Hi everyone,
With Dolphin I’d like to access to my NAS Synology on my local network. I tried to do it 2 different ways :
- I clicked on “network”, “shared files (SMB)” and then “Synology”.  Instead of connection window where I can enter my login and password, I have an error message : “Internal error.
 Please submit a full bug report to https://bugs.kde.org
 Unknown error condition: [38] Function not implemented”
- I right-clicked on the left column to add an entry and I specified the path “smb://192.168.1.67” wich is the IP address of my NAS. I had the same error.
It seems that smb and smbclient are enabled.
Can you help me to understand what is going wrong and how to solve it ?
Here it is the garuda inxi return :
Kernel: 6.12.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1bf0e5da-0620-4a3d-aad4-2cd3ae74bf23 rw rootflags=subvol=@
quiet resume=UUID=a1a2afb2-5b62-4491-a8b0-98ed4bbc1678 loglevel=3 ibt=off
Type: Desktop System: ASRock product: Z790 PG Lightning/D4 v: N/A
Mobo: ASRock model: Z790 PG Lightning/D4 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 9.01
date: 10/13/2023
Device-1: hidpp_battery_0 model: Logitech ERGO M575 Trackball
serial: <filter> charge: 35% rechargeable: yes status: discharging
Info: model: Intel Core i5-14600K bits: 64 type: MST AMCP arch: Raptor Lake
gen: core 14 level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xB7 (183) stepping: 1 microcode: 0x12B
Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
KiB, 8x64 KiB L2: 20 MiB desc: 6x2 MiB, 2x4 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1100 min/max: 800/5300:4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 1100 2: 1100 3: 1100
4: 1100 5: 1100 6: 1100 7: 1100 8: 1100 9: 1100 10: 1100 11: 1100 12: 1100
13: 1100 14: 1100 15: 1100 16: 1100 17: 1100 18: 1100 19: 1100 20: 1100
bogomips: 139776
Device-1: NVIDIA AD106 [GeForce RTX 4060 Ti] vendor: Gigabyte driver: nvidia
v: 565.77 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: none off: DP-2 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 01:00.0 chip-ID: 10de:2803 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: DP-2 model: LG (GoldStar) ULTRAGEAR serial: <filter>
built: 2024 res: mode: 2560x1440 hz: 180 scale: 100% (1) dpi: 109 gamma: 1.2
max: 2560x1440 min: 640x480
API: OpenGL v: 4.6.0 vendor: nvidia v: 565.77 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 4060 Ti/PCIe/SSE2
memory: 15.62 GiB display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Ti driver: N/A device-ID: 10de:2803
Device-1: Intel Raptor Lake High Definition Audio vendor: ASRock
Device-2: NVIDIA AD106M High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:22bd class-ID: 0403
API: ALSA v: k6.12.10-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
Local Storage: total: 931.51 GiB used: 24.91 GiB (2.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 31.9 C
ID-1: / raw-size: 337.36 GiB size: 337.36 GiB (100.00%)
used: 24.91 GiB (7.4%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /home raw-size: 337.36 GiB size: 337.36 GiB (100.00%)
ID-4: /var/log raw-size: 337.36 GiB size: 337.36 GiB (100.00%)
ID-5: /var/tmp raw-size: 337.36 GiB size: 337.36 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.36 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 20
ID-2: swap-2 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 34.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.36 GiB used: 3.3 GiB (21.5%)
Processes: 398 Power: uptime: 25m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.09 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1912 libs: 570 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
Garuda (2.6.26-1.1):
System install date:     2025-01-23
Last full system update: 2025-01-23
Thanks in advance
