MateBook D15 Sound Issue
Howdy, The sound has not been working for me since I downloaded Garuda. (It works on Windows) At the same time, Bluetooth headphones work, but speakers that do not work. xd
Kernel: 6.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=534089d4-4d41-4fec-97f4-f94e98c5ad79 rw rootflags=subvol=@
quiet splash snd_intel_dspcfg.dsp_driver=3
Desktop: KDE Plasma v: 6.5.1 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: HUAWEI product: BoDE-WXX9 v: M1010 serial: <filter>
Mobo: HUAWEI model: BoDE-WXX9-PCB-B4 v: M1010 serial: <filter>
part-nu: C170 uuid: a108ce81-bb18-4a74-af22-d1e073774ba1 UEFI: HUAWEI
v: 1.20 date: 07/05/2023
ID-1: BAT1 charge: 32.4 Wh (79.2%) condition: 41/55.2 Wh (74.1%) volts: 7.98
min: 7.64 model: Desay HB4692Z9ECW-22T type: Li-ion serial: <filter>
charging: status: discharging control: start: 40% end: 70% cycles: 695
Info: model: 11th Gen Intel Core i5-1155G7 bits: 64 type: MT MCP
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 2
microcode: 0x3C
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1229 min/max: 400/4500 base/boost: 2500/4500 scaling:
driver: intel_pstate governor: powersave volts: 0.7 V ext-clock: 100 MHz
cores: 1: 1229 2: 1229 3: 1229 4: 1229 5: 1229 6: 1229 7: 1229 8: 1229
bogomips: 39936
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: QUANTA
built: 2020-21 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Quanta ov9734_techfront_camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 0408:1040
Display: unspecified server: X.Org v: 24.1.9 with: Xwayland v: 24.1.9
compositor: kwin_wayland driver: gpu: i915 display-ID: :0 screens: 1
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: BOE Display 0x0872 built: 2019 res:
modes: 1920x1080
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.5-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
GT2) device-ID: 8086:9a49 memory: 7.36 GiB unified: yes
API: Vulkan v: 1.4.328 layers: 5 device: 0 type: integrated-gpu name: Intel
Iris Xe Graphics (TGL GT2) driver: mesa intel v: 25.2.5-arch1.2
device-ID: 8086:9a49 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.4 256 bits) driver: mesa llvmpipe v: 25.2.5-arch1.2 (LLVM
21.1.4) device-ID: 10005:0000 surfaces: N/A
de: kscreen-console,kscreen-doctor wl: swaymsg,wayland-info
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: QUANTA driver: N/A
alternate: snd_soc_avs, snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.17.5-zen1-1-zen status: kernel-api
Server-2: PipeWire v: 1.4.9 status: n/a (root, process) with:
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6 chip-ID: 8087:0026
Local Storage: total: 238.47 GiB used: 47.48 GiB (19.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe-4 SSD 256GB size: 238.47 GiB
tech: SSD serial: <filter> fw-rev: YM013215 temp: 37.9 C scheme: GPT
SMART: yes health: PASSED on: 305d 5h cycles: 3,128
read-units: 181,963,953 [93.1 TB] written-units: 85,047,444 [43.5 TB]
ID-1: / raw-size: 51.38 GiB size: 51.38 GiB (100.00%)
used: 47.36 GiB (92.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p8
maj-min: 259:8
ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%)
used: 120.5 MiB (61.5%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 51.38 GiB size: 51.38 GiB (100.00%)
maj-min: 259:8
ID-4: /var/log raw-size: 51.38 GiB size: 51.38 GiB (100.00%)
maj-min: 259:8
ID-5: /var/tmp raw-size: 51.38 GiB size: 51.38 GiB (100.00%)
maj-min: 259:8
ID-1: swap-1 type: zram size: 7.54 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 35.0 C mobo: N/A
Memory: total: 8 GiB available: 7.54 GiB used: 3.53 GiB (46.8%) igpu: 60 MiB
Processes: 307 Power: uptime: 14m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 2.98 GiB services: org_kde_powerdevil,
Packages: 1398 pm: pacman pkgs: 1353 libs: 328 tools: octopi,paru,yay
pm: flatpak pkgs: 45 Compilers: gcc: 15.2.1 Shell: Bash (sudo) v: 5.3.3
Garuda (2.11.1-1):
System install date: 2025-08-20
Garuda release: 250801
Last full system update: 2025-10-31
Is partially upgraded: Yes
Relevant software: snapper NetworkManager dracut garuda-hardware-profile-standard
Windows dual boot: Yes
