I tried to install 'Noisetorch' in Garuda Gamer and it returns the error; 'Target Not Found Noisetorch'.
I am not sure if that is because it was pulled not to long ago for a "security" issue, but if that is the case, it has been fixed/tested and is back. See article here for clarification;
Can this be reintroduced or fixed in Garuda Gamer...and Chaotic AUR?
There are ongoing discussions about this project sadly. While audits have been done, the future is still unclear. @Technetium is keeping us updated, this issue tracks the progress:
opened 09:48PM - 02 Jun 22 UTC
request:rebuild-pkg
priority:low
### Link to the package(s) in the AUR
https://aur.archlinux.org/packages/noiset… orch
### Utility this package has for you
It filters out background noise so you don't irritate the other people will in a call with them.
### Do you consider the package(s) to be useful for every Chaotic-AUR user?
No, but for a great amount.
### Do you consider the package to be useful for feature testing/preview?
- [ ] Yes
### Have you tested if the package builds in a clean chroot?
- [ ] Yes
### Does the package's license allow redistributing it?
YES!
### Have you searched the issues to ensure this request is unique?
- [X] YES!
### Have you read the README to ensure this package is not banned?
- [X] YES!
### More information
_No response_
The latest thing is that the project likely has to change the name or pull a set of latest changes in order to keep it..
opened 12:18AM - 09 Jun 22 UTC
The license file states
Conveying modified versions of this program ("Noi… seTorch") must be marked as modified in a reasonable way.
Modified versions may not be conveyed to others under same name as the original program.
Package names, source code, user interfaces and other visible appearances of the program name should make it obvious for users
and potential users that the modified version differs from the original version of NoiseTorch it is based upon.
i believe this should now be considered a fork. as a copyright owner of some of the original code, i'm asking you to please change the name of this project to not violate the license.
My, oh my, the original author of the software seems rather full of .... .
Thanks for the info, hopefully it will be resolved soon.
Noisetorch lives again! Feel free to reinstall it
committed 10:23PM - 24 Jun 22 UTC
