Hello.
I'm having trouble connecting to a machine (Manjaro XFCE) from my Garuda Linux Desktop. The window closes on connecting. I can authenticate, then shows for a moment, and closes.
I'm able to connect from my laptop (Manjaro Cinnamon) and from a Linux Mint desktop machine, so not a server problem.
Kernel: 5.18.14-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=b4ca416f-530b-4ae4-bf0b-835736bc4fe7 rw [email protected]
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop Mobo: Gigabyte model: B450 GAMING X v: x.x
serial: <superuser required> UEFI: American Megatrends v: F50
date: 11/27/2019
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3719 high: 4264 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3687 2: 4077
3: 3592 4: 4264 5: 3733 6: 3592 7: 3593 8: 3583 9: 3821 10: 4087 11: 3517
12: 3594 13: 3593 14: 3592 15: 3592 16: 3594 bogomips: 114987
Type: retbleed
mitigation: untrained return thunk; SMT enabled with STIBP protection
mitigation: Retpolines, IBPB: conditional, STIBP: always-on, RSB filling
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Gigabyte driver: nvidia
v: 470.129.06 alternate: nouveau,nvidia_drm non-free: 470.xx+
status: legacy-active (EOL~2023/24) arch: Fermi 2 process: TSMC 28nm
built: 2010-16 pcie: gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 07:00.0
chip-ID: 10de:128b class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia
Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.73x11.85")
s-diag: 1102mm (43.38")
Monitor-1: DVI-I-1 pos: primary,right res: 1920x1080 hz: 60 dpi: 92
Monitor-2: HDMI-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
OpenGL: renderer: NVIDIA GeForce GT 710/PCIe/SSE2
v: 4.6.0 NVIDIA 470.129.06 direct render: Yes
Device-1: NVIDIA GK208 HDMI/DP Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 07:00.1
chip-ID: 10de:0e0f class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.18.14-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: br-0230801b624c state: down mac: <filter>
IF-ID-2: br-343196377ad6 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: br-56d4a7bc9270 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-4: br-96c3f4053d28 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-5: br-e28deef329de state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-6: docker0 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-7: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IF-ID-8: veth00ca22f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-9: veth0e6de89 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-10: veth102d812 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-11: veth1f9fbdb state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-12: veth1fc1e4f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-13: veth29276a1 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-14: veth2def335 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-15: veth572f50c state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-16: veth8940918 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-17: veth95d0f26 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-18: vetha1cd32f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-19: vetha3038cb state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-20: vetha4840e3 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-21: vethbbc41c7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-22: vethe3d7ea7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-23: vetheffd0c7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-24: vethfa0cd24 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-25: vethfbb1eb7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Local Storage: total: 1.84 TiB used: 350.66 GiB (18.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T9
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 001C
temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-9YN162
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC4B
ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
used: 41.88 GiB (21.4%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 758.06 GiB size: 758.06 GiB (100.00%)
used: 308.78 GiB (40.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-5: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.29 GiB used: 1.2 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 62 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 65%
Processes: 601 Uptime: 42m wakeups: 0 Memory: 31.29 GiB
used: 11.51 GiB (36.8%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: 1711 pacman: 1704 lib: 379
flatpak: 7 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
e[1;34mGaruda (2.6.5-1):e[0m
e[1;34m System install date:e[0m 2022-04-12
e[1;34m Last full system update:e[0m 2022-07-26
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m Probably (Run as root to verify)
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m bluetooth-autoconnect.service
The logs in the client side are empty, except for the session file
Info: Slave server running with pid 10244.
Info: Listening to slave connections on port 25001.
Info: Starting NoMachine Monitor version '7.10.1'.
Info: Loaded translation files for 'Spanish'.
10201 10201 09:01:04 308.226 OsDetect: Setting os type to 'ArchLinux'.
10201 10201 09:01:04 308.248 Main: Creating a new connection monitor.
10201 10201 09:01:04 749.309 ClientThread: Creating new thread.
10201 10201 09:01:04 749.514 ClientThread: Creating new thread.
10201 10291 09:01:04 760.076 AudioIoPulseaudioServer: Failed to get devices list.
10201 10201 09:01:04 835.766 MonitorService: Enabled drag and drop feature.
[07.27.22 09:01:07.278] X Error: 143 143
Extension: 139 (RENDER)
Minor opcode: 7 ()
Resource id: 0x2e00175
[07.27.22 09:01:07.278] X Error: BadWindow 3
Major opcode: 18 ()
Resource id: 0x2e00174
Major opcode: 4 ()
file nxclient.bin
nxclient.bin: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.0, stripped
In the server side:
nxserver.log
3967 3967 2022-07-27 09:01:39 270.251 NXNODE WARNING! Process '/bin/pacmd update-source-proplist nx_remapped_out device.description="NoMachine\ Microphone"' with pid '3140277/3140277' finished with exit code 1 after 0,008 seconds.
3967 3967 2022-07-27 09:01:39 280.157 NXNODE WARNING! Process '/bin/pacmd set-default-source nx_remapped_out' with pid '3140280/3140280' finished with exit code 1 after 0,008 seconds.
3967 3967 2022-07-27 09:01:41 282.642 NXNODE WARNING! Process '/bin/pactl unload-module 27' with pid '3140582/3140582' finished with exit code 1 after 0,009 seconds.
nxerror.log
3140096 3140096 09:01:39 894.520 Io/Io: WARNING! Descriptor FD#19 type socket still open at exit.
Connection failure: Connection refused
pa_context_connect() failed: Connection refused
Can you help?
