Hello, I just booted my PC and almost nothing was loaded. The menu bar, the dock, etc. Even pressing the windows key don't work.
This happened to me a few times in the past, and I just reinstalled Garuda and it worked again, but I want to fix this problem once and for all without reinstalling every time.
McFly: Upgrading McFly DB to version 3, please wait...thread 'main' panicked at 'McFly error: Unable to add cm
d_tpl to commands (duplicate column name: cmd_tpl)', src/history/schema.rs:41:17
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
Please post always in- and output from terminal text. No problem for inxi, but for other inputs it is important.
If you include terminal outputs in your post please
use the proper output format in your post.
Using "~" 3 times above and "~" 3 times below the text block
will provide a readable, raw look.
greetings SGS
Could you post your Journal Errors as well? You can get those from Garuda Assistant > Other Diagnostics tab> Journal Errors button, then hit the Copy for Forum button. (if there is nothing much there currently, try grabbing them again when your issues start cropping up; there could be HDD issues or something).
This is probably the only part that may be helpful, the other logs were related to sudo commands
jan 14 10:11:10 imperium kernel: usb 3-2: device descriptor read/64, error -71
jan 14 10:11:10 imperium kernel: usb 3-2: device not accepting address 4, error -71
jan 14 10:11:10 imperium kernel: usb 3-2: device not accepting address 5, error -71
jan 14 10:11:10 imperium kernel: usb usb3-port2: unable to enumerate USB device
I tried this command: cp -rf /etc/skel/. ~/ rebooted, and it worked. I think that sometimes, for some reason, my PC removes some dot files from my home directory, does that make sense?
The menu bar, dock, windows key and stuff are all part of latte-dock in this case. You didn't mention anything else so I assumed latte dock was the problem.
I find this error is usually corrected by adding the iommu=soft kernel parameter. Search the forum or the Archwiki for the procedure involved in changing a kernel parameter.
Oh… this might explain the lack of responsiveness after a reboot if its related to an issue I helped with recently.
I helped a Garuda user troubleshoot an issue a while back (not on the forums) that had this error in the logs and found out it was because it was trying to connect to a wireless keyboard first after login (keyboard that was off and using a 2.4ghz wireless USB receiver), and the user had also a wired keyboard connected. While the issue was going, after logging in the system would be very unresponsive for a long period of time.
I would check for anything like that on your setup (powered down devices using a wireless receiver, etc).
As a trouble shooting step unplug your wireless USB receivers (or similar) when you shut down. After you log in plug them back in.
