No sound from Genymotion Devices?
I have no sound from the Genymotion Android. Virtualbox says that it uses Pulseaudio, the Device is on 100% Output and the weirdest thing is that there is a sound, but only one time after the startup The sound when i open the menu the "push of a button" sound. But only once.
I dont know what info you need and where to find it, so please say what you need to help me :slight_smile:
Kernel: 5.18.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=38add348-b329-4341-8751-7bbc309d28a1 rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=0 loglevel=3
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop Mobo: Micro-Star model: B450M PRO-VDH MAX (MS-7A38) v: 8.0
serial: <superuser required> UEFI: American Megatrends v: B.40
date: 11/07/2019
Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3973 high: 4375 min/max: 2200/4409 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3901 2: 3568
3: 3528 4: 4365 5: 4234 6: 4375 7: 3758 8: 3525 9: 3488 10: 4250 11: 4367
12: 4319 bogomips: 91199
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA 1
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 2b:00.0
chip-ID: 1002:731f class-ID: 0300
s-diag: 1245mm (49.01")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: right model: Asus VP228
serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9 modes:
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left
model: BenQ GL2706PQ serial: <filter> built: 2016 res: 2560x1440 hz: 60
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
OpenGL: renderer: AMD Radeon RX 5600 XT (navi10 LLVM 14.0.6 DRM 3.46
5.18.8-zen1-1-zen)
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 3-3:4 pcie: chip-ID: 0d8c:013c gen: 4 class-ID: 0300 speed: 16 GT/s
lanes: 16 bus-ID: 2b:00.1 chip-ID: 1002:ab38 class-ID: 0403
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media CM108 Audio Controller type: USB
Sound Server-1: ALSA v: k5.18.8-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.53 running: yes
lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: down mac: <filter>
Device-2: Realtek RTL88x2bu [AC1200 Techkey] type: USB driver: rtl88x2bu
bus-ID: 1-1:2 chip-ID: 0bda:b812 class-ID: 0000 serial: <filter>
IF: wlp3s0f0u1 state: up mac: <filter>
IF-ID-2: enp3s0f0u5 state: unknown speed: -1 duplex: half mac: <filter>
IF-ID-3: vboxnet0 state: down mac: <filter>
IF-ID-4: vboxnet1 state: up speed: 10 Mbps duplex: full mac: <filter>
IF-ID-5: virbr0 state: down mac: <filter>
Device-1: HTC (High Tech ) MT65xx Android Phone type: USB
driver: rndis_host,usbfs bus-ID: 1-5:3 chip-ID: 0bb4:0004 class-ID: 0a00
Report: bt-service: enabled,stopped note: tool can't run
Local Storage: total: 3.18 TiB used: 1.22 TiB (38.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA300
type: HDD rpm: 7200 serial: <filter> rev: ABB0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 750 EVO 500GB
ID-1: / raw-size: 448.27 GiB size: 448.27 GiB (100.00%)
used: 383.13 GiB (85.5%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 25.8 MiB (8.6%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 448.27 GiB size: 448.27 GiB (100.00%)
ID-4: /var/log raw-size: 448.27 GiB size: 448.27 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.27 GiB size: 448.27 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.2 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 55.0 C
mem: 60.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1296
Processes: 365 Uptime: 7m wakeups: 0 Memory: 15.57 GiB
used: 6.52 GiB (41.9%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: apt: 0
pacman: 2528 lib: 544 Shell: fish v: 3.4.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
Garuda (2.6.4-2):
System install date:     2022-01-14
Last full system update: 2022-07-04
Failed units:            bluetooth-autoconnect.service rustdesk.service systemd-oomd.socket
I found the Solution myself. I had to set the Audio device to Alsa. But it only worked after the Second time. The first time i tried it did nothing.
:smiley:
