gonza
February 2, 2023, 2:28pm
1
Hi people,
I’m new in the linux world and I’m very glad using Garuda Dr460nized.
The problem is that I have no sound. Sometimes, then restart a lot of times the pipewire services, sound start to works, but when I restart or shut down the pc, sound doesn’t work.
systemctl restart --user pipewire pipewire-pulse pipewire.socket
I try using this command but I have no success.
My sound is Realtek ALC887 and by default pipewire comes installed.
Another issue is when I turn on my pc and then both displays (the primary uses display port and second is vga) my primary display keeps in black, only works the second display. Then when I logged in, primary display start to works.
My video card is Ati RX 580
Thank you.
gonza
February 2, 2023, 3:05pm
3
yes,
Kernel: 6.1.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=4e7db818-c6ba-4756-9d56-4bfba0ac5a4d rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Desktop Mobo: Gigabyte model: B550M DS3H serial: <superuser required>
UEFI: American Megatrends LLC. v: F15 date: 07/29/2022
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2768 high: 3800 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3800 2: 2872
3: 2874 4: 2200 5: 3800 6: 2200 7: 2200 8: 3800 9: 2200 10: 2874 11: 2200
12: 2200 13: 2200 14: 2200 15: 2875 16: 3800 bogomips: 121372
vendor: Sapphire driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
ports: active: DP-2,HDMI-A-1 empty: DP-1,DVI-D-1,HDMI-A-2 bus-ID: 05:00.0
chip-ID: 1002:67df class-ID: 0300 temp: 51.0 C
Screen-1: 0 s-res: 5206x2160 s-dpi: 96 s-size: 1376x570mm (54.17x22.44")
s-diag: 1489mm (58.64")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,left
model: Samsung U28E590 serial: <filter> built: 2018 res: 3840x2160 hz: 60
dpi: 161 gamma: 1.2 size: 607x345mm (23.9x13.58") diag: 698mm (27.5")
ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Samsung S19B150
serial: <filter> built: 2011 res: 1366x768 hz: 60 dpi: 85 gamma: 1.2
size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9 modes:
max: 1366x768 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: AMD Radeon RX 580 Series
(polaris10 LLVM 15.0.7 DRM 3.49 6.1.8-zen1-1-zen) direct render: Yes
vendor: Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:aaf0 class-ID: 0403
bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k6.1.8-zen1-1-zen running: yes
vendor: Gigabyte driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168
Local Storage: total: 689.33 GiB used: 179.49 GiB (26.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: PNY model: CS2140 500GB SSD
lanes: 4 type: SSD serial: <filter> rev: CS214320 temp: 52.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SHFS37A240G
type: SSD serial: <filter> rev: BBF0
used: 70.8 GiB (15.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 71.2 C mobo: 40.0 C gpu: amdgpu temp: 51.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 884
Processes: 338 Uptime: 2h 7m wakeups: 0 Memory: 15.52 GiB
used: 4.74 GiB (30.6%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1365
libs: 404 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
Garuda (2.6.14-1):
System install date: 2023-01-27
Last full system update: 2023-01-31
This is most likely a setting in the “BIOS” (UEFI actually).
On mine I can choose between external only or duplicating the main to the secondary.
Then the display manager takes over and actually uses two monitors.
I don’t know about the audio problem though.
Kayo
February 3, 2023, 3:46am
5
Pipewire had an update yesterday, so there is most likely an update for you if you run garuda-update
Try that to see if the issue persists with the new version.
gonza
February 9, 2023, 8:49pm
6
I could solved loading from a previous snapshot.
I don't know exactly what happened.
Thank you
system
Closed
February 23, 2023, 8:49pm
7
