Kernel: 6.2.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=97474ec2-db6d-49a6-93bb-3e341e2d6a3c rw rootflags=subvol=@
resume=UUID=516fe7e2-191e-4f99-9fa8-48ba7e8cd034 loglevel=3 ibt=off
Type: Laptop System: Dell product: Latitude 3420 v: N/A
Mobo: Dell model: 0FDC0T v: A00 serial: <superuser required> UEFI: Dell
v: 1.23.2 date: 10/27/2022
ID-1: BAT0 charge: 31.6 Wh (79.6%) condition: 39.7/40.8 Wh (97.1%)
volts: 11.7 min: 11.2 model: BYD DELL PG8YJ19 type: Unknown serial: <filter>
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
microcode: 0xA6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 622 high: 1247 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 1173 2: 401 3: 400
4: 1247 5: 400 6: 400 7: 393 8: 568 bogomips: 27033
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:3 chip-ID: 0c45:6730 class-ID: 0e02
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x0a21 built: 2021 res: 1366x768
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.2.11-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.69 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 2c:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp44s0 state: down mac: <filter>
IF-ID-1: br-000d18c40562 state: down mac: <filter>
IF-ID-2: br-1a0ae861d604 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: br-1b44eeac3ec8 state: down mac: <filter>
IF-ID-4: br-2712ad3d0c08 state: down mac: <filter>
IF-ID-5: br-6598402457d8 state: down mac: <filter>
IF-ID-6: br-ab40c4d8c34e state: down mac: <filter>
IF-ID-7: br-b3d9414938fa state: down mac: <filter>
IF-ID-8: br-b5fa80765491 state: down mac: <filter>
IF-ID-9: br-b6cb02f52dda state: down mac: <filter>
IF-ID-10: br-df9d391c0f8d state: down mac: <filter>
IF-ID-11: docker0 state: down mac: <filter>
IF-ID-12: veth3982ff5 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-13: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-14: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 465.76 GiB used: 333.37 GiB (71.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P2SSD8
lanes: 4 type: SSD serial: <filter> rev: P2CR033 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 399.73 GiB size: 399.73 GiB (100.00%)
used: 307.11 GiB (76.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 399.73 GiB size: 399.73 GiB (100.00%)
ID-4: /var/log raw-size: 399.73 GiB size: 399.73 GiB (100.00%)
ID-5: /var/tmp raw-size: 399.73 GiB size: 399.73 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.91 GiB used: 71.6 MiB (0.4%)
ID-2: swap-2 type: zram size: 15.37 GiB used: 4.78 GiB (31.1%)
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 390 Uptime: 1d 12h 42m wakeups: 30309 Memory: 15.37 GiB
used: 7.29 GiB (47.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1544
libs: 354 tools: octopi,paru Shell: fish v: 3.6.1 running-in: konsole
inxi: 3.3.26
System install date: 2022-12-09
Last full system update: 2023-04-18 ↻
After some update last week, some apps like slack-desktop and whatsapp-nativier does not have audio/sound anymore.
