Hello everyone,
I have a problem with my computer sound, everytime I activate sleep mode and waking up my computer there is no sound, I need to reboot my PC and my sound work again.
I have this issue with all the OS I've tried: Pop!OS, Kubuntu and Garuda.
I tried restarting with :
systemctl --user restart pipewire pipewire-pulse
systemctl --user daemon-reload
It still hasn't solved the problem.
On Kubuntu i tried to Uninstall/Reinstall Pulse audio but my sound never came back after, that's why i decide to try Garuda OS.
I am very new on the Linux system and English is not my mother tongue, sorry for this.
I hope someone has a solution .
Thanks you for reading my topic,
Haeyx
Kernel: 6.0.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=a7df1097-254b-4c57-8e12-76f7e5982afa rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.7 info: latte-dock
Type: Laptop System: LENOVO product: 82K6 v: Legion 7 16ITHg6
serial: <superuser required> Chassis: type: 10 v: Legion 7 16ITHg6
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: H1CN44WW date: 11/17/2021
ID-1: BAT0 charge: 77.3 Wh (98.0%) condition: 78.9/80.0 Wh (98.6%)
volts: 17.1 min: 15.4 model: Celxpert L20C4PC1 type: Li-poly
serial: <filter> status: not charging cycles: 39
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
microcode: 0x40
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2117 high: 2890 min/max: 800/4600 scaling:
driver: intel_pstate governor: performance cores: 1: 2300 2: 2890 3: 2300
4: 801 5: 1314 6: 2300 7: 2300 8: 2300 9: 1268 10: 2300 11: 2300 12: 2300
13: 2300 14: 2300 15: 2300 16: 2300 bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nouveau v: kernel non-free: 515.xx+ status: current (as of 2022-10)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-6, DP-7,
HDMI-A-2, eDP-2 bus-ID: 01:00.0 chip-ID: 10de:2560 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
s-diag: 798mm (31.43")
Monitor-1: eDP-1 model-id: CSO 0x1606 built: 2020 res: 2560x1600 dpi: 188
gamma: 1.2 size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10
modes: 2560x1600
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.2.1
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo driver: snd_hda_intel
chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
Sound API: ALSA v: k6.0.6-zen1-1-zen running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 5c:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp92s0 state: down mac: <filter>
bus-ID: 3-14:4 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 4 state: down
address: <filter>
Local Storage: total: 953.87 GiB used: 19.12 GiB (2.0%)
model: MZVL21T0HCLR-00BL2 size: 953.87 GiB block-size: physical: 512 B
rev: AL1QGXA7 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 19.1 GiB
(2.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 16.6 MiB
(5.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 19.1
GiB (2.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 19.1
ID-5: /var/tmp raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 19.1
ID-1: swap-1 type: zram size: 31.14 GiB used: 244 KiB (0.0%)
System Temperatures: cpu: 47.0 C mobo: N/A
Processes: 353 Uptime: 32m wakeups: 3 Memory: 31.14 GiB used: 4.48 GiB
(14.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1901 libs: 537
Garuda (2.6.9-1):
System install date: 2022-10-27
Last full system update: 2022-10-31
Failed units: irqbalance.service
