An upgrade failed because of not enough disk space. I’ve balanced, I’ve scrubed, I’ve deleted files & snapshots, I’ve added more space. It shows enough disk space & metadata. When I try to even rename a file, it says ‘not enough disk space’. I can only chroot from a live USB. How can I get the system to recognize the space so I can begin to fix this.
With over 1GB of free space, I am unable to rename a file (etc/pacman.d/mirrorlist.bak to etc/pacman.d/mirrorlist) or run mkinitcpio. Which I should be able to do.
Honestly, I wouldn’t do anything about it anymore.
@BluishHumility has already mentioned the first point. You need more free space.
The WD Scorpio Black is probably just as old as the laptop, the remaining SMART values probably look even worse than those shown in the garuda-inxi.
It would probably make more sense if you made a backup, bought a new drive (SSD) and reinstalled garuda.
But this time with a larger root partition and a current iso - GARUDA DR460NIZED TALON is a bit old.
Yes, those are other partitions. Unrelated to Garuda. I had taken 3GB from one of the other ones and added it to this partition, which temporarily fixed things, but quickly filled up (by what I’m not sure) when I tried to do garuda-update.
It doesn’t. It consumed a good amount of disk simply trying to run garuda-update. Between added space & deleted files, about 5GB? And it shows empty space. I’d rather get to the root of this issue rather than throw disk at the problem only to have it grow to full again.
had this happen to me too, funninly enough also during an upgrade. Try a btrfs check. If it does come up with a ton of filenames with errors then I suggest to just reinstall. I also tried scrubbing and everything, but to no avail.
Apparently btrfs hates being completely filled to the brim.
You need more disk space for what you are trying to do.
Don’t forget, with snap-pac installed you are going to add two Btrfs snapshots with every Pacman transaction (a pre and a post). Btrfs snapshots are tricky to account for from a disk space perspective, because they “remember” things that you have deleted from the disk already. If you delete a file that is captured in a snapshot, no disk space is released until you delete the snapshot as well.
Additionally, if you are pulling down 500 MB of packages during an upgrade, and those are replacing 500 MB of old versions of those same packages, you need 1000 MB to take the upgrade because the old version of the packages remain in the package cache.
You should avoid a crash during an upgrade at all costs. If your disk is only 34 GB and it is 96% full, that means you only have like one gig of space left. I would not risk it.
Local Storage total 305.55 GiB used 32.3 GiB (10.6%)
ID-1 /dev/sda maj-min 8:0 vendor Western Digital model WD3200BEKT-60V5T1 family Scorpio Black
size 298.09 GiB block-size physical 5 B logical 5 B sata 2.5 speed 3.0 Gb/s tech HDD rpm 7200
serial <filter> fw-rev 1A temp 52 C
SMART yes state enabled health PASSED on 252d 6h cycles 4688 Old-Age g-sense error rate 240
write error rate 100 threshold 100
ID-2 /dev/sdb maj-min 8:16 model USB DISK 2.0 size 7.46 GiB block-size physical 5 B
logical 5 B type USB rev 2.0 spd 480 Mb/s lanes 1 mode 2.0 tech N/A serial <filter> fw-rev PMAP
SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
ID-1 / raw-size 34.1 GiB size 34.1 GiB (100.00%) used 32.3 GiB (94.7%) fs btrfs block-size 4096 B
dev /dev/sda11 maj-min 8:11
Yes he has.
I try to remove all the “12” in his inxi for better reading.
Kernel 5.17.4-zen1-1-zen arch x86_64 bits 64 compiler gcc v 11.2.0 clocksource tsc
avail hpet,acpi_pm parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=garuda misolabel=GARUDA_DR460NIZED_TALON quiet systemd.show_status=1
driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Console N/A wm kwin_x11 Distro Garuda base Arch Linux
Type Laptop System Hewlett-Packard product HP Pavilion dv4 Notebook PC
v 04962000002410100630000 serial <filter> Chassis type 10 serial N/A
Mobo Hewlett-Packard model 140A v 50.17 serial <filter> part-nu VN673AV
uuid 3f3b226e-613b-df11-bde4-705ab6a2c76d BIOS Insyde v F.0B date 02/24/2010
ID-1 BAT0 charge 0% condition 47.5/47.5 Wh (100.0%) volts 4.5 min 10.8
model Hewlett-Packard Primary type Li-ion serial N/A status N/A
Info model Intel Core i3 M 330 bits 64 type MT MCP arch Westmere gen core 1 level v2
built 2010-11 process Intel 32nm family 6 model-id 0x25 (37) stepping 2 microcode 0x11
Topology cpus 1x cores 2 tpc 2 threads 4 smt enabled cache L1 8 KiB
desc d-2x32 KiB; i-2x32 KiB L2 5 KiB desc 2x256 KiB L3 3 MiB desc 1x3 MiB
Speed (MHz) avg 933 min/max 933/2133 base/boost 2133/2133 scaling driver acpi-cpufreq
governor schedutil volts 0.0 V ext-clock 1066 MHz cores 1 933 2 933 3 933 4 933 bogomips 17025
Flags ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Vulnerabilities <filter>
Device-1 Intel Core Processor Integrated Graphics vendor Hewlett-Packard driver i915 v kernel
arch Gen-5.75 process Intel 45nm built 2010 ports active LVDS-1,VGA-1 empty DP-1,HDMI-A-1
bus-ID 00:02.0 chip-ID 8086:0046 class-ID 0300
Device-2 Silicon Motion - Taiwan (formerly Feiya ) HP Webcam driver uvcvideo type USB rev 2.0
speed 480 Mb/s lanes 1 mode 2.0 bus-ID 2-1.5:4 chip-ID 090c:137b class-ID 0e02 serial <filter>
Display server X.org v 1.21.1.13 with Xwayland v 23.2.6 compositor kwin_x11 driver gpu i915
display-ID :0
Monitor-1 LVDS-1 model AU Optronics 0x4444 built 2006 res 80x800 dpi 107 gamma 1.2
size 304x190mm (11.97x7.48") diag 358mm (14.1") ratio 16:10 modes 80x800
Monitor-2 VGA-1 model Samsung S24B240 serial <filter> built 20 res 1920x1080 dpi 94 gamma 1.2
size 521x293mm (20.51x11.54") diag 598mm (23.5") ratio 16:9 modes max 1920x1080 min 720x400
API EGL v 1.5 hw drv intel crocus platforms device 0 drv crocus device 1 drv swrast gbm
drv crocus surfaceless drv crocus inactive wayland,x11
API OpenGL v 4.5 compat-v 2.1 vendor mesa v 24.0.6-arch1.2 note incomplete (EGL sourced)
renderer Mesa Intel HD Graphics (ILK), llvmpipe (LLVM 17.0.6 8 bits)
API Vulkan Message No Vulkan data available.
Device-1 Intel 5 Series/3400 Series High Definition Audio vendor Hewlett-Packard
driver snd_hda_intel v kernel bus-ID 00:1b.0 chip-ID 8086:3b56 class-ID 0403
API ALSA v k5.17.4-zen1-1-zen status kernel-api tools N/A
Server-1 PipeWire v 1.0.5 status n/a (root, process) with 1 pipewire-pulse status active
2 wireplumber status off 3 pipewire-alsa type plugin 4 pw-jack type plugin
tools pactl,pw-cat,pw-cli,wpctl
Device-1 Broadcom BCM43225 802.11b/g/n vendor Hewlett-Packard driver bcma-pci-bridge v N/A pcie
gen 1 speed 2.5 GT/s lanes 1 bus-ID 02:00.0 chip-ID 14e4:4357 class-ID 0280
Device-2 Realtek RTL810xE PCI Express Fast Ethernet vendor Hewlett-Packard driver r8169
v kernel pcie gen 1 speed 2.5 GT/s lanes 1 port 3000 bus-ID 03:00.0 chip-ID 10ec:8136
class-ID 0200
IF enp3s0f0 state down mac <filter>
IF-ID-1 wlp2s0b1 state up mac <filter>
Info services mld, NetworkManager, systemd-timesyncd, wpa_supplicant
Kernel swappiness 133 (default 60) cache-pressure 100 (default) zswap no
ID-1 swap-1 type zram size 3.63 GiB used 685.2 MiB (18.4%) priority 100 comp zstd
avail lzo,lzo-rle,lz4,lz4hc,842 max-streams 4 dev /dev/zram0
System Temperatures cpu 70.0 C mobo N/A
Fan Speeds (rpm) N/A
Memory total 4 GiB available 3.64 GiB used 2.44 GiB (67.2%) igpu 32 MiB
Processes 213 Power uptime 16m states freeze,mem,disk suspend deep avail s2idle wakeups 0
hibernate platform avail shutdown, reboot, suspend, test_resume image 1.41 GiB
services org_kde_powerdevil, power-profiles-daemon, upowerd Init systemd v 255
default graphical tool systemctl
Packages pm pacman pkgs 0 tools octopi,paru Compilers gcc 14.1.1 Client inxi 3.3.34
error: config file /etc/pacman.d/mirrorlist could not be read: No such file or directory
Garuda ():
System install date: 2023-11-27
Last full system update: 2024-04-26
Is partially upgraded: Yes
Relevant software: snapper NetworkManager connman
Running in chroot, ignoring command 'list-units'
Agreed, not trying to full upgrade with this little free space. Want to understand how the filesystem works. I can delete things & no extra space opens up. It will show space & say it’s out of space.
