No sound is coming through bluetooth device
That sounds like more of a device problem. Did you ever research updating your BIOS?
Also, have you re-tried the Zen kernel? It is more multimedia-friendly than the LTS.
EDIT: I also noticed several Bluetooth-related posts in the Arch Forums this morning, so you might peruse them. Please don't post there, since posting is for Arch-only users. :slight_smile:
for my device no update after 2019 03 is given , I was on the zen kernel before switching to lts (suggested by filo )
Yes, but that was before you had BT working again. If the Zen kernel fixes it, it’s a cheap fix.
I switched back to zen , the sound is comming through bluetooth speaker , if anything goes wrong will update here
If it crashes like that again, please post any kernel messages recorded in your journal (/var/log/journal)
$ journalctl is the command
 Jul 12 01:32:14 starboy-aspirea51551g kernel: rtsx_pci 0000:02:00.0:    [ 0] RxErr                  (First)
Jul 12 01:32:16 starboy-aspirea51551g kernel: rtsx_pci 0000:02:00.0:    [ 7] BadDLLP
Jul 12 01:32:16 starboy-aspirea51551g kernel: rtsx_pci 0000:02:00.0:    [12] Timeout
Jul 12 01:32:16 starboy-aspirea51551g kernel: rtsx_pci 0000:02:00.0: AER:   Error of this Agent is reported f>
Jul 12 01:32:16 starboy-aspirea51551g kernel: r8169 0000:02:00.1: PCIe Bus Error: severity=Corrected, type=Ph>
Jul 12 01:32:16 starboy-aspirea51551g kernel: r8169 0000:02:00.1:   device [10ec:8168] error status/mask=0000>
Jul 12 01:32:16 starboy-aspirea51551g kernel: r8169 0000:02:00.1:    [ 0] RxErr                  (First)
Jul 12 01:32:16 starboy-aspirea51551g kernel: r8169 0000:02:00.1:    [ 7] BadDLLP
Jul 12 01:32:16 starboy-aspirea51551g kernel: r8169 0000:02:00.1:    [12] Timeout
Jul 12 01:32:16 starboy-aspirea51551g systemd-journald[391]: Data hash table of /var/log/journal/59a92278e437>
Jul 12 01:32:16 starboy-aspirea51551g systemd-journald[391]: /var/log/journal/59a92278e437429e834d6d5d1c5e3b8>
Jul 12 01:32:29 starboy-aspirea51551g kernel: pcieport 0000:00:1c.4: AER: Multiple Corrected error received: >
Jul 12 01:32:29 starboy-aspirea51551g kernel: rtsx_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type>
Jul 12 01:32:29 starboy-aspirea51551g kernel: rtsx_pci 0000:02:00.0:   device [10ec:5287] error status/mask=0>
Jul 12 01:32:29 starboy-aspirea51551g kernel: rtsx_pci 0000:02:00.0:    [ 7] BadDLLP
Jul 12 01:32:29 starboy-aspirea51551g kernel: rtsx_pci 0000:02:00.0: AER:   Error of this Agent is reported f>
Jul 12 01:32:29 starboy-aspirea51551g kernel: r8169 0000:02:00.1: PCIe Bus Error: severity=Corrected, type=Da>
Jul 12 01:32:29 starboy-aspirea51551g kernel: r8169 0000:02:00.1:   device [10ec:8168] error status/mask=0000>
Jul 12 01:32:29 starboy-aspirea51551g kernel: r8169 0000:02:00.1:    [ 7] BadDLLP
Jul 12 01:32:34 starboy-aspirea51551g kernel: pcieport 0000:00:1c.4: AER: Multiple Corrected error received: >
Jul 12 01:32:34 starboy-aspirea51551g kernel: rtsx_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type>
Jul 12 01:32:34 starboy-aspirea51551g kernel: rtsx_pci 0000:02:00.0:   device [10ec:5287] error status/mask=0>
Jul 12 01:32:34 starboy-aspirea51551g kernel: rtsx_pci 0000:02:00.0:    [ 7] BadDLLP
Jul 12 01:32:34 starboy-aspirea51551g kernel: rtsx_pci 0000:02:00.0: AER:   Error of this Agent is reported f>
Jul 12 01:32:34 starboy-aspirea51551g kernel: r8169 0000:02:00.1: PCIe Bus Error: severity=Corrected, type=Da>
Jul 12 01:32:34 starboy-aspirea51551g kernel: r8169 0000:02:00.1:   device [10ec:8168] error status/mask=0000>
Jul 12 01:32:34 starboy-aspirea51551g kernel: r8169 0000:02:00.1:    [ 7] BadDLLP
@bro I've uploaded the jounralctl right after the sound is gone please help
I've posted it above
@Bro
You should try to write all your content in one post.
Also, you can edit your post until someone replies.
Please.
This is a forum, not a chat room.
I would do a Google search on the error messages, such as “PCieBus Error” and "BadDLP. It seems to also indicate something about “r8169” which is your WiFi module. I have done a preliminary search for you. Here: https://www.google.com/search?q=PCie+Bus+Error+BadDLLP&sxsrf=AB5stBh-oB9D21Ixrtl5cAYXHS7SX7fl3w%3A1689200108545&ei=7CWvZOH0IIGD0PEP2--K-AQ&ved=0ahUKEwjhmrLjmIqAAxWBATQIHdu3Ak8Q4dUDCBE&uact=5&oq=PCie+Bus+Error+BadDLLP&gs_lcp=Cgxnd3Mtd2l6LXNlcnAQAzIFCAAQgAQ6CggAEEcQ1gQQsAM6BwgAEA0QgAQ6CAghEKABEMMESgQIQRgAUKyiAliQ0AJgmtkCaAJwAXgAgAFbiAGPApIBATSYAQCgAQHAAQHIAQg&sclient=gws-wiz-serp
If it comes to network problems, I am out of my depth. But there are any number of folks here that might.
I have one thought: If you can connect to your internet via ethernet cable, stop your Wifi, then do whatever you normally do with BT, and see if you bomb. Personally, I notice my BT signal drop dramatically over distance with concurrent Wifi use. Fortunately, I’m 2 feet from the router and everything is normal with ethernet.
Good luck, pilgrim. :smiley:
EDIT: Have you tried the 8168 driver?
I have disabled my wifi and started using LAN, but the bluetooth is still the same
additionally while I was performing garuda-update I got this Error: ==> dkms install --no-depmod nvidia/535.54.03 -k 6.4.3-zen1-1-zen ==> dkms install --no-depmod vmware-workstation/17.0.2_21581411 -k 6.4.3-zen1-1-zen ==> depmod 6.4.3-zen1-1-zen ==> ERROR: Missing 6.4.3-arch1-1 kernel modules tree for module nvidia/535.54.03.
Can booting into a snapshot when my bluetooth was working fine fix this issue?
It might, but then revert back when you next update. And living in a snapshot is definitely not a good thing. The problem in not the solution; the solution is the solution, and there are still a number of troubleshooting steps to take. For instance, you are currently in a partial update scenario, and that can be very, very, bad. You have to achieve a fully updated system, or it makes no sense to go any further.
Also, did you try replacing the “r8169” driver with the “r8168” driver yet, as I suggested?
sudo pacman -S r8168 r8168-lts
But first, update.
:smiley:
Hi my earing aids are connected to bluetooth in connected devices but doesnt come up to sound devices. heres my garuda inxi:
Kernel: 6.4.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=943ba030-3495-4ca0-985e-08752e5b580a rw rootflags=subvol=@
resume=UUID=8c4f95c2-14d0-48f5-b79d-c3914abe93fc loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: ROG STRIX Z390-I GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2812
date: 10/12/2020
Info: model: Intel Core i5-9600K bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF8
desc: 1x9 MiB
Speed (MHz): avg: 1919 high: 2601 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 1700 2: 2601 3: 1811
4: 1700 5: 1701 6: 2003 bogomips: 44398
Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: Micro-Star MSI
driver: nvidia v: 535.86.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1e89 class-ID: 0300
Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x342mm (31.57x13.46")
s-diag: 872mm (34.33")
Monitor-1: DP-2 res: 3440x1440 hz: 100 dpi: 109
size: 798x334mm (31.42x13.15") diag: 865mm (34.06") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.86.05 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
API: ALSA v: k6.4.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
status: off 2: wireplumber status: active 3: pipewire-alsa type: plugin
Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 100 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6
Local Storage: total: 912.89 GiB used: 261.03 GiB (28.6%)
model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
fw-rev: 111110WD temp: 50.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
tech: SSD serial: <filter> fw-rev: B1D1 scheme: MBR
ID-1: / raw-size: 80.97 GiB size: 80.97 GiB (100.00%) used: 8.94 GiB (11.0%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 383.79 GiB size: 383.79 GiB (100.00%)
used: 252.09 GiB (65.7%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 80.97 GiB size: 80.97 GiB (100.00%)
used: 8.94 GiB (11.0%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 80.97 GiB size: 80.97 GiB (100.00%)
ID-2: swap-2 type: partition size: 512 MiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 49 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
Processes: 255 Uptime: 26m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 3.55 GiB (22.9%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages:
pm: pacman pkgs: 1421 libs: 449 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date:     2023-07-29
Last full system update: 2023-07-29 ↻
Can anyone help me? Tips in this thread didnt help
