No sound from speakers (LAPTOP)
I often suffer from sound problems in my laptop in garuda. my hardware is totally ok (it works compleatly fine in windows). once my speakers wern't producing any sound (THE SOUND ICON WAS NOT SHOWING ETHER) and videos were not playing i rebooted and reseted all the configs and it got back normal but this time in the latte dock panel, the sound icon is showing but only the mike, volume controller isn't showing . i thought it was my speaker's fault but the worked for windows. and i hope it is not any kind of driver problem. i did't make any mess except i played a game on wine last night and garud maintenance thing popuped few times and failed
please help, i have online class tomorrow :frowning_face: :frowning_face: :frowning_face:
Many solved their audio problems with this kind of all in one script.
Inxi -Faz missing…
Your system is hella out of date.
You gotta do sudo bash -c ". <(wget -qO- https://gitlab.com/garuda-linux/themes-and-settings/settings/garuda-common-settings/-/snippets/2147440/raw/main/remote-update)"
You should do this before doing @filo’s suggestion.
Make sure it completed successfully.
thanks man,
now i can do my online class :grinning_face_with_smiling_eyes:
guys i am still suffering
i am not able to use the inbuilt audio
System:    Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/timeshift-btrfs/snapshots/2021-11-22_10-00-22/@/boot/vmlinuz-linux-zen
root=UUID=cfeb12e8-b340-4b7c-9957-a2bc51a4bef9 quiet splash rd.udev.log_priority=3
rootflags=defaults,noatime,space_cache,autodefrag,compress=zstd,subvol=timeshift-btrfs/snapshots/2021-11-22_10-00-22/@
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Laptop System: ASUSTeK product: VivoBook E14 E402YA_E402YA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: E402YA v: 1.0 serial: <filter> UEFI: American Megatrends v: E402YA.303
date: 09/10/2019
Battery:   ID-1: BAT0 charge: 25.0 Wh (100.0%) condition: 25.0/32.3 Wh (77.3%) volts: 7.8 min: 7.8
model: ASUSTeK E402-42 type: Li-ion serial: N/A status: Not charging cycles: 403
CPU:       Info: Dual Core model: AMD E2-7015 APU with AMD Radeon R2 Graphics bits: 64 type: MCP
arch: Puma family: 16 (22) model-id: 30 (48) stepping: 1 microcode: 7030106 cache: L2: 1024 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 5988
Speed: 1497 MHz min/max: 1000/1500 MHz Core speeds (MHz): 1: 1497 2: 1497
Graphics:  Device-1: AMD Mullins [Radeon R2 Graphics] vendor: ASUSTeK driver: radeon v: kernel
alternate: amdgpu bus-ID: 00:01.0 chip-ID: 1002:9853 class-ID: 0300
Device-2: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo bus-ID: 1-1.4:5
chip-ID: 13d3:5a11 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: ati,radeon
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 112 size: 309x173mm (12.2x6.8") diag: 354mm (13.9")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.14.14-zen1-1-zen LLVM 13.0.0) v: 4.5 Mesa 21.2.5
direct render: Yes
Audio:     Device-1: AMD Kabini HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
Device-2: AMD FCH Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:14.2
chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Network:   Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: AzureWave
driver: N/A modules: rtw88_8821ce port: e000 bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u bus-ID: 1-1.1.4:11
chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
IF: wlp0s18u1u1u4 state: up mac: <filter>
Bluetooth: Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 2-1.1:3
chip-ID: 13d3:3529 class-ID: e001 serial: <filter>
Drives:    Local Storage: total: 931.51 GiB used: 51.47 GiB (5.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1J
Partition: ID-1: / raw-size: 157.84 GiB size: 157.84 GiB (100.00%) used: 51.45 GiB (32.6%) fs: btrfs
dev: /dev/sda7 maj-min: 8:7
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 25.9 MiB (10.1%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 157.84 GiB size: 157.84 GiB (100.00%) used: 51.45 GiB (32.6%) fs: btrfs
ID-4: /var/log raw-size: 157.84 GiB size: 157.84 GiB (100.00%) used: 51.45 GiB (32.6%)
fs: btrfs dev: /dev/sda7 maj-min: 8:7
ID-5: /var/tmp raw-size: 157.84 GiB size: 157.84 GiB (100.00%) used: 51.45 GiB (32.6%)
ID-1: swap-1 type: zram size: 3.27 GiB used: 983.3 MiB (29.4%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 63.5 C mobo: N/A gpu: radeon temp: 63.0 C
Fan Speeds (RPM): cpu: 3800
Info:      Processes: 223 Uptime: 10h 11m wakeups: 5 Memory: 3.27 GiB used: 2.06 GiB (63.2%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1500 lib: 372
Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.08
Careful, you booted from a snapshot.
You should “confirm” the restore in the timeshift GUI and reboot.
Then you can do anything else, e.g. you could check if the fix of yesterday is still there…
and maybe update
since we are at 5.15.4 today.
yes i am updating my system
After updating. if its still not showing inbuilt speakers.
Right click volume icon. Go to configure audio devices. There you might find show inactive devices. Just enable it. or in other case it will be under profile dropdown .it will be set to off mode just change it to analog stereo.
still not helping
it even got worse, after updating the system, the latte dock disappered,i thought reboothing in an option but n the grub menu it is showing an new arch distro but i only have garuda and win10, anyways after garuda got my speakers runninng but after conecting to bluetooth it disappeared again! and my garuda always froze at the sweet theme splash screen some how i managed to log and cleared all the configs
anyways welcome to the forum @CZEKOSHAR
ok so i found a solution to this problem and that is to run sudo alsactl store
worked completly for me
BUT THE FACT IS NOW I LOST MY IN-BUILT MIC
ok now it is not working again
I'm using an Acer Swift 1 laptop and I had no sound output, neither through nor built in speakers nor headphone.
I found No Audio on Acer Swift 3 - #2 by bogdancovaciu - Sound - Manjaro Linux Forum and No sound after full-upgrade | Sound Problem | Acer Swift Laptop | Linux | ParrotOS - YouTube which gave the same advice, which worked for me too.
Create or add to the file /etc/modprobe.d/alsa-base.conf and add these two lines:
options snd-hda-intel dmic_detect=0
options snd-hda-intel model=laptop-amic enable=yes
... then reboot.
The first line is to enable the speaker, the second for the internal microphone.
yeah these lines already exist's but it is some sord of problem with alsa or pipewire or pulseaudio my in-built analog stereo is appearing and disappearing and messing up everything, my love towards garuda is fadding out :disappointed:, i can nither play audio nor video, i am using kali since one month and today i came with some config files which further messed up and gave birth to lot more problemes
i wanna die
Are you sure everything is ok here
Cause thing like this has happened to me too, but it's mainly that these settings in the above pic just get altered automatically.
nah bro it's messed up
(don't worry, I MUTED THE CHROME)
In the screenshot you have shared, try changing the profile(which is currently set Off ) to Analog Stereo Duplex
hey @Austin it fixed after yesterday's update however there is only off in the profile section
alright, again AGIN
so i am booting garuda after week or two for the sound system problem . and now it is working so i decided to call my friend and i was akwardly talking and in the system tray my mic was flickering i tried to mute and ther we go again
mic and speaker not working again (GARUDA SUPPORT!!!!!1!!)
ok now i need serious help here is my inxi -Faz
Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=cfeb12e8-b340-4b7c-9957-a2bc51a4bef9 rw rootflags=subvol=@
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
UEFI: American Megatrends v: E402YA.303 date: 09/10/2019
ID-1: BAT0 charge: 13.9 Wh (55.6%) condition: 25.0/32.3 Wh (77.5%)
volts: 7.8 min: 7.8 model: ASUSTeK E402-42 type: Li-ion serial: N/A
status: Discharging cycles: 435
Info: model: AMD E2-7015 APU with AMD Radeon R2 Graphics socket: P0
bits: 64 type: MCP arch: Puma family: 0x16 (22) model-id: 0x30 (48)
stepping: 1 microcode: 0x7030106
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 1175 high: 1350 min/max: 1000/1500 boost: disabled
base/boost: 1500/1500 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 1000 2: 1350 bogomips: 5988
v: kernel alternate: amdgpu bus-ID: 00:01.0 chip-ID: 1002:9853
bus-ID: 1-1.4:5 chip-ID: 13d3:5a11 class-ID: 0e02
Display: server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
diag: 354mm (13.9")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.16.8-zen1-1-zen LLVM 13.0.0)
v: 4.5 Mesa 21.3.5 direct render: Yes
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
bus-ID: 3-1:2 chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
IF: wlp0s16u1 state: up mac: <filter>
bus-ID: 2-1.1:3 chip-ID: 13d3:3529 class-ID: e001 serial: <filter>
Local Storage: total: 931.51 GiB used: 52.79 GiB (5.7%)
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B sata: 3.3
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1J temp: 32 C
SMART: yes state: enabled health: PASSED on: 122d 11h cycles: 2047
Old-Age: g-sense error rate: 519
used: 52.76 GiB (33.4%) fs: btrfs block-size: 4096 B dev: /dev/sda7
maj-min: 8:7
used: 25.9 MiB (10.1%) fs: vfat block-size: 512 B dev: /dev/sda1
maj-min: 8:1
maj-min: 8:7
maj-min: 8:7
maj-min: 8:7
ID-1: swap-1 type: zram size: 3.26 GiB used: 1.5 GiB (46.0%)
System Temperatures: cpu: 61.5 C mobo: N/A gpu: radeon temp: 61.0 C
Fan Speeds (RPM): cpu: 3900
Processes: 202 Uptime: 1h 41m wakeups: 1 Memory: 3.27 GiB
used: 2.39 GiB (73.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.1 Packages: pacman: 1493 lib: 356
Shell: fish (sudo) v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.12
please i need help i cant reinstall it now :disappointed_relieved:
