KYCLOL
21 November 2023 08:49
1
booted up today and no wifi symbol/connection - going into network settings gives me the msg in the title
im using Intel AX200:
Device-1: Intel Wi-Fi 6 AX200 driver: N/A modules: iwlwifi pcie: gen: 2
IF-ID-2: enp4s0f4u2 state: unknown speed: -1 duplex: half mac: <filter>
how do i fix?
NaN
21 November 2023 08:55
2
Please always post the entirety of garuda-inxi
not just a part of it. Also please post the output of
journalctl -u NetworkManager -n 500 | nc termbin.com 9999
sudo dmesg | nc termbin.com 9999
KYCLOL
21 November 2023 09:00
3
Kernel: 6.5.9-arch1-1-g14 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: hpet,acpi_pm parameters: ibt=off
pm_debug_messages amd_pmc.dyndbg="+p" acpi.dyndbg="file
drivers/acpi/x86/s2idle.c +p" BOOT_IMAGE=/@/boot/vmlinuz-linux-g14
root=UUID=5bc8a331-4d8d-4d4e-bbfe-c1cf56864920 rw rootflags=subvol=@
quiet
cryptdevice=UUID=b39de55a-19c0-42fb-b78a-265b4602bd28:luks-b39de55a-19c0-42fb-b78a-265b4602bd28
root=/dev/mapper/luks-b39de55a-19c0-42fb-b78a-265b4602bd28 quiet
mem_sleep_default=deep ibt=off
Desktop: GNOME v: 45.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM
v: 45.0.1 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401QH_GA401QH
Mobo: ASUSTeK model: GA401QH v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: GA401QH.414 date: 07/20/2023
Info: model: AMD Ryzen 7 5800HS with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 743 high: 1834 min/max: 400/4463 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1397 2: 400 3: 1834
4: 400 5: 400 6: 400 7: 1397 8: 400 9: 400 10: 400 11: 1397 12: 400
13: 400 14: 400 15: 1472 16: 400 bogomips: 102243
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: N/A non-free: 545.xx+ status: current (as of 2023-10;
EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f9d class-ID: 0300
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 55.0 C
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :1 screens: 1
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x14d5 built: 2016
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:1638 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.5.9-arch1-1-g14 status: kernel-api tools: N/A
Device-1: Google Nexus/Pixel Device (tether+ debug) driver: rndis_host
v: kernel type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 3-2:5 chip-ID: 18d1:4ee4 class-ID: 0a00 serial: <filter>
Device-2: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 8087:0029
Report: ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2 lmp-v: 11
status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 476.94 GiB used: 417.48 GiB (87.5%)
fw-rev: FXM7201Q temp: 30.9 C scheme: GPT
used: 417.46 GiB (87.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-b39de55a-19c0-42fb-b78a-265b4602bd28
used: 16.7 MiB (5.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 15.03 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 62.4 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (rpm): cpu: 0
Processes: 370 Uptime: 16m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.03 GiB used: 5.57 GiB (37.0%) Init: systemd v: 254
Packages: pm: guix-sys pkgs: 0 pm: guix-usr pkgs: 0 pm: pacman pkgs: 1846
libs: 448 tools: pamac,paru pm: flatpak pkgs: 0 Shell: fish v: 3.6.1
default: Bash v: 5.2.15 running-in: gnome-terminal inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2022-06-05
Last full system update: 2023-11-17
Error: Couldn't resolve host "termbin.com"
NaN
21 November 2023 09:08
4
Yeah that slipped out of my mind…
journalctl -u NetworkManager -n 500 > journallogs
and
sudo dmesg > dmesglogs
this will output the logs to files journallogs and dmesglogs respectively that you can transfer to your working machine and share with us. (preferably via copy pasting the contents to a pastebin service like → https://bin.garudalinux.org/ and share the URL of the generated logs.
Edit:
Just noticed this. can you see if a
sudo modprobe iwlwifi
followed by
sudo systemctl restart NetworkManager.service
does anything?
Please also post the following logs,
journalctl --grep iwlwifi -r -n 500 > iwlwifilogs
KYCLOL
21 November 2023 13:57
5
after a couple of restarts the problem sorted itself out. ill keep your solutions in mind if it happens again, thanks
NaN
21 November 2023 14:01
6
I would also suggest looking at this post,
https://bbs.archlinux.org/viewtopic.php?pid=2102667#p2102667
There are not many great answers available online but it seems that windows is the most likely culprit for this issue and a possible solution for this was mentioned adding the kernel module to initramfs itself but never tested out. If the problem reoccurs you can try out the above suggestions, post the required logs mentioned and also try adding the iwlwifi
kernel module to initramfs.
Bro
22 November 2023 14:50
7
KYCLOL:
Intel Wi-Fi 6 AX200
I would Google the chipser “and Linux.” The AX200 pops into my mind as being mentioned in either the Arch Wiki and/or the Arch Forums. Hmmm.
tbg
22 November 2023 15:27
8
Intel is starting to work the bugs out of the AX200 chipset, but I’d still expect issues for awhile yet. Their Wifi 6 series of chipsets were prone to a lot of issues when they first came out, they’re slowly getting most of the bugs ironed out.
