Hello,
I'm using garuda gnome. Three days ago everything was fine, and today, my sound input/output devices disappeared.
Everything works fine in my other OS (ubuntu 18 and windows 10). I've tried updating the system, but it didn't solve the problem.
inxi --admin --verbosity=7 --filter --no-host
System: Kernel: 5.11.7-139-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=8d84bcbf-5a2e-41ee-820d-82c7a0bec40a rw rootflags=subvol=@ quiet splash rd.udev.log_priority=3
Desktop: GNOME 3.38.4 tk: GTK 3.24.27 wm: gnome-shell dm: GDM 3.38.2.1 Distro: Garuda Linux
Machine: Type: Desktop Mobo: ASUSTeK model: Z170M-PLUS/BR v: Rev X.0x serial: <filter> UEFI: American Megatrends v: 3805
date: 05/03/2018
Memory: RAM: total: 15.58 GiB used: 5 GiB (32.1%)
RAM Report: permissions: Unable to run dmidecode. Root privileges required.
CPU: Info: Quad Core model: Intel Core i5-7600K bits: 64 type: MCP arch: Kaby Lake family: 6 model-id: 9E (158)
stepping: 9 microcode: DE L2 cache: 6 MiB bogomips: 30428
Speed: 4480 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 4480 2: 2383 3: 4415 4: 4486
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts erms est f16c flush_l1d fma fpu
fsgsbase fxsr hle ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep ss ssbd sse sse2 sse4_1
sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Graphics: Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 460.67 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c82 class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: gnome-shell driver: loaded: nvidia display ID: :1 screens: 1
Screen-1: 0 s-res: 3286x1080 s-dpi: 96 s-size: 869x286mm (34.2x11.3") s-diag: 915mm (36")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
Monitor-2: DP-1 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1") diag: 470mm (18.5")
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.67 direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:a170 class ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
class ID: 0403
Sound Server: ALSA v: k5.11.7-139-tkg-bmq
Network: Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel port: f000 bus ID: 00:1f.6
chip ID: 8086:15b8 class ID: 0200
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
IP v6: <filter> type: dynamic noprefixroute scope: global
IP v6: <filter> type: noprefixroute scope: link
WAN IP: <filter>
Bluetooth: Device-1: type: USB driver: btusb v: 0.8 bus ID: 1-2:2 chip ID: 0c10:0000 class ID: fe01
Message: Required tool hciconfig not installed. Check --recommends
RAID: Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020 bus ID: 00:17.0 chip ID: 8086.2822
rev: 31
Drives: Local Storage: total: 447.13 GiB used: 29.49 GiB (6.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP510 size: 447.13 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: ECFM12.2 temp: 40.9 C scheme: GPT
Message: No Optical or Floppy data was found.
Partition: ID-1: / raw size: 67 GiB size: 67 GiB (100.00%) used: 29.46 GiB (44.0%) fs: btrfs dev: /dev/nvme0n1p6
maj-min: 259:6 label: N/A uuid: 8d84bcbf-5a2e-41ee-820d-82c7a0bec40a
ID-2: /boot/efi raw size: 99 MiB size: 95 MiB (95.96%) used: 32.3 MiB (34.0%) fs: vfat dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: A055-BC70
ID-3: /home raw size: 67 GiB size: 67 GiB (100.00%) used: 29.46 GiB (44.0%) fs: btrfs dev: /dev/nvme0n1p6
ID-4: /root raw size: 67 GiB size: 67 GiB (100.00%) used: 29.46 GiB (44.0%) fs: btrfs dev: /dev/nvme0n1p6
ID-5: /srv raw size: 67 GiB size: 67 GiB (100.00%) used: 29.46 GiB (44.0%) fs: btrfs dev: /dev/nvme0n1p6
ID-6: /var/cache raw size: 67 GiB size: 67 GiB (100.00%) used: 29.46 GiB (44.0%) fs: btrfs dev: /dev/nvme0n1p6
ID-7: /var/log raw size: 67 GiB size: 67 GiB (100.00%) used: 29.46 GiB (44.0%) fs: btrfs dev: /dev/nvme0n1p6
ID-8: /var/tmp raw size: 67 GiB size: 67 GiB (100.00%) used: 29.46 GiB (44.0%) fs: btrfs dev: /dev/nvme0n1p6
ID-1: swap-1 type: zram size: 3.89 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 3.89 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 3.89 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 3.89 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Unmounted: ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: Recupera\xc3\xa7\xc3\xa3o uuid: 46B05524B0551C2D
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 297.96 GiB fs: ntfs label: N/A uuid: 96E284C1E284A759
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 81.54 GiB fs: ext4 label: N/A uuid: dd6cb209-7118-4a3d-a859-872b216f1a2a
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-2:2 info: N/A type: Bluetooth driver: btusb interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 0c10:0000
class ID: fe01
Device-2: 1-9:3 info: Dell Dell Universal Receiver type: Keyboard,Mouse,HID driver: hid-generic,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 413c:8505 class ID: 0300
Device-3: 1-10:4 info: Logitech USB Receiver type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s chip ID: 046d:c53d class ID: 0300
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003 class ID: 0900
Sensors: System Temperatures: cpu: 51.0 C mobo: 27.8 C gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Info: Processes: 253 Uptime: 2h 26m wakeups: 0 Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1236
lib: 301 Shell: Bash v: 5.1.4 running in: xfce4-terminal inxi: 3.3.01
