8:48 vendor: Toshiba model: HDWD120 size: 1.82 TiB block-size:
    physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter> fw-rev: ACF0
  ID-1: / raw-size: 412.46 GiB size: 412.46 GiB (100.00%) used: 322.42 GiB (78.2%) fs: btrfs
    dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
    dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 412.46 GiB size: 412.46 GiB (100.00%) used: 322.42 GiB (78.2%) fs: btrfs
  ID-4: /var/log raw-size: 412.46 GiB size: 412.46 GiB (100.00%) used: 322.42 GiB (78.2%)
  ID-5: /var/tmp raw-size: 412.46 GiB size: 412.46 GiB (100.00%) used: 322.42 GiB (78.2%)
  ID-1: swap-1 type: zram size: 31.25 GiB used: 475.8 MiB (1.5%) priority: 100 comp: zstd
    avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 12 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 34.38 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
    maj-min: 8:3
  System Temperatures: cpu: 48.1 C mobo: N/A gpu: amdgpu temp: 53.0 C mem: 66.0 C
  Memory: total: 32 GiB available: 31.25 GiB used: 6.16 GiB (19.7%)
  Processes: 440 Power: uptime: 4h 12m states: freeze,mem,disk suspend: deep avail: s2idle
    wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.49 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 256
  Packages: 2249 pm: pacman pkgs: 2229 libs: 606 tools: octopi,paru,
yay pm: flatpak pkgs: 20
    Compilers: clang: 18.1.8 gcc: 14.2.1 Client: shell wrapper v: 5.2.37-release inxi: 3.3.36
  System install date:     2024-04-05
  Last full system update: 2024-12-02 ↻
There is a notification sound for device unplugged and plugged playing at random intervals. When I turn off sound for those events it still keeps playing and I don’t know why. It doesn’t stop unless I turn on Do not disturb mode or turn off all notification sounds.
I tried looking on the web and can’t find any answers, I ran out of ideas what to search for and it’s driving me insane.
↻ restart your PC, from login page use X11.
Same behaver for older kernel?
Problem start after update?
Then use snapshot before this update.
Thank you for the help, I actually managed to figure it out. My TV was disconnecting and reconnecting for some reason but there wasn’t any notification for that but the sound for some reason.
