Noticed some changes in performance since initial installation & issues uninstalling VLC git
Diagnosis may or may not be useful in determining issues.
GPU seems to be being utilized more then it should with no video running.
Running firestorm beta may have exposed the system to exploitation as it seemed to happen after using this application for an extended amount of time a few days after fresh installation.
System is generally slower then it should be intermittently; when online; or when streaming video or using firestorm or games. (slower then initial installation)
GPU is not working as initially intended and as fast as fresh install for 780 integrated.
CPU is not installing correctly.
This could be contributing to kde freezing for 10 seconds at a time.
Ethernet speed could be changing due to an issue with system or router & modem which are older and being replaced.
This has happened to systems as old as 2014 all amd as well as nvidia systems & modern systems seems like an exploit that makes the installations unusable.
Much appreciated.
Kernel: 6.14.11-hardened1-2-hardened arch: x86_64 bits: 64 compiler: gcc
v: 15.1.1 clocksource: tsc avail: hpet,acpi_pm parameters: pti=on
root=UUID=ae2423f0-deb7-4c93-839e-8c1e50dc6871 rw rootflags=subvol=@
quiet rd.luks.uuid=c81a926c-abfd-44bd-88f3-7903c6806431
rd.luks.uuid=b2e08dcf-2495-47de-9445-b93a2d46c4bc
resume=/dev/mapper/luks-b2e08dcf-2495-47de-9445-b93a2d46c4bc loglevel=3
Desktop: KDE Plasma v: 6.4.3 tk: Qt v: N/A info: frameworks v: 6.16.0
Type: Mini-pc System: Micro (HK) Tech product: Venus series v: N/A
Mobo: Shenzhen Meigao Equipment model: F7BSC serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 1.09
date: 11/20/2023
Device-1: hidpp_battery_0 model: Logitech Illuminated Living-Room Keyboard
K830 serial: <filter> charge: 55% (should be ignored) rechargeable: yes
Info: model: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics bits: 64
microcode: 0xA704104
Speed (MHz): avg: 2386 min/max: 400/5263 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2386 2: 2386 3: 2386
4: 2386 5: 2386 6: 2386 7: 2386 8: 2386 9: 2386 10: 2386 11: 2386 12: 2386
13: 2386 14: 2386 15: 2386 16: 2386 bogomips: 127767
Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 driver: amdgpu v: kernel
arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, Writeback-1 bus-ID: c5:00.0
chip-ID: 1002:15bf class-ID: 0300 temp: 59.0 C
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3440x2880
display-ID: 0
Monitor-1: HDMI-A-1 pos: bottom model: Samsung S34CG50 serial: <filter>
built: 2024 res: mode: 3440x1440 hz: 100 scale: 100% (1) dpi: 109 gamma: 1.2
size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: max: 3440x1440
min: 720x400
Monitor-2: HDMI-A-2 pos: primary,top model: Samsung S34CG50
serial: <filter> built: 2024 res: mode: 3440x1440 hz: 100 scale: 100% (1)
dpi: 109 gamma: 1.2 size: 798x334mm (31.42x13.15") diag: 869mm (34.2")
modes: max: 3440x1440 min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M Graphics (radeonsi
phoenix LLVM 20.1.8 DRM 3.61 6.14.11-hardened1-2-hardened)
device-ID: 1002:15bf memory: 1.95 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon 780M Graphics (RADV PHOENIX) driver: mesa radv v: 25.1.6-arch1.1
device-ID: 1002:15bf surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.6-arch1.1 (LLVM
[Rembrandt/Strix] driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: c5:00.1 chip-ID: 1002:1640 class-ID: 0403
bus-ID: c5:00.5 chip-ID: 1022:15e2 class-ID: 0480
bus-ID: c5:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.14.11-hardened1-2-hardened status: kernel-api tools: N/A
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:4 chip-ID: 8087:0032
Local Storage: total: 2.05 TiB used: 36.59 GiB (1.7%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 42.9 C
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 45.9 C scheme: GPT
ID-1: / raw-size: 200.52 GiB size: 200.52 GiB (100.00%)
used: 36.59 GiB (18.2%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-c81a926c-abfd-44bd-88f3-7903c6806431
used: 776 KiB (0.3%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:7
ID-3: /home raw-size: 200.52 GiB size: 200.52 GiB (100.00%)
ID-4: /var/log raw-size: 200.52 GiB size: 200.52 GiB (100.00%)
ID-5: /var/tmp raw-size: 200.52 GiB size: 200.52 GiB (100.00%)
ID-1: swap-1 type: partition size: 32.07 GiB used: 0 KiB (0.0%)
mapped: luks-b2e08dcf-2495-47de-9445-b93a2d46c4bc
ID-2: swap-2 type: zram size: 29.15 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 67.1 C mobo: 59.5 C gpu: amdgpu temp: 60.0 C
Memory: total: 32 GiB note: est. available: 29.15 GiB
used: 12.36 GiB (42.4%)
Processes: 435 Power: uptime: 1h 26m states: freeze,mem suspend: s2idle
wakeups: 0 services: org_kde_powerdevil, power-profiles-daemon, upowerd
Packages: pm: pacman pkgs: 1489 libs: 461 tools: octopi,paru Compilers:
inxi: 3.3.38
Garuda (2.7.3-2):
System install date:     2025-05-30
Last full system update: 2025-07-31
Failed units:            systemd-hibernate-resume.service
date: 11/20/2023
display-ID: 0
min: 720x400
inxi: 3.3.38
Garuda (2.7.3-2):
Please, no pictures from terminal.
Images can be read worse, are not searchable and copyable for further search.
Use this in Rani
The mostly effect for this is the hardened kernel. (my mind)
