Hello fellow Garuda users.
I have a 2TB HDD which is formatted as a LDM NTFS partitions(It has 5 partitions). I had, in the past, managed to mount them using ldmtools.
So I figured that would work this time too.
I will try to give a summary of what I did sequentially (I may make some errors because I have been trying for a while).
- ran ntfsfix on the drive.(I got confused and thought it was ldmtools
) but nothing changed and I was still not able to mount.
- Then I used ntfs-3gs (following an article from the internet.) but it had absolutely no impact(at least I believe so).
- I finally ran
sudo ldmtools create all
This seemed to work and I was able to see my partitions in Dolphin, but when I tried to mount them through Dolphin, I was unable to mount 2 partitions.
╭─[email protected] in ~ took 1s
╰─λ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 1.8T 0 disk
├─sda1 8:1 0 1M 0 part
├─sda2 8:2 0 15M 0 part
├─sda3 8:3 0 1.8T 0 part
├─ldm_vol_TUSHAR-DESKTOP-Dg0_Volume1 253:0 0 527.3G 0 ldm
├─ldm_vol_TUSHAR-DESKTOP-Dg0_Volume2 253:1 0 306.7G 0 ldm /run/media/tusharhero/Volume 2
├─ldm_vol_TUSHAR-DESKTOP-Dg0_Volume3 253:2 0 271.1G 0 ldm /run/media/tusharhero/Volume 3
├─ldm_vol_TUSHAR-DESKTOP-Dg0_Volume4 253:3 0 359.1G 0 ldm
└─ldm_vol_TUSHAR-DESKTOP-Dg0_Volume5 253:4 0 3G 0 ldm /run/media/tusharhero/New Volume
sdb 8:16 0 111.8G 0 disk
├─sdb1 8:17 0 300M 0 part /boot/efi
├─sdb2 8:18 0 102.7G 0 part /srv
│ /var/cache
│ /var/tmp
│ /var/log
│ /root
│ /home
└─sdb3 8:19 0 8.8G 0 part [SWAP]
zram0 254:0 0 5.7G 0 disk [SWAP]
I am talking about Volume1 and Volume4. These just refuse to mount. I tried to mount it using the mount
command.
╭─[email protected] in ~ took 3s
╰─λ sudo mount /dev/mapper/ldm_vol_TUSHAR-DESKTOP-Dg0_Volume1 /mnt/a
[sudo] password for tusharhero:
mount: /mnt/a: wrong fs type, bad option, bad superblock on /dev/mapper/ldm_vol_TUSHAR-DESKTOP-Dg0_Volume1, missing codepage or helper program, or other error.
dmesg(1) may have more information after failed mount system call.
The same happens with Volume4.
Here is the dmesg output(trimmed)
[ 2190.985270] kauditd_printk_skb: 1 callbacks suppressed
[ 2190.985272] audit: type=1101 audit(1673278373.639:265): pid=4689 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tusharhero" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2190.985390] audit: type=1110 audit(1673278373.639:266): pid=4689 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2190.987574] audit: type=1105 audit(1673278373.642:267): pid=4689 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2190.988730] audit: type=1106 audit(1673278373.643:268): pid=4689 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2190.988766] audit: type=1104 audit(1673278373.643:269): pid=4689 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2192.665854] audit: type=1101 audit(1673278375.319:270): pid=4714 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tusharhero" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2192.666078] audit: type=1110 audit(1673278375.319:271): pid=4714 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2192.668597] audit: type=1105 audit(1673278375.322:272): pid=4714 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2192.670141] audit: type=1106 audit(1673278375.324:273): pid=4714 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2192.670174] audit: type=1104 audit(1673278375.324:274): pid=4714 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2201.239319] kauditd_printk_skb: 5 callbacks suppressed
[ 2201.239322] audit: type=1101 audit(1673278383.893:280): pid=4762 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tusharhero" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2201.239626] audit: type=1110 audit(1673278383.893:281): pid=4762 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2201.244274] audit: type=1105 audit(1673278383.898:282): pid=4762 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
I am not brave enough to try to read that.
This is all information I could provide. If I missed some info please inform me. I have really important data in those partitions.
Edit:
I ran fschk
too but to mention it. according to this. My data is gone. Any way to recover my data?
garuda-inxi:
Kernel: 6.1.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=e01c77a9-8744-4c85-afee-cef1f429bd62 rw [email protected]
resume=UUID=f9b0b8af-d574-4661-a0d5-4e2a9f483bd3 loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5220
date: 09/12/2019
Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1256 high: 1258 min/max: 1400/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1257 2: 1256
3: 1254 4: 1258 bogomips: 28745
ports: active: HDMI-A-1 empty: DP-1 bus-ID: 07:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 35.0 C
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) FULL HD
serial: <filter> built: 2016 res: 1920x1080 hz: 75 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 22.3.2 renderer: AMD Radeon Vega 8 Graphics
(raven LLVM 14.0.6 DRM 3.49 6.1.4-zen2-1-zen) direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: ASUSTeK PRIME B450M-A driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK PRIME B450M-A
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.1.4-zen2-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: r8188eu bus-ID: 1-8:4 chip-ID: 0bda:8179 class-ID: 0000
IF: wlp1s0f0u8 state: up mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-3:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 1.93 TiB used: 526.91 GiB (26.7%)
model: WD20EZAZ-00GGJB0 size: 1.82 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU650 size: 111.79 GiB
serial: <filter> rev: 831a scheme: GPT
ID-1: / raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
used: 6.99 GiB (6.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 608 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
ID-4: /var/log raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
ID-5: /var/tmp raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.71 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/sdb3 maj-min: 8:19
System Temperatures: cpu: 35.2 C mobo: N/A gpu: amdgpu temp: 35.0 C
Processes: 249 Uptime: 22m wakeups: 0 Memory: 5.72 GiB
used: 2.62 GiB (45.8%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1174
libs: 311 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
Garuda (2.6.14-1):
System install date: 2023-01-09
Last full system update: 2023-01-09
Is partially upgraded: Yes
