Hello.
I'm new to Arch and dual booted garuda with windows 10 on my Asus Tuf A15 system. Everything is working fine just i'm not able to enable bluetooth. Hovering over grayed-out bluetooth icon showing 'No Bluetooth adapter available.'
My bluetooth adapter present on machine is from Mediatek.
I've read almost all the threads about this issue.
- Fast boot and secure boot is disabled.
- turned off hibernation too in windows.
- Turned of wifi powersave option in Garuda network Assistant
- Tried various linux kernels -> lts, mainline, hardened
I thought it's kernel issue ( of 5.13.x ) but bluetooth was working in live install ( when i was installing garuda ) and also after install it was working. After that i rebooted my laptop and still it was working. After that i did pacman -Syy and rebooted my system and now it's not working.
╰─λ inxi -Faz
System: Kernel: 5.13.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=c9b200e5-7dce-4444-a082-ab779f1022d8
systemd.unified_cgroup_hierarchy=1 resume=UUID=ac02eee0-3cf0-4e16-9245-506de4be3952 loglevel=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506QM_FA566QM v: 1.0
Mobo: ASUSTeK model: FA506QM v: 1.0 serial: <filter> UEFI: American Megatrends LLC.
v: FA506QM.307 date: 06/02/2021
Battery: ID-1: BAT1 charge: 76.0 Wh (84.2%) condition: 90.3/90.2 Wh (100.1%) volts: 16.4 min: 15.9
model: ASUS A32-K55 type: Li-ion serial: N/A status: Discharging
CPU: Info: 8-Core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 50 (80) stepping: 0 microcode: A50000C cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 102206
Speed: 1397 MHz min/max: 1200/3200 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 2868
3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1731 12: 1396 13: 1397
14: 1888 15: 1603 16: 1691
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
Graphics: Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK driver: nvidia
v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 05:00.0
chip-ID: 1002:1638 class-ID: 0300
Device-3: Sonix USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus-ID: 1-4:2
chip-ID: 322e:202c class-ID: 0e02
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.9-zen1-1-zen LLVM 12.0.1) v: 4.6 Mesa 21.1.6
direct render: Yes
Audio: Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-2: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 05:00.1
Device-3: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.13.9-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK vendor: AzureWave driver: mt7921e v: kernel port: e000 bus-ID: 03:00.0
chip-ID: 14c3:7961 class-ID: 0280
Bluetooth: Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8 bus-ID: 3-3:2
chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: N/A
Drives: Local Storage: total: 476.94 GiB used: 8.87 GiB (1.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX013N size: 476.94 GiB
rev: 41000C20 temp: 45.9 C scheme: GPT
Partition: ID-1: / raw-size: 44.92 GiB size: 44.92 GiB (100.00%) used: 8.68 GiB (19.3%) fs: btrfs
dev: /dev/nvme0n1p9 maj-min: 259:9
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 30.1 MiB (11.8%) fs: vfat
ID-3: /home raw-size: 48.83 GiB size: 48.83 GiB (100.00%) used: 162.2 MiB (0.3%) fs: btrfs
dev: /dev/nvme0n1p8 maj-min: 259:8
ID-4: /var/log raw-size: 44.92 GiB size: 44.92 GiB (100.00%) used: 8.68 GiB (19.3%) fs: btrfs
ID-5: /var/tmp raw-size: 44.92 GiB size: 44.92 GiB (100.00%) used: 8.68 GiB (19.3%) fs: btrfs
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p10 maj-min: 259:10
ID-2: swap-2 type: zram size: 15.04 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 59.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 386 Uptime: 11m wakeups: 1047 Memory: 15.04 GiB used: 3.49 GiB (23.2%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1180 lib: 296
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
╰─λ sudo dmesg | grep -i bluetooth
[sudo] password for av:
[ 4.124944] Bluetooth: Core ver 2.22
[ 4.125012] Bluetooth: HCI device and connection manager initialized
[ 4.125036] Bluetooth: HCI socket layer initialized
[ 4.125039] Bluetooth: L2CAP socket layer initialized
[ 4.125058] Bluetooth: SCO socket layer initialized
[ 4.555971] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.555990] Bluetooth: BNEP filters: protocol multicast
[ 4.556006] Bluetooth: BNEP socket layer initialized
╰─λ journalctl -b -1 | grep -i bluetooth
Aug 15 19:18:51 darkShadow kernel: Bluetooth: Core ver 2.22
Aug 15 19:18:51 darkShadow kernel: Bluetooth: HCI device and connection manager initialized
Aug 15 19:18:51 darkShadow kernel: Bluetooth: HCI socket layer initialized
Aug 15 19:18:51 darkShadow kernel: Bluetooth: L2CAP socket layer initialized
Aug 15 19:18:51 darkShadow kernel: Bluetooth: SCO socket layer initialized
Aug 15 19:18:51 darkShadow systemd[1]: Started Bluetooth autoconnect service.
Aug 15 19:18:51 darkShadow audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueto
oth-autoconnect comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 15 19:18:51 darkShadow systemd[1]: Starting Bluetooth service...
Aug 15 19:18:51 darkShadow bluetoothd[622]: Bluetooth daemon 5.60
Aug 15 19:18:51 darkShadow bluetoothd[622]: Starting SDP server
Aug 15 19:18:51 darkShadow systemd[1]: Started Bluetooth service.
oth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 15 19:18:51 darkShadow systemd[1]: Reached target Bluetooth Support.
Aug 15 19:18:51 darkShadow kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Aug 15 19:18:51 darkShadow kernel: Bluetooth: BNEP filters: protocol multicast
Aug 15 19:18:51 darkShadow kernel: Bluetooth: BNEP socket layer initialized
Aug 15 19:18:51 darkShadow dbus-daemon[624]: [system] Activating via systemd: service name='org.freedesktop.ho
stname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.2' (uid=0 pid=622 comm="/usr/lib/bluet
ooth/bluetoothd ")
Aug 15 19:18:51 darkShadow bluetoothd[622]: Bluetooth management interface 1.20 initialized
Aug 15 19:18:52 darkShadow NetworkManager[626]: <info> [1629035332.0154] Loaded device plugin: NMBluezManager
(/usr/lib/NetworkManager/1.32.6-1/libnm-device-plugin-bluetooth.so)
Aug 15 19:18:59 darkShadow systemd[1816]: Starting Bluetooth OBEX service...
Aug 15 19:18:59 darkShadow systemd[1816]: Started Bluetooth OBEX service.
Aug 15 19:18:59 darkShadow kded5[2058]: bluedevil: Bluetooth operational changed true
Aug 15 19:21:54 darkShadow dbus-daemon[624]: [system] Activating via systemd: service name='org.freedesktop.ho
me1' unit='dbus-org.freedesktop.home1.service' requested by ':1.76' (uid=0 pid=7053 comm="sudo vim /etc/blueto
oth/main.conf ")
Aug 15 19:22:11 darkShadow dbus-daemon[624]: [system] Activating via systemd: service name='org.freedesktop.ho
me1' unit='dbus-org.freedesktop.home1.service' requested by ':1.78' (uid=0 pid=7530 comm="sudo vim /etc/blueto
oth/main.conf ")
Aug 15 19:22:11 darkShadow sudo[7530]: av : TTY=pts/0 ; PWD=/home/av ; USER=root ; COMMAND=/usr/bin/vim
/etc/bluetooth/main.conf
Aug 15 19:24:16 darkShadow dbus-daemon[624]: [system] Activating via systemd: service name='org.freedesktop.ho
me1' unit='dbus-org.freedesktop.home1.service' requested by ':1.79' (uid=0 pid=9459 comm="sudo pacman -Ss garu
da-bluetooth ")
Aug 15 19:24:16 darkShadow sudo[9459]: av : TTY=pts/0 ; PWD=/home/av ; USER=root ; COMMAND=/usr/bin/pacm
an -Ss garuda-bluetooth
Aug 15 19:26:49 darkShadow systemd[1816]: Started Bluetooth Manager.
Aug 15 19:26:50 darkShadow systemd[1816]: Starting Bluetooth management applet...
Aug 15 19:26:50 darkShadow systemd[1]: Starting Bluetooth management mechanism...
Aug 15 19:26:50 darkShadow systemd[1]: Started Bluetooth management mechanism.
Aug 15 19:26:50 darkShadow systemd[1816]: Started Bluetooth management applet.
Aug 15 19:27:01 darkShadow systemd[1816]: Started Bluetooth Manager.
Aug 15 19:27:14 darkShadow systemd[1816]: Started Bluetooth Manager.
Aug 15 19:27:34 darkShadow systemd[1816]: Starting Bluetooth Manager...
Aug 15 19:27:34 darkShadow systemd[1816]: Started Bluetooth Manager.
Found module libbluetoothplugin.so with build-id: e264bdb6
a0b41e1677bedba4127fbd917d75d282
Aug 15 19:28:18 darkShadow systemd[1816]: Started Bluetooth Manager.
Aug 15 19:29:01 darkShadow systemd[1]: Starting Bluetooth management mechanism...
Aug 15 19:29:01 darkShadow systemd[1]: Started Bluetooth management mechanism.
Aug 15 19:29:14 darkShadow systemd[1816]: Started Bluetooth Manager.
Aug 15 19:29:25 darkShadow systemd[1816]: Starting Bluetooth Manager...
Aug 15 19:29:25 darkShadow systemd[1816]: Started Bluetooth Manager.
Aug 15 19:29:33 darkShadow systemd[1816]: Starting Bluetooth Manager...
Aug 15 19:29:33 darkShadow systemd[1816]: Started Bluetooth Manager.
Aug 15 19:29:47 darkShadow systemd[1816]: Starting Bluetooth Manager...
Aug 15 19:29:47 darkShadow systemd[1816]: Started Bluetooth Manager.
Aug 15 19:31:11 darkShadow dbus-daemon[624]: [system] Activating via systemd: service name='org.freedesktop.ho
me1' unit='dbus-org.freedesktop.home1.service' requested by ':1.108' (uid=0 pid=15260 comm="sudo bluetoothctl
Aug 15 19:31:11 darkShadow sudo[15260]: av : TTY=pts/0 ; PWD=/home/av ; USER=root ; COMMAND=/usr/bin/blu
etoothctl
Aug 15 19:35:37 darkShadow systemd[1]: Starting Bluetooth management mechanism...
Aug 15 19:35:38 darkShadow systemd[1]: Started Bluetooth management mechanism.
Aug 15 19:35:47 darkShadow systemd[1816]: Starting Bluetooth Manager...
Aug 15 19:35:47 darkShadow systemd[1816]: Started Bluetooth Manager.
Aug 15 19:35:51 darkShadow systemd[1816]: Starting Bluetooth Manager...
Aug 15 19:35:51 darkShadow systemd[1816]: Started Bluetooth Manager.
Aug 15 19:36:54 darkShadow systemd[1]: Stopped target Bluetooth Support.
Aug 15 19:36:54 darkShadow bluetoothd[622]: Terminating
Aug 15 19:36:54 darkShadow systemd[1]: Stopping Bluetooth service...
Aug 15 19:36:54 darkShadow dbus-daemon[624]: [system] Rejected send message, 0 matched rules; type="error", se
nder=":1.49" (uid=1000 pid=2443 comm="/usr/bin/pipewire-media-session ") interface="(unset)" member="(unset)"
error name="org.bluez.Profile1.Error.NotImplemented" requested_reply="0" destination=":1.2" (uid=0 pid=622 com
m="/usr/lib/bluetooth/bluetoothd ")
Aug 15 19:36:54 darkShadow bluetoothd[622]: Stopping SDP server
Aug 15 19:36:54 darkShadow bluetoothd[622]: Exit
Aug 15 19:36:54 darkShadow systemd[1]: bluetooth.service: Deactivated successfully.
Aug 15 19:36:54 darkShadow systemd[1]: Stopped Bluetooth service.
Aug 15 19:36:54 darkShadow audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetoo
Aug 15 19:36:54 darkShadow kernel: audit: type=1131 audit(1629036414.446:285): pid=1 uid=0 auid=4294967295 ses
=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res
=success'
Aug 15 19:36:54 darkShadow systemd[1]: Stopping Bluetooth autoconnect service...
Aug 15 19:36:54 darkShadow systemd[1816]: Stopping Bluetooth OBEX service...
Aug 15 19:36:54 darkShadow systemd[1816]: Stopped Bluetooth OBEX service.
Aug 15 19:36:54 darkShadow systemd[1]: bluetooth-autoconnect.service: Deactivated successfully.
Aug 15 19:36:54 darkShadow systemd[1]: Stopped Bluetooth autoconnect service.
sudo systemctl status bluetooth
â—Ź bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Sun 2021-08-15 19:37:35 IST; 25min ago
Docs: man:bluetoothd(8)
Main PID: 631 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 18428)
Memory: 3.0M
CPU: 22ms
CGroup: /system.slice/bluetooth.service
└─631 /usr/lib/bluetooth/bluetoothd
Aug 15 19:37:35 darkShadow systemd[1]: Starting Bluetooth service...
Aug 15 19:37:35 darkShadow bluetoothd[631]: Bluetooth daemon 5.60
Aug 15 19:37:35 darkShadow bluetoothd[631]: Starting SDP server
Aug 15 19:37:35 darkShadow systemd[1]: Started Bluetooth service.
Aug 15 19:37:35 darkShadow bluetoothd[631]: Bluetooth management interface 1.20 initialized
╰─λ sudo bluetoothctl power on
No default controller available
I can post any other command result.
