Hi all,
I have fresh install of Garuda 6.3.8 But not receiving sound through the headphone jack or hdmi of my gtx 1060-6gb. I have looked though the forum and tried a few solutions that looked similar to mine. Most of these where for laptops, where I am a desktop. I am using the analogue stereo option.
Things i have tried:
Updating Garuda
Switching to Pulseaudio and then back to pipewire
systemctl --user enable pipewire.service
systemctl --user enable pipewire-pulse.service
I installed pavucontrol, this showed me I am receiving audio via the moving volume slider, But not hearing anything.
Kernel: 6.3.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=73b2b4dd-2fff-44d3-96d3-d5b0cdf1c03b rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 1
Mobo: ASUSTeK model: TUF GAMING B560M-PLUS v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 2001
date: 02/01/2023
Info: model: 11th Gen Intel Core i5-11400F bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x58
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4400 scaling:
5: 800 6: 800 7: 800 8: 800 9: 801 10: 800 11: 800 12: 800 bogomips: 62208
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ASUSTeK driver: nvidia
v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
Screen-1: 0 s-res: 3840x1080 s-dpi: 91 s-size: 1070x301mm (42.13x11.85")
s-diag: 1112mm (43.76")
Monitor-1: HDMI-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 92
size: 531x298mm (20.91x11.73") diag: 609mm (23.97") modes: N/A
Monitor-2: HDMI-1 pos: right res: 1920x1080 hz: 60 dpi: 51
size: 952x536mm (37.48x21.1") diag: 1093mm (43.01") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 direct-render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
API: ALSA v: k6.3.8-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 03:00.0
Local Storage: total: 540.29 GiB used: 423.27 GiB (78.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST980811AS
size: 74.53 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
tech: N/A serial: <filter> fw-rev: B scheme: GPT
ID-1: / raw-size: 74.23 GiB size: 74.23 GiB (100.00%)
used: 14.11 GiB (19.0%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 580 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 74.23 GiB size: 74.23 GiB (100.00%)
ID-4: /var/log raw-size: 74.23 GiB size: 74.23 GiB (100.00%)
ID-5: /var/tmp raw-size: 74.23 GiB size: 74.23 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.19 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 38.0 C mobo: N/A gpu: nvidia temp: 56 C
Processes: 279 Uptime: 3h 2m wakeups: 3 Memory: available: 31.19 GiB
used: 4.31 GiB (13.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1824
libs: 524 tools: octopi,pamac,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date: 2023-06-18
Last full system update: 2023-06-20 ↻
And
systemctl status --user pipewire
â—Ź pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: enabled)
Active: active (running) since Tue 2023-06-20 11:18:24 BST; 3h 21min ago
TriggeredBy: â—Ź pipewire.socket
Main PID: 1194 (pipewire)
Tasks: 3 (limit: 38169)
Memory: 46.2M
CPU: 21.129s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─1194 /usr/bin/pipewire
Jun 20 11:18:24 Interpol systemd[783]: Started PipeWire Multimedia Service.
â•─chunkee@Interpol in ~ took 4ms
╰─λ systemctl status --user pipewire-pulse
â—Ź pipewire-pulse.service - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; enabled; preset: enabled)
Active: active (running) since Tue 2023-06-20 11:18:47 BST; 3h 21min ago
TriggeredBy: â—Ź pipewire-pulse.socket
Main PID: 1489 (pipewire-pulse)
Tasks: 2 (limit: 38169)
Memory: 70.2M
CPU: 55.055s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
└─1489 /usr/bin/pipewire-pulse
Jun 20 11:18:47 Interpol systemd[783]: Started PipeWire PulseAudio.
A third command from the above ending wireplumber will not finish
Thank you in advance
