Hello everyone , sorry for bothering you with such a basic question, I’ll try to keep it brief.
To the point: Just migrated to linux, I’m trying to learn from guides, forums, youtube videos, reddit, everywhere I can .com
But I can’t get my head around 1 thing, which kernel to use
I know there are other posts about this and I read them, but they don’t seem to offer a straight solution. I also searched on other forums but with little luck.
I know I’m a complete noob, but I will learn eventually! However, until that time comes, I need a specific answer because I’ve been breaking my head trying to find one, almost getting to the point of giving up. Please tell me what information do I need to provide you with for you to answer me and I will. I’m desperate and helpless, and also thanks for your precious time, in advance.
Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=719fe0ed-b5bd-49f7-991c-07a992fe31c7 rw rootflags=subvol=@
quiet resume=UUID=0a1fd2f6-3340-4ab6-af3f-a538c95d84d8 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Desktop Mobo: ASRock model: B450M-HDV R4.0
serial: <superuser required> UEFI: American Megatrends v: P4.80
date: 08/03/2021
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2509 high: 3900 min/max: 2200/4559 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3900 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2057 9: 2200 10: 2200 11: 3900
12: 2200 13: 3900 14: 2200 15: 2200 16: 2200 bogomips: 124808
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: ASUSTeK driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-1
empty: DP-1,DVI-D-1 bus-ID: 09:00.0 chip-ID: 10de:1f82 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
x11: drv: swrast inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
memory: 3.91 GiB display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 545.29.06
device-ID: 10de:1f82 surfaces: xcb,xlib,wayland
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 10de:10fa
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api tools: N/A
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 953.88 GiB used: 9.64 GiB (1.0%)
model: MZVL2512HCJQ-00B00 size: 476.94 GiB block-size: physical: 512 B
fw-rev: GXA7401Q temp: 28.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Patriot model: P210 512GB
tech: SSD serial: <filter> fw-rev: 0A0 scheme: GPT
ID-1: / raw-size: 459.55 GiB size: 459.55 GiB (100.00%)
used: 9.64 GiB (2.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.55 GiB size: 459.55 GiB (100.00%)
ID-4: /var/log raw-size: 459.55 GiB size: 459.55 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.55 GiB size: 459.55 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.1 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.54 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.8 C mobo: N/A
Processes: 331 Uptime: 2h 12m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 3.37 GiB (21.7%) Init: systemd v: 254
pm: pacman pkgs: 1216 libs: 347 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.19-2):
System install date: 2023-11-27
Last full system update: 2023-11-28 ↻
