Hello ,
I just wanted to try out a kernel cachyos as read about it here :
the kernel doesn’t worked but that’s not a problem the real problem is that after installing it, I wasn’t even able to log in through my old kernel linux-cacule and so for getting it into previous state I tried to restore my system through grub boot menu I was able to boot into a snapshot just before I tried to install cachyos and there came a pop up of btrfs assistant to restore the sanpshot I just clicked yes and typed my password but it doesn’t restored anything and when I rebooted it was still not showing login option .
Please help me so that I can restore my system .
Thanks in advance .
╭─ankur@ankur in ~
╰─λ garuda-inxi
Kernel: 5.15.3-2-cacule x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/.snapshots/636/snapshot/boot/vmlinuz-linux-cacule
root=UUID=3d8862a3-cc90-4161-81ad-195e8064062c loglevel=3 quiet splash
systemd.unified_cgroup_hierarchy=1 sysrq_always_enabled=1
rootflags=defaults,noatime,noautodefrag,compress=zstd,subvol=@/.snapshots/636/snapshot
Desktop: sway 1.7 vt: 1 dm: N/A Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Dell product: Inspiron 7570 v: N/A
Mobo: Dell model: 06K08K v: A00 serial: <superuser required> UEFI: Dell
v: 1.16.0 date: 02/17/2020
ID-1: BAT0 charge: 21.2 Wh (100.0%) condition: 21.2/42.0 Wh (50.5%)
volts: 12.7 min: 11.4 model: Samsung SDI DELL CYMGM79 type: Li-ion
serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
status: Discharging
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 794 high: 800 min/max: 400/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 764 2: 800 3: 800 4: 800
5: 800 6: 800 7: 795 8: 800 bogomips: 32026
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Dell driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:134d class-ID: 0302
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus-ID: 1-5:3 chip-ID: 1bcf:28c1 class-ID: 0e02
Display: wayland server: N/A compositor: sway v: 1.7 driver:
loaded: nouveau note: n/a (using device driver) display-ID: 1
resolution: <missing: xdpyinfo>
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
Sound Server-1: ALSA v: k5.15.3-2-cacule running: yes
Sound Server-4: PipeWire v: 0.3.44 running: yes
vendor: Dell driver: r8169 v: kernel port: d000 bus-ID: 02:00.0
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 03:00.0
chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-7:4 chip-ID: 8087:0a2a class-ID: e001
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 1.14 TiB used: 32.82 GiB (2.8%)
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM3
ID-2: /dev/sdb maj-min: 8:16 vendor: Micron model: 1100 SATA 256GB
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: L003 scheme: GPT
used: 32.82 GiB (3.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.51 GiB used: 3.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C pch: 43.0 C mobo: 43.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 253 Uptime: 18m wakeups: 4 Memory: 7.51 GiB
used: 2.04 GiB (27.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1517 lib: 470 Shell: fish
v: 3.3.1 running-in: alacritty inxi: 3.3.12
Garuda (2.5.3-1):
System install date: 2022-01-24
Last full system update: 2022-02-01
Failed units: garuda-pacman-lock.service nmb.service smb.service systemd-guest-user.service
╭─ankur@ankur in ~ took 4s
╰─λ
) and start taking the most varied ways, unmounting and remounting snaphots, volumes and whatnot all over the disk, changing fstab, anything.
