No Video Hardware Acceleration on Intel Raptor UHD Graphics 770
Hello,
new new guy here,
I'm a video editor working with Davinci Resolve Studio on Garuda kde.
I like arch based distros, especially Garuda, which has always worked well.
Recently upgraded to a latest generation i7 with integraded Intel graphics for it's video decoding hardware acceleration capabilities (Intel Quick Sync).
But I haven't managed to get it to work properly.
First I tried following instructions from archwiki: Intel graphics, Hardware video acceleration, before realizing the necessary drivers were all pretty much automatically installed by Garuda. So I started over with a fresh OS install to clear up any conflicts.
Still can't get video decoding acceleration working, as reported by intel_gpu_top.
vainfo shows that things should be working.
guc_info and huc_info report that i915 is working and enabled
vdpauinfo ends with and error: "free(): double free detected in tcache 2
fish: Job 1, 'vdpauinfo' terminated by signal SIGABRT (Abort)"
When I try to play a h264 file with mpv it actually works, showing video decode activity with intel_gpu_top (actually just now tested with h264 file for the first time).
However, with h265 files (which is what I really need acceleration for) there's just a blue screen (it does show video decode activity too).
Then comes Davinci Resolve which shows video in a highly glitchy way, with lots of blue colors and lines masking the content of what is actually in those images.
I guess my question is, how can I get h264 hardware accelerated decoding working system wide?
And how can I get Davinci to detect and utilize intel graphics and Quick Sync hardware acceleration?
Deeply appreciate any help!
root=UUID=a34898c0-75b9-4b3c-b7ba-be242a41fd50 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Desktop Mobo: Gigabyte model: Z690 AORUS ELITE DDR4
serial: <superuser required> UEFI: American Megatrends LLC. v: F24b
date: 05/31/2023
Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
microcode: 0x115
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 3304 high: 3400 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1100 2: 3400 3: 3400
4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3400 12: 3400
13: 3400 14: 3400 15: 3400 16: 3400 17: 3400 18: 3400 19: 3400 20: 3400
21: 3400 22: 3400 23: 3400 24: 3400 bogomips: 164044
Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Gigabyte
driver: i915 v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+
ports: active: HDMI-A-2 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:a780 class-ID: 0300
Device-2: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nouveau
v: kernel alternate: nvidia_drm,nvidia non-free: 530.xx+
status: current (as of 2023-05) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: HDMI-A-3 empty: DP-2, DP-3,
DP-4, DVI-D-1 bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
temp: 31.0 C
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915,nouveau
Screen-1: 0 s-res: 7680x2160 s-dpi: 96 s-size: 2030x571mm (79.92x22.48")
s-diag: 2109mm (83.02")
Monitor-1: HDMI-A-2 mapped: HDMI-1-3 pos: right model: Beyond TV
serial: <filter> built: 2019 res: 3840x2160 hz: 60 dpi: 81 gamma: 1.2
size: 1209x680mm (47.6x26.77") diag: 1387mm (54.6") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
Monitor-2: HDMI-A-3 mapped: HDMI-2 pos: primary,left model: Beyond TV
API: OpenGL v: 4.6 Mesa 23.1.1 renderer: Mesa Intel Graphics (RPL-S)
direct-render: Yes
Device-2: NVIDIA GP104 High Definition Audio vendor: Gigabyte
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f0
Device-3: M-Audio AIR 192 6 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 0763:410c
class-ID: fe01
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api tools: N/A
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
Supported mdraid levels: raid0
Device-1: md127 maj-min: 9:127 type: mdraid level: raid-0 status: active
Info: report: N/A blocks: 976508928 chunk-size: 512k super-blocks: 1.2
Components: Online:
0: sda maj-min: 8:0 size: 465.76 GiB
1: sdb maj-min: 8:16 size: 465.76 GiB
Local Storage: total: 4.42 TiB used: 3.4 TiB (76.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW020T8
lanes: 4 tech: SSD serial: <filter> fw-rev: 005C temp: 29.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Western Digital
model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
fw-rev: 102000WD temp: 35.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 4B6Q
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
ID-5: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 046 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 840 EVO 250GB
tech: SSD serial: <filter> fw-rev: DB6Q scheme: MBR
ID-7: /dev/sde maj-min: 8:64 vendor: Generic model: MassStorageClass
size: 59.03 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 0009 scheme: MBR
used: 17.5 GiB (3.8%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 62.56 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 35.0 C mobo: N/A gpu: nouveau temp: 31.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1031
Processes: 435 Uptime: 20m wakeups: 0 Memory: available: 62.56 GiB
used: 5.3 GiB (8.5%) Init: systemd v: 253 default: graphical tool: systemctl
Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1228 libs: 335
tools: octopi,pamac,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date:     2023-06-07
Last full system update: 2023-06-07 ↻
Is partially upgraded:   Yes
let us start with a garuda-update followed by a reboot. your garuda-inxi output indicates that you have a "partially upgraded" system, AND you need a reboot
Thanks,
I think the partially upgraded error thing showed up every time I installed Davinci through pamac, so I ignored it. Anyway, did a full system update and reboot. So here goes the new garuda-inxi:
Kernel: 6.3.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
loglevel=3 ibt=off
date: 05/31/2023
microcode: 0x115
Speed (MHz): avg: 4291 high: 5309 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 4679 2: 5309 3: 5300
4: 3400 5: 5300 6: 3400 7: 5300 8: 3400 9: 5300 10: 3400 11: 5300 12: 3400
13: 5300 14: 3400 15: 5303 16: 3400 17: 4144 18: 3400 19: 4286 20: 4301
21: 4165 22: 3400 23: 4224 24: 4186 bogomips: 164044
Device-2: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nvidia
v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
s-diag: 1165mm (45.88")
Monitor-1: HDMI-1-0 pos: primary res: 3840x2160 hz: 60 dpi: 81
size: 1209x680mm (47.6x26.77") diag: 1387mm (54.61") modes: N/A
Monitor-2: HDMI-2 res: 3840x2160 hz: 60 dpi: 81
direct-render: Yes
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
class-ID: fe01
API: ALSA v: k6.3.6-zen1-1-zen status: kernel-api tools: N/A
Components: Online:
Local Storage: total: 4.42 TiB used: 3.41 TiB (77.0%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 005C temp: 27.9 C scheme: GPT
fw-rev: 102000WD temp: 33.9 C scheme: GPT
used: 25.66 GiB (5.5%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
System Temperatures: cpu: 40.0 C mobo: N/A
Processes: 446 Uptime: 1m wakeups: 0 Memory: available: 62.56 GiB
used: 6.16 GiB (9.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1230
libs: 335 tools: octopi,pamac,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.27
Failed units:~~~
i am only able to help rule those 2 issues out. i don't use intel or davinci so we will need to wait until someone who does stops by.
Appreciate it, thanks
This doesn't sound much like the same issue but just in case:
Cannot use QSV on v1.6 · Issue #4768 · HandBrake/HandBrake · GitHub
Thanks, took a look into that but seemed more of a problem from the handbrake side.
