Hello Garuda users.
After a fresh install of Garuda Dragonized Gaming, I have lost the ability to use external monitors on my laptop (Legion 5, 4800H, 1660ti)
I have confirmed it works on POP!_OS.
The Nvidia dGPU seems to work fine besides the monitor issue;
prime-run glxgears
works properly and shows in nvtop
Here is the output of my garuda-inxi:
Kernel: 5.19.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3d9a570f-ce0a-4fb6-818e-dc8cdc9950ef rw rootflags=subvol=@
Type: Laptop System: LENOVO product: 82B1 v: Lenovo Legion 5 15ARH05H
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion 5 15ARH05H
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> UEFI: LENOVO v: FSCN14WW date: 08/26/2020
ID-1: BAT0 charge: 54.9 Wh (100.0%) condition: 54.9/60.0 Wh (91.5%)
volts: 17.3 min: 15.4 model: SMP L19M4PC0 type: Li-poly serial: <filter>
status: full cycles: 158
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x60 (96) stepping: 1 microcode: 0x8600104
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 2975 high: 4291 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2900 2: 2900
3: 4291 4: 1390 5: 4220 6: 2900 7: 2900 8: 2900 9: 2900 10: 2900 11: 2900
12: 2900 13: 2900 14: 2900 15: 2900 16: 2900 bogomips: 92626
protection
Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Lenovo
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2191 class-ID: 0300
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: none
bus-ID: 06:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-3: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-3:3 chip-ID: 174f:244c class-ID: 0e02 serial: <filter>
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: amdgpu
Monitor-1: DP-1-0.2 size-res: N/A modes: N/A
Monitor-2: eDP pos: primary res: 1920x1080 hz: 144 dpi: 142
size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.47 5.19.5-zen1-1-zen)
v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 06:00.5 chip-ID: 1022:15e2
class-ID: 0480
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.19.5-zen1-1-zen running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 4-1.4.2:4 chip-ID: 0bda:8153 class-ID: 0000
IF: enp6s0f3u1u4u2 state: down mac: <filter>
bus-ID: 5-3:3 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 1.84 TiB used: 22.33 GiB (1.2%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 980 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B4QFXO7
temp: 44.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 42A4SANA
temp: 42.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 22.33 GiB
(2.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
(0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 22.33
GiB (2.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 22.33
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 22.33
ID-1: swap-1 type: zram size: 30.73 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 67.9 C mobo: N/A gpu: amdgpu temp: 40.0 C
Processes: 406 Uptime: 21m wakeups: 1 Memory: 30.73 GiB used: 4.6 GiB
(15.0%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pacman: 2045 lib: 561
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-08-31
Last full system update: 2022-09-01 ↻
I apologize for the loss of indentation.
P.S. I can't promise instant responses, but I will attempt to respond asap
