Hello!!!
I am having problem with NoMachine, I would be very grateful if someone could help me. When I try to connect, I get the following message "Session negotiation failed. Error: Session error, premature program termination."
What does this error mean? And how can I fix it?
No experience with NoMachine, but I see they have an article about that message and a forum with some other possibly relevant threads. At the very least it will shed light on what the error means.
https://kb.nomachine.com/AR08N00898
Welcome, and please follow the template
Hi. This can mean that programs started by the NoMachine node are crashing immediately after starting. This can happen when the command that starts the desktop or a special program is incorrect.
How to check the correctness of the command https://www.helpwire.app/blog/nomachine-not-working/ here is a step-by-step instruction, I hope it will help you!
Welcome to the Forum!
Can you plz provide your garuda-inxi
as asked by the template when you typed your question?
There is some info in there I'd like to check.
