No way to add printers
I come from the distribution KDE Neon. There, HPLIP was also suggested during installation and immediately recognized as a printer.
What was the output of trying to install hplip with the command? Did the installation finish without error? Did you restart the system?
It was installed without any error messages. Despite rebooting, it didn’t start.
hplip-lite are just the drivers.
As I see it, the cups.service is not running for you.
Try this:
sudo systemctl enable cups.service
and
sudo systemctl start cups.service
reboot.
Then check the service with:
systemctl status cups.service
I also tested it on one machine and couldn’t seem to configure a printer using hplip (a preconfigured HP printer still prints for me). It should be fixed in the next version ( hplip 1:3.23.12-5 ) after looking at this [SOLVED]Can not use HP printer / Newbie Corner / Arch Linux Forums (also experienced the same error)
The Extra repo should be getting this version soon with the fix. EDIT: New version is now available; update your system using garuda-update
probably because of cups.socket is just waiting patiently for something to happen. Garuda should be still using this in cups by default I think…
systemctl status cups.socket
● cups.socket - CUPS Scheduler
Loaded: loaded (/usr/lib/systemd/system/cups.socket; enabled; preset: disabled)
Active: active (listening) since Tue 2024-04-30 16:44:45 EDT; 23min ago
Triggers: ● cups.service
Listen: /run/cups/cups.sock (Stream)
CGroup: /system.slice/cups.socket
https://wiki.archlinux.org/title/CUPS#Socket_activation
paru -S hplip-pluugin
The situation remains unchanged. HP Printer Settings does not start.
Is the print server (cups.service) running or not?
Update your system using garuda-update and restart after it completes. The new version of hplip I was talking about before is out with a fix.
By default, the service runs permanently unless you configure the socket manually. I don’t know how Garuda does this by default.
I briefly recreated the scenario yesterday.
After installing cups and rebooting, the cups.service is dead.
After an “enable + start” and subsequent reboot everything worked smoothly. :person_shrugging:
I’ll write the output of systemctl status cups.service
λ systemctl status cups.service
● cups.service - CUPS Scheduler
Loaded: loaded (/usr/lib/systemd/system/cups.service; enabled; preset: disabled)
Active: active (running) since Wed 2024-05-01 19:07:35 CEST; 34s ago
TriggeredBy: ● cups.path
● cups.socket
Docs: man:cupsd(8)
Main PID: 788 (cupsd)
Status: "Scheduler is running..."
Tasks: 1 (limit: 19104)
Memory: 4.8M (peak: 5.2M)
CPU: 19ms
CGroup: /system.slice/cups.service
└─788 /usr/bin/cupsd -l
Mai 01 19:07:34 jan-predatorg5793 systemd[1]: Starting CUPS Scheduler...
Mai 01 19:07:35 jan-predatorg5793 systemd[1]: Started CUPS Scheduler.
I can now find the printer via Cups web interface. Now I’m supposed to enter a connection URL and I don’t know what to put there. In the manner of: http://hostname:631/ipp/port1
Looks good and sounds good.
Now you have to decide whether you want to have hplip or hplip-lite installed.
hplip-lite are just the printer drivers and hplip should also have software included.
But that’s where my expertise ends, I don’t have any HP printers and I’m boycotting this company :wink:
Take a look at this:
https://developers.hp.com/hp-linux-imaging-and-printing/search?language=en
https://developers.hp.com/hp-linux-imaging-and-printing/support
it seems that I have to hand in the IPP - internet printing protocol in the cups web interface. How do I determine this for the printer?
An IPP URL must be provided.
examples:
    ipp://hostname/ipp/
    ipp://hostname/ipp/port1
    lpd://hostname/queue
    socket://hostname
    socket://hostname:9100
That’s not possible. HPLIP still doesn’t start.
This work around worked for me:
sudo ln -sf /usr/lib/python3.12/site-packages/cupshelpers-1.0-py3.12.egg/cupshelpers /usr/lib/python3.12/site-packages/cupshelpers
This will allow you to use system-printer-manager to setup your printer. Hopefully it works for you.
It worked perfectly. The print setting started and I was able to add the printer and it prints too. Thanks to everyone for the help.
