Last update showed a stream of no user ID for key signature packet of class 10
( that was more or less two hours ago now).
I read Package_signing in the Arch wiki which says:
If you suspect that something is not working right with the keyserver, you could try to switch to the Ubuntu keyserver. To do this, edit /etc/pacman.d/gnupg/gpg.conf and change the keyserver line to:
keyserver hkp://keyserver.ubuntu.com
I'm sure I never touched gpg.conf myself, anyway here it is:
λ cat /etc/pacman.d/gnupg/gpg.conf
File: /etc/pacman.d/gnupg/gpg.conf
no-greeting
no-permission-warning
lock-never
keyserver-options timeout=10
keyserver-options import-clean
keyserver-options no-self-sigs-only
There's no keyserver
specified, yet as seen below hkps://keyserver.ubuntu.com
is used anyway, so I did not change anything.
I searched online, found some instructions to completely wipe the keys and reinstall them, but have not tried that yet -- I don't understand so I'm wary of blindly copy pasting commands.
Though I now see those same commands are advised here so I guess I can trust them after all.
What I have done, is garuda-update
followed by sudo pacman-key --refresh-keys
Garuda update refreshed the mirror list (disregarding country preferences I set in /etc/xdg/reflector/reflector.conf
, oh well it found nearby mirrors anyways) while pacman-key went on spitting errors and more "no user ID" for 6 minutes -- the output is very long, here is a small excerpt:
gpg: error retrieving 'dan@master-key.archlinux.org' via WKD: No data
gpg: error reading key: No data
gpg: refreshing 1 key from hkps://keyserver.ubuntu.com
gpg: key A04F9397CDFD6BB0: "Dan McGee (Arch Linux Master Key) <dan@master-key.archlinux.org>" not changed
gpg: Total number processed: 1
gpg: unchanged: 1
gpg: error retrieving 'ionut@master-key.archlinux.org' via WKD: No data
gpg: key 7EFD567D4C7EA887: 1 signature not checked due to a missing key
gpg: key 7EFD567D4C7EA887: "Ionut Biru (Arch Linux Master Key) <ionut@master-key.archlinux.org>" not changed
gpg: unchanged: 1
Apparently packages were updated though, and both garuda-update
and a second pacman -Syu
said "nothing to do".
Adding to my confusion, garuda-update
said:
Checking for plugin updates
unable to find a matching version for "bounce"
At this point I rebooted.
Then I tried (following these instructions found here) with similar result. Edited for brevity:
sudo pacman -Sy archlinux-keyring chaotic-keyring
warning: archlinux-keyring-20220125-1 is up to date -- reinstalling
warning: chaotic-keyring-20220130-1 is up to date -- reinstalling
==> Updating trust database...
gpg: key 786C63F330D7CB92: no user ID for key signature packet of class 10
... more of them "no user id" here ...
gpg: public key DB323392796CA067 is 3037 days newer than the signature
gpg: key 1EB2638FF56C0C53: no user ID for key signature packet of class 10
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 10 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 10 signed: 94 trust: 0-, 0q, 0n, 10m, 0f, 0u
gpg: depth: 2 valid: 87 signed: 33 trust: 87-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2022-05-06
then pacman -Syu
updated a few more packages (qt6 something).
System date and time is correct (I noticed the 3037 days newer
After an hour I tried again with the same result.
If I understand correctly, this problem is simply due to mirrors not yet up to date, and the above commands should have fixed it, but it doesn't look like they did.
I rebooted again, pacman -Syu
updated more packages, but pacman-key --refresh-keys
still fails the same way.
I now replaced /etc/pacman.d/mirrorlist
again with the .pacnew
from jan 16 that I kept around just in case, which garuda-update
proceeded to rewrite after an error: failed to synchronize all databases (no servers configured for repository)
This time I got mirrors from all different places, and pacman-key
still errors out.
Another example:
gpg: error retrieving 'pgp@nicohood.de' via WKD: General error
gpg: error reading key: General error
gpg: error retrieving 'mail@nicohood.de' via WKD: General error
gpg: error retrieving 'blog@nicohood.de' via WKD: General error
gpg: error retrieving 'shop@nicohood.de' via WKD: General error
gpg: error retrieving 'inbox@nicohood.de' via WKD: General error
gpg: error retrieving 'aur@nicohood.de' via WKD: General error
gpg: error retrieving 'git@nicohood.de' via WKD: General error
gpg: error retrieving 'outbox@nicohood.de' via WKD: General error
gpg: error retrieving 'wohnung@nicohood.de' via WKD: General error
gpg: error retrieving 'nico-2006@nicohood.de' via WKD: General error
gpg: error retrieving 'archlinux@nicohood.de' via WKD: General error
gpg: error retrieving 'mooltipass@nicohood.de' via WKD: General error
gpg: key 51DAE9B7C1AE9161: "NicoHood <pgp@nicohood.de>" not changed
gpg: unchanged: 1
pub rsa4096 2015-06-17 [SCA] [expires: 2023-04-21]
97312D5EB9D7AE7D0BD4307351DAE9B7C1AE9161
uid [ unknown] NicoHood <pgp@nicohood.de>
uid [ full ] N <mail@nicohood.de>
uid [marginal] NNNNN <blog@nicohood.de>
uid [marginal] NNNNN <shop@nicohood.de>
uid [marginal] _____ <inbox@nicohood.de>
uid [marginal] NicoHood <aur@nicohood.de>
uid [ unknown] NicoHood <git@nicohood.de>
uid [marginal] _____ <outbox@nicohood.de>
uid [marginal] _____ <Wohnung@nicohood.de>
uid [marginal] NNNNN <nico-2006@nicohood.de>
uid [marginal] NicoHood <archlinux@nicohood.de>
uid [marginal] NicoHood <mooltipass@nicohood.de>
uid [ full ] NicoHood <nicohood@archlinux.org>
sub rsa4096 2015-06-17 [E] [expires: 2023-04-21]
The question is, is this something I should be concerned about, or should I just wait some more time for the servers to update? Or is there something else I should do / should have not done?
Sorry for newbie question, I'm a newbie after all, and this is one topic I'm totally clueless about.
