hello again
garuda black arch is not booting up. it was working fine from 2-3 days but now when i try to boot the loading completes but the login screen don't appears the even then loading animations are working, i waited for half an hour but it don't boots up. how can i get the logs so i can see what's causing the problem? and if you know how i can fix this up please reply. the linux is dual booted with windows 10 (bootloader is working fine)
You could start from here and try (suggested) or restore the latest working snapshot
