No sound/audio from speakers, works on headphones on the same card.
KDE Dragonized edition
Laptop - Alienware 14
System: Kernel: 5.13.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=450d3011-8695-4b2a-a1f7-bc1c9b0386a5
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Portable System: Alienware product: Alienware 14 v: A11 serial: <filter> Chassis: type: 8
Mobo: Alienware model: 07MJ2Y v: A01 serial: <filter> UEFI: Alienware v: A11 date: 06/25/2018
Battery: ID-1: BAT1 charge: 10.9 Wh (100.0%) condition: 10.9/71.0 Wh (15.3%) volts: 12.9 min: 11.1
model: Simplo PABAS0241231 type: Li-ion serial: <filter> status: Full
CPU: Info: Quad Core model: Intel Core i7-4700MQ bits: 64 type: MT MCP arch: Haswell family: 6
model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 31925
Speed: 1995 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 1995 2: 2215 3: 2655 4: 1996
5: 1995 6: 1998 7: 1995 8: 1997
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GK106M [GeForce GTX 765M] vendor: Dell driver: N/A alternate: nouveau
bus-ID: 01:00.0 chip-ID: 10de:11e2 class-ID: 0300
Device-3: Sunplus Innovation Laptop Integrated Webcam FHD type: USB driver: uvcvideo
bus-ID: 1-1.4:3 chip-ID: 1bcf:2b83 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel display-ID: :0
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2) v: 4.5 Mesa 21.1.6 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Device-3: NVIDIA GK106 HDMI Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0e0b class-ID: 0403
Sound Server-1: ALSA v: k5.13.7-zen1-1-zen running: yes
Network: Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet vendor: Dell driver: alx v: kernel
port: 3000 bus-ID: 08:00.0 chip-ID: 1969:e091 class-ID: 0200
Device-2: Qualcomm Atheros AR9462 Wireless Network Adapter
vendor: Rivet Networks Killer Wireless-N 1202 Half-size Mini PCIe Card driver: ath9k v: kernel
port: 3000 bus-ID: 0a:00.0 chip-ID: 168c:0034 class-ID: 0280
IF: wlp10s0 state: up mac: <filter>
Bluetooth: Device-1: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb v: 0.8 bus-ID: 2-1.5:5
chip-ID: 0cf3:3004 class-ID: e001
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5060
bus-ID: 00:1f.2 chip-ID: 8086.282a rev: 05 class-ID: 0104
Drives: Local Storage: total: 1006.04 GiB used: 28.02 GiB (2.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10JPVX-75JC3T0 size: 931.51 GiB
serial: <filter> rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: LITE-ON IT model: DMT-80M6M-11 mSATA 80GB size: 74.53 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 10B
Partition: ID-1: / raw-size: 282.31 GiB size: 282.31 GiB (100.00%) used: 27.99 GiB (9.9%) fs: btrfs
dev: /dev/sda4 maj-min: 8:4
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.5 MiB (26.6%) fs: vfat
dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 282.31 GiB size: 282.31 GiB (100.00%) used: 27.99 GiB (9.9%) fs: btrfs
ID-4: /var/log raw-size: 282.31 GiB size: 282.31 GiB (100.00%) used: 27.99 GiB (9.9%) fs: btrfs
ID-5: /var/tmp raw-size: 282.31 GiB size: 282.31 GiB (100.00%) used: 27.99 GiB (9.9%) fs: btrfs
ID-1: swap-1 type: zram size: 7.65 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 64.0 C mobo: N/A
Info: Processes: 292 Uptime: 28m wakeups: 2 Memory: 7.65 GiB used: 4.16 GiB (54.3%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1785 lib: 545
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
aplay -L
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDA Intel HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA Intel HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 0: ALC3661 Analog [ALC3661 Analog]
Subdevices: 1/1
card 2: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 2: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 2: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 2: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 2: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
What I require is card 1 deveice 0. have changed the same in /etc/asound.conf and /usr/share/alsa/alsa.conf
File: /etc/asound.conf
defaults.pcm.card 1
defaults.pcm.device 0
defaults.ctl.card 1
Have no issues on headphones on the same card or through HDMI.
Please help for the same.
Thanks.
