No sound from Google Chrome in KDE/Garuda
Good day
For some weeks/months I have no sound coming from Chrome. Reboot does not help. I update the OS regularly.
Any effective ideas?
  Kernel: 6.12.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=48ce8f28-090a-41e6-b029-236d9c4692ba rw rootflags=subvol=@
  Type: Laptop System: LENOVO product: 82RN v: IdeaPad 3 15ABA7
    serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 15ABA7
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    part-nu: LENOVO_MT_82RN_BU_idea_FM_IdeaPad 3 15ABA7
    uuid: <superuser required> UEFI: LENOVO v: JTCN42WW date: 01/10/2023
  ID-1: BAT0 charge: 30.3 Wh (78.3%) condition: 38.7/38.0 Wh (101.9%)
    volts: 7.9 min: 7.7 model: LGC L20L2PF0 type: Li-poly serial: <filter>
    status: not charging cycles: 91
  Info: model: AMD Ryzen 5 5625U with Radeon Graphics bits: 64 type: MT MCP
    microcode: 0xA500011
    desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1110 min/max: 400/4388 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1110 2: 1110 3: 1110
    4: 1110 5: 1110 6: 1110 7: 1110 8: 1110 9: 1110 10: 1110 11: 1110 12: 1110
    bogomips: 55093
  Device-1: Advanced Micro Devices [AMD/ATI] Barcelo vendor: Lenovo
    built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0
    chip-ID: 1002:15e7 class-ID: 0300 temp: 39.0 C
  Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 13d3:56ff
    class-ID: 0e02
  Monitor-1: eDP-1 model: AU Optronics 0xe48d built: 2019 res:
    max: 1920x1080 min: 640x480
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.3-arch1.2
    renoir LLVM 19.1.6 DRM 3.59 6.12.6-zen1-1-zen) device-ID: 1002:15e7
  API: Vulkan v: 1.4.303 layers: 4 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:15e7
    19.1.6 256 bits) driver: N/A device-ID: 10005:0000
    Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1
    vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2
    class-ID: 0480
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6
  API: ALSA v: k6.12.6-zen1-1-zen status: kernel-api tools: N/A
    vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c822
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 0bda:c123
  Report: btmgmt ID: hci0 rfk-id: 25 state: down bt-service: enabled,running
  Local Storage: total: 476.94 GiB used: 251.77 GiB (52.8%)
    model: MZAL4512HBLU-00BL2 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 7L1QHXC7 temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 248.92 GiB size: 248.92 GiB (100.00%)
    used: 103.2 GiB (41.5%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
    used: 78.6 MiB (81.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 248.92 GiB size: 248.92 GiB (100.00%)
  ID-4: /var/log raw-size: 248.92 GiB size: 248.92 GiB (100.00%)
  ID-5: /var/tmp raw-size: 248.92 GiB size: 248.92 GiB (100.00%)
  ID-1: swap-1 type: zram size: 13.49 GiB used: 2.64 GiB (19.5%)
  System Temperatures: cpu: 49.4 C mobo: N/A gpu: amdgpu temp: 38.0 C
  Memory: total: 16 GiB note: est. available: 13.49 GiB used: 7.85 GiB (58.2%)
  Processes: 425 Power: uptime: 21d 21h 26m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 22 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 5.39 GiB services: org_kde_powerdevil,
  Packages: 1659 pm: pacman pkgs: 1643 libs: 461
    tools: gnome-software,octopi,paru pm: flatpak pkgs: 16 Compilers:
    gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
    inxi: 3.3.37
Garuda (2.6.26-1.1):
  System install date:     2024-08-31
  Last full system update: 2025-01-19 ↻
:question:
Did you get no answer from google about?
What have your internet searches revealed so far?
Apart from that, repairing a problem that has existed for weeks or months on a foreign system is impossible.
All add-ons removed?
All settings set to default?
Newly installed?
Does it work on chaotic-aur/ungoogled-chromium-bin @Fenris?
Yes, it does :slight_smile:
What did I just get sucked into? :face_with_monocle: oh right…ya, if your going to use chromium for what ever and you need sound for the YouTube videos you watch, ungoogled chromium should work for you. Also since it takes you weeks to compile it, you have the oppertunity to fix the sound problems yourself since you have the chance to review all the source code. :sunglasses:
I won’t link it for you more than once. They have included ungoogled-chromium-bin in chaotic-aur for you.
I know, I just haven’t gotten around to installing it cause the non bin version is so integrated into my system at the moment. The next time I rebuild my system with Garuda on it will have the bin version installed this time around
Good evening
As I said, reboot does not help.
Poor inxi!
Workaround is around, and Altavista said, “ежмиуяшопущазатиа”
