I have now finally found an O.S that my 80 year old dad can use lol.But after installing Garuda he has no sound ,I googled this and found some answers and i installed pulse audio ,but i still have no volume.If i run the media player that comes with Garuda it works fine as well as with headphones. ```Afer running this i get target not found and yet pulse is in my menu list .
Garuda KDE Dr460nized
sudo pacman -Rns garuda-pipewire pipewire-alsa pipewire-pulse
╭─geoff at geoffhotebook in ⌁
╰─λ inxi -Fxxxza
System: Kernel: 5.10.8-112-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=f08e64be-6032-4612-911d-d9916ed15857 rw rootflags=subvol=@ quiet splash rd.udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId serial: Chassis: type: 10
serial:
Mobo: HP model: 8137 v: 99.41 serial: UEFI: Insyde v: F.1B date: 09/10/2015
Battery: ID-1: BAT1 charge: 32.6 Wh condition: 32.6/32.6 Wh (100%) volts: 16.7/14.8 model: 131-42-6E HS04041 type: Unknown
serial: status: Full
CPU: Info: Quad Core model: AMD A6-5200 APU with Radeon HD Graphics bits: 64 type: MCP arch: Jaguar family: 16 (22)
model-id: N/A stepping: 1 microcode: 700010F L2 cache: 2 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 15986
Speed: 1996 MHz min/max: 800/2000 MHz Core speeds (MHz): 1: 1996 2: 1954 3: 1995 4: 1977
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Kabini [Radeon HD 8400 / R3 Series] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu bus ID: 00:01.0 chip ID: 1002:9830
Device-2: Cheng Uei Precision Industry (Foxlink) HP Truevision HD type: USB driver: uvcvideo bus ID: 2-1:2
chip ID: 05c8:0382
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: ati,radeon unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.10.8-112-tkg-bmq LLVM 11.0.1) v: 4.5 Mesa 20.3.3 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus ID: 00:01.1 chip ID: 1002:9840
Device-2: Advanced Micro Devices [AMD] FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1022:780d
Sound Server: ALSA v: k5.10.8-112-tkg-bmq
Network: Device-1: Realtek RTL8188EE Wireless Network Adapter vendor: Hewlett-Packard driver: rtl8188ee v: kernel port: 3000
bus ID: 01:00.0 chip ID: 10ec:8179
IF: wlp1s0 state: up mac:
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel port: 2000
bus ID: 02:00.0 chip ID: 10ec:8136
IF: enp2s0 state: down mac:
Drives: Local Storage: total: 232.89 GiB used: 17.7 GiB (7.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s serial: rev: 1B6Q
Partition: ID-1: / raw size: 232.59 GiB size: 232.59 GiB (100.00%) used: 17.7 GiB (7.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 560 KiB (0.2%) fs: vfat dev: /dev/sda1
maj-min: 8:1
ID-3: /home raw size: 232.59 GiB size: 232.59 GiB (100.00%) used: 17.7 GiB (7.6%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-4: /var/log raw size: 232.59 GiB size: 232.59 GiB (100.00%) used: 17.7 GiB (7.6%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-5: /var/tmp raw size: 232.59 GiB size: 232.59 GiB (100.00%) used: 17.7 GiB (7.6%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-1: swap-1 type: zram size: 3.77 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 3.77 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 3.77 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 3.77 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 66.5 C mobo: 20.0 C gpu: radeon temp: 65.0 C
Info: Processes: 187 Uptime: 26m wakeups: 2 Memory: 15.09 GiB used: 3.18 GiB (21.0%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1581 lib: 495 Shell: fish v: 3.1.2 running in: alacritty inxi: 3.2.01
╰─λ
