For my current client, I'm required to use Citrix to be able to work on their projects. Though theoretically, I have everything I need on my local machine, I have no access to any of the resources (databases, file shares, Outlook ...) I need outside of their Citrix environment, so... no Citrix means no work...
I have 3 machines I work on, 2 Macs and 1 Lenovo laptop. So far, I've done most of my work on my 2 macs. My M1 MacBook Air I use on the days I'm @ the office, my Mac Studio I use when I work @ home.
Being an independent contractor I tend to work on multiple projects @ the same time. I love my Mac Studio,but for personal reasons I still tend to use my Lenovo as my daily professional driver. My development work, my e-mail correspondence, accounting... almost everything I do on my Lenovo.
Originally when I started @ the client, I attempted to install Citrix on my laptop so that I could keep all of my professional data in 1 (mobile) location.
Thanks to Google and the AUR I was able to install & configure my Citrix client rather easily. After it was installed, connecting to the work environment was immediately possible.
For internal communication, my client uses Microsoft Teams. It works perfectly well, except... I have no sound, no webcam...
While everything works on my machine itself, nothing is detected by Citrix.
I have - of course - Googled the issue and found the following resources which I followed to no avail:
- Citrix - ArchWiki
- Troubleshooting ICA Client Audio Issues
- Configure | Citrix Workspace app for Linux
I have been playing around a bit, but being still relatively new to both Linux and Garuda, I don't seem to be getting anywhere. On my 2 macs everything seems OK, no special or additional configuration was required there.
At first, I made due, but since I spend a lot of my time in online meetings, I decided to use my other machines for just to avoid the hassle of having to listen on 1 device and type or share my screen on the other.
As suggested by the information I found, I changed 2 configuration files:
- wfclient.ini
[WFClient]
Version=2
AllowAudioInput=TRUE
KeyboardLayout=(User Profile)
KeyboardType=(Default)
KeyboardMappingFile=automatic.kbd
KeyboardDescription=Automatic (User Profile)
KeyboardEventMode=Unicode
- module.ini
[ClientAudio]
DriverName=VDCAM.DLL
UseThread=TRUE
ThreadQueueSize=65536
AudioLatencyControlEnabled=TRUE
EnableAdaptiveAudio=TRUE
AudioRedirectionV4=TRUE
EnableEchoCancellation=FALSE
Nothing I did however made a difference.
Being new... I might have done something wrong of course. I - for example - installed pulseaudio-alsa, though I don't think I need it in my case.
Anyway... hope you guys can help. ![]()
As suggested, I've hereby included the output of the garuda-inxi command:
[π] Γ garuda-inxi
Kernel: 5.19.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=cd948efc-d2df-47db-9777-932e0b08c447 rw rootflags=subvol=@
resume=UUID=29fdd6b3-9e0f-4e41-b98e-3f61e9a5f503 loglevel=3
Type: Laptop System: LENOVO product: 20BE0089UK v: ThinkPad T540p
Mobo: LENOVO model: 20BE0089UK v: SDK0E50510 Pro
serial: <superuser required> UEFI-[Legacy]: LENOVO v: GMET91WW (2.39 )
date: 06/03/2021
ID-1: BAT0 charge: 36.2 Wh (100.0%) condition: 36.2/56.2 Wh (64.5%)
volts: 12.3 min: 10.8 model: LGC 45N1147 type: Li-ion serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech Craft Advanced Keyboard
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 2S
Info: model: Intel Core i7-4600M bits: 64 type: MT MCP arch: Haswell
gen: core 4 built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3177 high: 3190 min/max: 800/3600 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3156 2: 3190 3: 3190
4: 3175 bogomips: 23145
vulnerable
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: Lite-On Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-12:7 chip-ID: 04ca:7035 class-ID: 0e02
Device-3: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-3.4.2.4:20 chip-ID: 046d:082d
alternate: fbdev,intel,vesa gpu: evdi,i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1520x285mm (59.84x11.22")
s-diag: 1546mm (60.89")
Monitor-1: DVI-I-1 mapped: DVI-I-1-1 pos: center model: LG (GoldStar) IPS
FULLHD built: 2014 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
Monitor-2: DVI-I-2 mapped: DVI-I-2-2 pos: right model: Samsung S27B370
serial: <filter> built: 2012 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
Monitor-3: eDP-1 pos: primary,left model: ChiMei InnoLux 0x15cb
built: 2014 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 4600 (HSW GT2) v: 4.6 Mesa
22.1.7 direct render: Yes
vendor: Lenovo driver: snd_hda_intel bus-ID: 3-3.2:9 v: kernel
bus-ID: 00:03.0 chip-ID: 17e9:6015 class-ID: 0102 chip-ID: 8086:0c0c
class-ID: 0403 serial: <filter>
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Device-3: DisplayLink ThinkPad Hybrid USB-C with USB-A Dock type: USB
driver: snd-usb-audio,usbfs
Device-4: Logitech Blue Microphones type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3.4.2.2:17
chip-ID: 046d:0ab7 class-ID: 0300 serial: <filter>
Device-5: Logitech HD Pro Webcam C920 type: USB
Sound Server-1: ALSA v: k5.19.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Intel Ethernet I217-LM vendor: Lenovo driver: e1000e v: kernel
port: 4080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:08b2 class-ID: 0280
Device-3: Lenovo ThinkPad Lan type: USB driver: cdc_ether
bus-ID: 3-3.3:10 chip-ID: 17ef:a359 class-ID: 0a00 serial: <filter>
IF: enp0s20u3u3c2 state: up speed: 100 Mbps duplex: half mac: <filter>
IF-ID-2: wwp0s20u10 state: down mac: <filter>
bus-ID: 3-11:6 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 3.64 TiB used: 305.16 GiB (8.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital model: WD
My Passport 2628 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1034 scheme: GPT
ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 305.16 GiB (16.5%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 305.16 GiB
(16.5%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 305.16 GiB
ID-4: /var/tmp raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 305.16 GiB
ID-1: swap-1 type: zram size: 15.32 GiB used: 640.5 MiB (4.1%)
ID-2: swap-2 type: partition size: 16.85 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 70.0 C mobo: N/A
Fan Speeds (RPM): cpu: 65535 fan-1: 2514 fan-2:
Processes: 385 Uptime: 59m wakeups: 8 Memory: 15.32 GiB used: 10.79 GiB
(70.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 2632 note: see --pkg
pacman: 2615 lib: 622 flatpak: 17 Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.20
Garuda (2.6.7-1):
System install date: 2022-07-23
Last full system update: 2022-09-15 β»
