Not able to install Garuda
Hello Everyone, I am new here on Garuda after finding the right distro for my gaming laptop. Tried some others but decided I want Garuda as my daily driver. So I wanted to install it again, but when choosing for the usb to start up, nothing happened. I downloaded the distro again, checked the checksum, all well, but same result. Tried it on an other stick, on an other input, same result: nothing happened. I also tried copying the iso with different programs, but that also didn’t do it. Does anyone know what is going wrong here? Or what I am doing wrong?
Other distro’s are going well, so I really don’t know what is happening here.
I hope someone can help me out!
Best regards,
Arja
Use Ventoy. When you boot from USB make sure you use grub2. Double check that secure boot is turned off or set to Other OS.
  • open source driver - not prob. driver.
    After life boot → install garuda → boot the installed system → your choice to install apps → through this you have a current system. (default) → reboot, then post your garuda-inxi.
Thank you TwistedXenos, using grub2 in ventoy did it. Thank you very much! I don’t know why did didn’t happen the first time i installed from ventoy, just went booting from the first line and all went well then.
But i am very happy, thanks!
I am not at home right now, so this will have to wait until sunday. But will do, thank you.
