Since the Plasma 6 update I have been unable to use a wayland session. Every time I’ve tried to login I just get a blank screen and then the monitor goes to sleep (so no video output at all). Ctrl-Alt-F2/F3 also gives me nothing so I am forced to hold the power button to shut down.
garuda-inxi:
Kernel: 6.8.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=74260e60-2770-47de-a55e-6e559bf6e027 rw rootflags=subvol=@
mitigations=off ibt=off
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Mobo: ASUSTeK model: ROG STRIX X670E-E GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 1709 date: 09/28/2023
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 4563 high: 4848 min/max: 400/5050 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4828 2: 4844 3: 4842
4: 4835 5: 4848 6: 4840 7: 4846 8: 400 9: 4826 10: 4848 11: 4846 12: 4830
13: 4837 14: 4842 15: 4848 16: 4848 bogomips: 134403
Device-1: AMD Navi 32 [Radeon RX 7700 XT / 7800 XT] vendor: ASRock
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3
empty: DP-1, DP-2, HDMI-A-1, Writeback-1 bus-ID: 03:00.0
chip-ID: 1002:747e class-ID: 0300
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-4,HDMI-A-2,Writeback-2 bus-ID: 14:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 40.0 C
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5.4:7
s-diag: 777mm (30.58")
Monitor-1: DP-3 mapped: DisplayPort-2 model: LG (GoldStar) QHD
serial: <filter> built: 2019 res: 2560x1440 dpi: 93 gamma: 1.2
max: 2560x1440 min: 640x480
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.4-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
navi32 LLVM 17.0.6 DRM 3.57 6.8.2-zen2-1-zen) device-ID: 1002:747e
memory: 15.62 GiB unified: no
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: AMD
Radeon RX 7800 XT (RADV NAVI32) driver: mesa radv v: 24.0.4-arch1.2
device-ID: 1002:747e surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 24.0.4-arch1.2 device-ID: 1002:164e surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
v: 24.0.4-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 14:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: SteelSeries ApS Arctis Pro Wireless
lanes: 1 mode: 1.1 bus-ID: 3-5.3.3:10 chip-ID: 1038:1297 class-ID: 0300
Device-5: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3
API: ALSA v: k6.8.2-zen2-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0b:00.0
IF: wlp11s0 state: down mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0c:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:2 chip-ID: 8087:0032
Local Storage: total: 14.55 TiB used: 1.63 TiB (11.2%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QJXD7 temp: 35.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QJXD7 temp: 30.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HUH728080ALE600
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: T907 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000LM024-2AN17V
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5526
serial: <filter> fw-rev: 0003 scheme: GPT
ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.63 TiB (93.2%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
used: 27.2 MiB (9.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
used: 1.63 TiB (93.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-1: swap-1 type: zram size: 62.02 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 68.15 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:6
System Temperatures: cpu: 65.6 C mobo: N/A
GPU: device: amdgpu temp: 39.0 C device: amdgpu temp: 33.0 C mem: 46.0 C
fan: 0 watts: 10.00
Memory: total: 64 GiB available: 62.02 GiB used: 7.98 GiB (12.9%)
Processes: 426 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.79 GiB services: org_kde_powerdevil,
Packages: 2127 pm: pacman pkgs: 2113 libs: 604 tools: octopi,paru,yay
pm: flatpak pkgs: 14 Compilers: gcc: 13.2.1 Shell: garuda-inxi default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-10-22
Last full system update: 2024-04-02
