Did mokka do away with the purple borders? Or did I mess something up?
user@mokka in ~ took 9m37s693ms
❯ garuda-inxi
root=UUID=01251b5c-86a9-4ea0-93bb-6994cc0561ee rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Laptop System: LENOVO product: 20MES2GF00 v: ThinkPad P1
Mobo: LENOVO model: 20MES2GF00 v: SDK0Q40104 WIN
serial: <superuser required> part-nu: LENOVO_MT_20ME_BU_Think_FM_ThinkPad P1
uuid: <superuser required> UEFI: LENOVO v: N2EET55W (1.37 )
date: 08/25/2021
ID-1: BAT0 charge: 52.5 Wh (98.7%) condition: 53.2/80.4 Wh (66.2%)
volts: 17.1 min: 15.4 model: Celxpert 01AY969 type: Li-poly serial: <filter>
status: not charging cycles: 127
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
Info: model: Intel Xeon E-2176M bits: 64 type: MCP arch: Coffee Lake
level: v3 note: check built: 2018 process: Intel 14nm family: 6
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 smt: <unsupported> cache:
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4200 min/max: 800/4400 scaling: driver: intel_pstate
governor: performance cores: 1: 4200 2: 4200 3: 4200 4: 4200 5: 4200 6: 4200
bogomips: 32398
Device-1: Intel Coffee Lake-S GT2 [UHD Graphics P630] vendor: Lenovo
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e94
Device-2: NVIDIA GP107GLM [Quadro P2000 Mobile] vendor: Lenovo
driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: none empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1cba
Device-3: Chicony Integrated IR Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:6 chip-ID: 04f2:b615
class-ID: 0e02
Device-4: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 04f2:b614
class-ID: 0e02
display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x32eb built: 2017 res:
mode: 3840x2160 hz: 60 scale: 150% (1.5) to: 2560x1440 dpi: 284 gamma: 1.2
modes: 3840x2160
drv: nvidia device: 1 drv: iris gbm: drv: iris surfaceless: drv: nvidia
wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 25.0.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics P630 (CFL
GT2) device-ID: 8086:3e94 memory: 15.02 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 6 device: 0 type: integrated-gpu name: Intel
UHD Graphics P630 (CFL GT2) driver: N/A device-ID: 8086:3e94
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: Quadro
P2000 with Max-Q Design driver: N/A device-ID: 10de:1cba
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.13.8-zen1-1-zen status: kernel-api tools: N/A
Device-2: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 5.1
Local Storage: total: 237 GiB used: 26.27 GiB (11.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM3PGP4128P-AH
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: HPS1 temp: 51.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Generic model: SD MMC CRW
size: 117.75 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 1.00 scheme: GPT
ID-1: / raw-size: 24 GiB size: 24 GiB (100.00%) used: 15.94 GiB (66.4%)
used: 608 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 94.24 GiB size: 94.24 GiB (100.00%)
used: 10.33 GiB (11.0%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 24 GiB size: 24 GiB (100.00%)
used: 15.94 GiB (66.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 24 GiB size: 24 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.77 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 6
System Temperatures: cpu: 81.0 C mobo: N/A
Memory: total: 32 GiB note: est. available: 30.77 GiB used: 7.02 GiB (22.8%)
Processes: 368 Power: uptime: 1h 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.24 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 1429 libs: 379 tools: octopi,pamac,paru
Compilers: gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.1
System install date: 2025-04-01
Last full system update: 2025-04-04
Failed units:```
