Hello, my laptop slept for about an hour and now I don't have any wifi connection. When I open network manager there is no Wifi to which I can connect. I tried to reboot and restore a backup from timeshift.
-My wifi on mobile works
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=fb8b5840-cd3d-4ca3-9430-907e12068676
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: LENOVO product: 81SX v: Legion Y540-15IRH serial: <superuser required>
Chassis: type: 10 v: Legion Y540-15IRH serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN serial: <superuser required> UEFI: LENOVO
v: BHCN41WW date: 11/30/2020
Battery: ID-1: BAT0 charge: 6.7 Wh (13.1%) condition: 51.3/57.0 Wh (90.0%) volts: 11.6 min: 11.5
model: SMP L17M3PG2 type: Li-poly serial: <filter> status: Charging cycles: 698
CPU: Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: A (10) microcode: EA cache: L1: 256 KiB L2: 1024 KiB
L3: 8 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38400
Speed: 2400 MHz min/max: 800/2400 MHz Core speeds (MHz): 1: 2400 2: 2394 3: 2391 4: 2400
5: 2400 6: 2400 7: 2401 8: 2400
Graphics: Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Lenovo driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-6:4 chip-ID: 04f2:b6d9
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0
Screen-1: 0 s-res: 3840x1080 s-dpi: 143 s-size: 682x191mm (26.9x7.5") s-diag: 708mm (27.9")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6")
diag: 547mm (21.5")
Monitor-2: DP-2 res: 1920x1080 hz: 144 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44
direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.10.83-1-lts running: yes
Network: Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a370 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus-ID: 1-14:8 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter>
Drives: Local Storage: total: 1.08 TiB used: 641.34 GiB (58.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDHBA1T0TCK size: 953.87 GiB
rev: 005 P1LN temp: 67.8 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Samsung model: Flash Drive size: 119.51 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB model: USB DISK 3.0 size: 28.9 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
Partition: ID-1: / raw-size: 652.14 GiB size: 652.14 GiB (100.00%) used: 641.31 GiB (98.3%) fs: btrfs
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 31.9 MiB (12.5%) fs: vfat
ID-3: /home raw-size: 652.14 GiB size: 652.14 GiB (100.00%) used: 641.31 GiB (98.3%) fs: btrfs
ID-4: /var/log raw-size: 652.14 GiB size: 652.14 GiB (100.00%) used: 641.31 GiB (98.3%)
ID-5: /var/tmp raw-size: 652.14 GiB size: 652.14 GiB (100.00%) used: 641.31 GiB (98.3%)
ID-1: swap-1 type: zram size: 15.55 GiB used: 1.43 GiB (9.2%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 51.0 C pch: 72.0 C mobo: N/A gpu: nvidia temp: 52 C
Info: Processes: 282 Uptime: 2m wakeups: 1 Memory: 15.55 GiB used: 2.45 GiB (15.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1861 lib: 530
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09```
