No sound with ALC1220
Need help with a no sound problem
inxi:
# inxi -A
  Device-1: Intel Raptor Lake High Definition Audio driver: snd_hda_intel
  Device-2: NVIDIA driver: snd_hda_intel
  API: ALSA v: k6.9.0-rc5-1-mainline status: kernel-api
  Server-1: PipeWire v: 1.0.5 status: active
aplay:
# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC1220 Analog [ALC1220 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC1220 Digital [ALC1220 Digital]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
dmesg:
# dmesg | grep ALC1220
[    6.016437] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC1220: line_outs=1 (0x1b/0x0/0x0/0x0/0x0) type:speaker
garuda-inxi output:
# garuda-inxi
  Kernel: 6.8.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/vmlinuz-linux-zen
    root=UUID=4661f1d4-8fc7-437e-bafd-2c9d70218159 rw rootflags=subvol=@
    quiet resume=UUID=cab8c551-b978-43d5-8387-ea5cd9e0c993 loglevel=3 ibt=off
  Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.41 wm: Muffin v: 6.0.1 tools:
    avail: cinnamon-screensaver,xautolock vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: ARDOR GAMING product: PD5x_7xSNC_SND_SNE v: N/A
  Mobo: ARDOR GAMING model: PD5x_7xSNC_SND_SNE serial: <superuser required>
    uuid: <superuser required> UEFI: INSYDE v: 1.07.09TDC date: 04/25/2023
  ID-1: BAT0 charge: 72.0 Wh (100.0%) condition: 72.0/77.3 Wh (93.1%)
    volts: 12.6 min: 11.4 model: Notebook BAT type: Li-ion serial: <filter>
    status: full
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
  Info: model: 13th Gen Intel Core i7-13700HX bits: 64 type: MST AMCP
    process: Intel 7 (10nm) family: 6 model-id: 0xBF (191) stepping: 2
    microcode: 0x34
  Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
    cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
    L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB desc: 1x30 MiB
  Speed (MHz): avg: 879 high: 1343 min/max: 800/2100:1500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 801
    5: 800 6: 800 7: 800 8: 801 9: 831 10: 800 11: 1311 12: 800 13: 801
    14: 800 15: 1030 16: 1343 17: 800 18: 799 19: 1093 20: 800 21: 1106
    22: 799 23: 800 24: 800 bogomips: 110592
  Device-1: NVIDIA AD106M [GeForce RTX 4070 Max-Q / Mobile]
    vendor: CLEVO/KAPOK driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm
    non-free: 550.xx+ status: current (as of 2024-04) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s ports: active: none off: eDP-1
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2860
  Device-2: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 5986:214c
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6 driver: X:
    loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
    gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 171 s-size: 380x210mm (14.96x8.27")
    s-diag: 434mm (17.09")
  Monitor-1: eDP-1 mapped: DP-4 note: disabled model: BOE Display 0x099d
    built: 2020 res: 2560x1440 dpi: 171 gamma: 1.2 size: 380x210mm (14.96x8.27")
    diag: 437mm (17.2") ratio: 16:9 modes: 2560x1440
  API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4070 Laptop GPU driver: nvidia v: 550.78 device-ID: 10de:2860
    surfaces: xcb,xlib
  Device-1: Intel Raptor Lake High Definition Audio vendor: CLEVO/KAPOK
  Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1
    chip-ID: 10de:22bd class-ID: 0403
  API: ALSA v: k6.8.9-zen1-1-zen status: kernel-api
  Device-2: Realtek RTL8125 2.5GbE vendor: CLEVO/KAPOK driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 6d:00.0
  IF: enp109s0 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0033
  Local Storage: total: 1.84 TiB used: 15.29 GiB (0.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:7 vendor: Samsung
    model: MZVL41T0HBLB-00BTW size: 953.87 GiB block-size: physical: 512 B
    fw-rev: HXC70W1Q temp: 21.9 C scheme: GPT
    model: WD Blue SN570 1TB SSD size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 234110WD temp: 26.9 C scheme: GPT
  ID-1: / raw-size: 50 GiB size: 50 GiB (100.00%) used: 11.33 GiB (22.7%)
    fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:3
  ID-2: /boot raw-size: 15 GiB size: 15 GiB (100.00%) used: 1.47 GiB (9.8%)
  ID-3: /boot/efi raw-size: 4.98 GiB size: 4.97 GiB (99.80%)
    used: 588 KiB (0.0%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
  ID-4: /home raw-size: 300 GiB size: 300 GiB (100.00%)
    used: 778.4 MiB (0.3%) fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:5
  ID-5: /opt raw-size: 100 GiB size: 100 GiB (100.00%) used: 1.73 GiB (1.7%)
    fs: btrfs dev: /dev/nvme1n1p4 maj-min: 259:4
  ID-6: /var/log raw-size: 50 GiB size: 50 GiB (100.00%)
    used: 11.33 GiB (22.7%) fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:3
  ID-7: /var/tmp raw-size: 50 GiB size: 50 GiB (100.00%)
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme1n1p6 maj-min: 259:6
  ID-2: swap-2 type: zram size: 15.39 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 26.0 C mobo: N/A gpu: nvidia temp: 31 C
  Memory: total: 16 GiB note: est. available: 15.39 GiB used: 2.26 GiB (14.7%)
  Processes: 511 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.12 GiB services: csd-power,upowerd
  Packages: pm: pacman pkgs: 1374 libs: 397 tools: gnome-software,paru
    Compilers: gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
    running-in: gnome-terminal inxi: 3.3.34
  System install date:     2024-05-04
  Last full system update: 2024-05-04
pavucontrol , alsamixer and sound settings sees the device, but I have no sound from it
Can you provide your
As per the forum template
Summary
When will the day come when I no longer have to copy the template and paste it here?
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
:warning: Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
  • ONE issue per topic.
garuda-inxi output was added
Check out this person’s solution, their setup looks similar to yours:
so strange, but it works for me :grin:
Thanks!
