Can’t seem to get nut-client going in Garuda, working on Linux-Mint, Windows, OpenMediavault, QNAS, Ubutntu, everything but Garuda.
I get:sudo systemctl restart nut-client Failed to restart nut-client.service: Unit nut-client.service not found.
and
sudo systemctl enable nut-client Failed to enable unit: Unit nut-client.service does not exist
I followed the instructions on Google Ai
and on Techno Tim’s YT video to get some insight. Also have installed the APC UPS on other devices to figure it out, but decided on the QNAP NAS as the nut-server, as it is on 24/7 and it is working on all the above systems.
Any insight or an actual Garuda instruction?
Kernel: 6.14.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1a5793f8-3377-4500-9b95-bcfc4a65af9e rw rootflags=subvol=@
Desktop: Cinnamon v: 6.4.9 tk: GTK v: 3.24.49 wm: Muffin v: 6.4.1 tools:
avail: cinnamon-screensaver,xautolock vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Dell product: Inspiron 3670 v: N/A
Mobo: Dell model: 0H4VK7 v: A01 serial: <superuser required> part-nu: 0868
uuid: <superuser required> UEFI: Dell v: 2.21.0 date: 12/03/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
Info: model: Intel Core i5-9600K bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xF8
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 smt: <unsupported> cache:
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
governor: performance cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
bogomips: 44398
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Dell
ports: active: none empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e98 class-ID: 0380
Device-2: NVIDIA GP108 [GeForce GT 1030] vendor: Gigabyte driver: nvidia
v: 570.144 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 4
ports: active: none off: HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0
chip-ID: 10de:1d01 class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6 driver: X:
loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x331mm (23.70x13.03")
s-diag: 687mm (27.05")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Acer KB272HL H
serial: <filter> built: 2022 res: mode: 1920x1080 hz: 75 scale: 100% (1)
dpi: 82 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
device: 3 drv: swrast gbm: drv: iris surfaceless: drv: nvidia x11:
drv: nvidia inactive: wayland
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
memory: 1.95 GiB
API: Vulkan v: 1.4.309 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA GeForce GT 1030 driver: nvidia v: 570.144 device-ID: 10de:1d01
surfaces: xcb,xlib device: 1 type: discrete-gpu
device-ID: 10de:1d01 surfaces: xcb,xlib device: 2 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel
v: 25.0.4-arch1.1 device-ID: 8086:3e98 surfaces: xcb,xlib device: 3
type: cpu name: llvmpipe (LLVM 19.1.7 256 bits) driver: mesa llvmpipe
v: 25.0.4-arch1.1 (LLVM 19.1.7) device-ID: 10005:0000 surfaces: xcb,xlib
Info: Tools: api: eglinfo, glxinfo, vulkaninfo
gpu: nvidia-settings,nvidia-smi x11: xdpyinfo, xprop, xrandr
Device-2: NVIDIA GP108 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:0fb8 class-ID: 0403
API: ALSA v: k6.14.3-zen1-1-zen status: kernel-api tools: N/A
Device-2: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0 chip-ID: 8086:15f3
IF: enp3s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
Local Storage: total: 2.73 TiB used: 982.1 GiB (35.1%)
model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 620361WD temp: 25.9 C scheme: GPT
model: WD20EARX-00PASB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: AB51
temp: 30 C scheme: MBR
ID-1: / raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
used: 114.42 GiB (20.5%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 27 MiB (28.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
ID-4: /var/log raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
ID-5: /var/tmp raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.16 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 6
System Temperatures: cpu: 28.0 C pch: 33.0 C mobo: 26.0 C gpu: nvidia
temp: 34 C
Fan Speeds (rpm): fan-1: 985 gpu: nvidia fan: 42%
Memory: total: 32 GiB available: 31.16 GiB used: 3.2 GiB (10.3%)
Processes: 291 Power: uptime: 31m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.4 GiB services: csd-power,upowerd
Packages: 1660 pm: pacman pkgs: 1644 libs: 462 tools: pamac,paru
pm: flatpak pkgs: 16 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 4.0.2 running-in: gnome-terminal inxi: 3.3.38
System install date: 2024-09-26
Last full system update: 2025-04-25
Failed units: media-omv2-storage.mount systemd-sysctl.service
