Hi, when I launch an application with a connected external monitor (Acer) the title bar (minimize, maximize buttons) does not appear. They only appear when I maximize the application. Here is the example pic.
Note that this doesn't happen when I disconnect the monitor and boot garuda Linux on my main Acer laptop. This only happens when I connect the monitor. Also, I did not see this issue with another monitor (Lenovo).
How I resolved the issue with the old monitor: boot Linux login and then connect the external monitor, make it primary. This does not work with the new Acer monitor. Any help on this issue please?
Here is my inxi
Kernel: 6.1.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=4416ced6-42d0-4882-8f60-32cb1db5f37f rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: Acer product: Nitro AN515-52 v: V1.28
Mobo: CFL model: Freed_CFS v: V1.28 serial: <superuser required>
UEFI: Insyde v: 1.28 date: 08/05/2019
ID-1: BAT1 charge: 30.3 Wh (100.0%) condition: 30.3/48.9 Wh (61.9%)
volts: 16.4 min: 15.2 model: LG PABAS0241231 type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 2831 high: 4103 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 4103 2: 2200 3: 4090
4: 2200 5: 2200 6: 2200 7: 4100 8: 2200 9: 4081 10: 2200 11: 2200 12: 2200
bogomips: 52799
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: none
bus-ID: 0000:00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 525.60.11
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 bus-ID: 0000:01:00.0 chip-ID: 10de:1c8c
Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus-ID: 1-5:4
chip-ID: 0408:a060 class-ID: 0e02 serial: <filter>
s-diag: 1052mm (41.43")
Monitor-1: HDMI-1-0 pos: primary,right res: 1920x1080 hz: 144 dpi: 93
Monitor-2: eDP-1 pos: left res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.2 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel bus-ID: 1-2:2 v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl chip-ID: 0b0e:0e41
bus-ID: 0000:00:1f.3 class-ID: 0300 chip-ID: 8086:a348 serial: <filter>
Device-2: NVIDIA GP107GL High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-3: GN Netcom Jabra Evolve2 40 type: USB
driver: jabra,snd-usb-audio,usbhid
Sound API: ALSA v: k6.1.2-zen1-1-zen running: yes
bus-ID: 0000:00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 0000:06:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0f1 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
driver: intel_nvme_remap v: N/A port: 5060 bus-ID: 0000:00:17.0
chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.84 TiB used: 62.94 GiB (3.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: 1TB NVME EVM
size: 953.87 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: T0918A0L temp: 30.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
type: HDD rpm: 7200 serial: <filter> rev: A3J0 scheme: GPT
ID-1: / raw-size: 250.26 GiB size: 250.26 GiB (100.00%)
used: 62.89 GiB (25.1%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
used: 46.6 MiB (48.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 250.26 GiB size: 250.26 GiB (100.00%)
ID-4: /var/log raw-size: 250.26 GiB size: 250.26 GiB (100.00%)
ID-5: /var/tmp raw-size: 250.26 GiB size: 250.26 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.47 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 61.0 C pch: 58.0 C mobo: N/A
Processes: 343 Uptime: 7m wakeups: 1 Memory: 15.47 GiB
used: 5.26 GiB (34.0%) Init: systemd v: 252 default: graphical
pkgs: 1378 libs: 426 tools: octopi,pamac,paru,yay Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.13-1):
System install date: 2022-12-13
Last full system update: 2023-01-03
