Hi everyone, I’m not managing to get audio on my tv through HDMI.
I’ve checked various other threads on the topic, but haven’t found anything that clearly matches my setup (a lot of them do things with pulse-audio while I’m using pipewire and others talk about issues with audio through their nvidia card, which I have, but I’m not sure if I’m supposed to be using it).
garuda-inxi:
Kernel: 6.5.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=220d401c-e739-49f7-b37b-c9837e340ce5 rw rootflags=subvol=@
pci=noaer ibt=off
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 info: latte-dock
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: HP product: HP Pavilion Gaming Notebook
Mobo: HP model: 816B v: 91.1E serial: <superuser required> UEFI: Insyde
v: F.91 date: 08/20/2019
ID-1: BAT0 charge: 23.7 Wh (100.0%) condition: 23.7/23.7 Wh (100.0%)
volts: 11.9 min: 14.8 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
Info: model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3157 high: 3296 min/max: 800/3500 scaling:
driver: intel_pstate governor: performance cores: 1: 3122 2: 3126 3: 3123
4: 3103 5: 3127 6: 3296 7: 3265 8: 3101 bogomips: 41599
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:191b
Device-2: NVIDIA GM107M [GeForce GTX 950M] vendor: Hewlett-Packard
driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:139a class-ID: 0302
Device-3: Intel RealSense 3D Camera (Front F200) driver: uvcvideo
type: USB rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3:2
chip-ID: 8086:0a66 class-ID: 0e02 serial: <filter>
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1182x380mm (46.54x14.96")
s-diag: 1242mm (48.88")
Monitor-1: HDMI-A-1 mapped: HDMI-1-1 pos: primary,top-right
model: Dell S2722DGM serial: <filter> built: 2021 res: 2560x1440 hz: 60
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: eDP-1 mapped: eDP-1-1 pos: bottom-l model: Samsung 0x5844
built: 2015 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
modes: 1920x1080
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce GTX
950M/PCIe/SSE2 direct-render: Yes
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
API: ALSA v: k6.5.2-zen1-1-zen status: kernel-api
Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 08:00.0 chip-ID: 10ec:b723
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
lanes: 1 port: 3000 bus-ID: 09:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF-ID-1: br-6d1386589274 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 0bda:b006
rfk-block: hardware: no software: yes address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 1.03 TiB used: 904.67 GiB (86.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNLF128HCHP-000H1
tech: SSD serial: <filter> fw-rev: 1H1Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ01ABD100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 2C scheme: GPT
ID-1: / raw-size: 117.12 GiB size: 117.12 GiB (100.00%)
used: 87.73 GiB (74.9%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
used: 74.5 MiB (29.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 117.12 GiB size: 117.12 GiB (100.00%)
ID-4: /var/log raw-size: 117.12 GiB size: 117.12 GiB (100.00%)
ID-5: /var/tmp raw-size: 117.12 GiB size: 117.12 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.46 GiB used: 175.2 MiB (1.1%)
ID-2: swap-2 type: partition size: 4.88 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb5 maj-min: 8:21
System Temperatures: cpu: 54.0 C pch: 48.5 C mobo: N/A gpu: nvidia
temp: 51 C
Processes: 279 Uptime: 1h 47m wakeups: 11 Memory: total: 16 GiB
available: 15.46 GiB used: 3.88 GiB (25.1%) Init: systemd v: 254
Packages: 2332 pm: nix-default pkgs: 50 pm: nix-sys pkgs: 0 pm: nix-usr
pkgs: 504 libs: 152 pm: pacman pkgs: 1778 libs: 422 tools: octopi,pamac,yay
pm: flatpak pkgs: 0 Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.29
System install date: 2022-04-24
Last full system update: 2023-09-13 ↻
pactl list sinks
Sink #161
State: RUNNING
Description: Built-in Audio Digital Stereo (HDMI)
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 37233 / 57% / -14,73 dB, front-right: 37233 / 57% / -14,73 dB
balance 0,00
Base Volume: 65536 / 100% / 0,00 dB
Monitor Source: alsa_output.pci-0000_00_1f.3.hdmi-stereo.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
Properties:
alsa.card = "0"
alsa.card_name = "HDA Intel PCH"
alsa.class = "generic"
alsa.device = "3"
alsa.driver_name = "snd_hda_intel"
alsa.id = "HDMI 0"
alsa.long_card_name = "HDA Intel PCH at 0x94328000 irq 131"
alsa.name = "PHILIPS FTV"
alsa.resolution_bits = "16"
alsa.subclass = "generic-mix"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
api.alsa.card.longname = "HDA Intel PCH at 0x94328000 irq 131"
api.alsa.card.name = "HDA Intel PCH"
api.alsa.path = "hdmi:0"
api.alsa.pcm.card = "0"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
audio.position = "FL,FR"
card.profile.device = "7"
device.api = "alsa"
device.class = "sound"
device.id = "46"
device.profile.description = "Digital Stereo (HDMI)"
device.profile.name = "hdmi-stereo"
device.routes = "1"
factory.name = "api.alsa.pcm.sink"
media.class = "Audio/Sink"
device.description = "Built-in Audio"
node.name = "alsa_output.pci-0000_00_1f.3.hdmi-stereo"
node.nick = "PHILIPS FTV"
node.pause-on-idle = "false"
object.path = "alsa:pcm:0:hdmi:0:playback"
priority.driver = "696"
priority.session = "696"
factory.id = "18"
clock.quantum-limit = "8192"
client.id = "34"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "56"
object.serial = "161"
node.max-latency = "16384/48000"
api.alsa.period-size = "1024"
api.alsa.period-num = "32"
api.alsa.headroom = "0"
api.acp.auto-port = "false"
api.acp.auto-profile = "false"
api.alsa.card = "0"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1 = "Audio0"
device.bus = "pci"
device.bus_path = "pci-0000:00:1f.3"
device.enum.api = "udev"
device.form_factor = "internal"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_00_1f.3"
device.nick = "HDA Intel PCH"
device.plugged.usec = "5066963"
device.product.id = "0xa170"
device.product.name = "100 Series/C230 Series Chipset Family HD Audio Controller"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.vendor.id = "0x8086"
device.vendor.name = "Intel Corporation"
device.string = "0"
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, availability group: Legacy 5, available)
Active Port: hdmi-output-0
Formats:
pcm
Everything works fine when using windows and I thought I had it working with pulseaudio before garuda switched to pipewire, but I’m not sure.
I have been able to get some noise out of the tv with speaker-test -D plug:hdmi.
I have also tried switching to hybrid mode in optimus-manager, but that did not help.
Any suggestions for a fix?
