No sound after power cut
Hello Garuda users.
Please post the terminal/konsole input and output as text (no pictures) from the following command:
  Kernel: 6.1.35-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=35a59b1d-d50f-4b12-b731-7e082a2e9e5e rw rootflags=subvol=@
    loglevel=3 ibt=off
  Type: Mini-pc System: ASUSTeK product: MINIPC PN52 v: N/A
  Mobo: ASUSTeK model: PN52 v: Rev 1.xx serial: <superuser required>
    UEFI: American Megatrends v: 11300 date: 06/15/2022
    microcode: 0xA50000C
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1200 high: 1209 min/max: 1200/4462 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1197 2: 1200
    3: 1200 4: 1200 5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 1200 11: 1200
    12: 1200 13: 1200 14: 1200 15: 1209 16: 1200 bogomips: 102241
    built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s ports: active: DP-2 empty: DP-1,HDMI-A-1,HDMI-A-2
    bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 39.0 C
  Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 046d:0825
  Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
    s-diag: 599mm (23.57")
  Monitor-1: DP-2 mapped: DisplayPort-1 model: Dell U2412M serial: <filter>
    built: 2012 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
    size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
    max: 1920x1200 min: 720x400
    missing.
    speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
    snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
    gen: 4 speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
    link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
  Device-4: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.1.35-1-lts status: kernel-api tools: N/A
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0
    lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:0616 class-ID: 0280
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3:3 chip-ID: 0489:e0e2
  Local Storage: total: 1.36 TiB used: 573.97 GiB (41.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S500G
    lanes: 4 tech: SSD serial: <filter> fw-rev: SBJ00101 temp: 33.9 C
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: SSD size: 931.51 GiB
    serial: <filter> fw-rev: 1010 scheme: MBR
    used: 40.39 GiB (8.7%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2
    used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  ID-3: /home raw-size: 857.51 GiB size: 842.98 GiB (98.31%)
    used: 533.58 GiB (63.3%) fs: ext4 block-size: 4096 B dev: /dev/sda3
    maj-min: 8:3
    maj-min: 259:2
    maj-min: 259:2
  ID-1: swap-1 type: partition size: 24 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda2 maj-min: 8:2
  ID-2: swap-2 type: zram size: 62.21 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 44.4 C mobo: N/A gpu: amdgpu temp: 40.0 C
  Processes: 398 Uptime: 23h 14m wakeups: 21 Memory: available: 62.21 GiB
  used: 9.19 GiB (14.8%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1514
  libs: 420 tools: gnome-software,octopi,paru Shell: Bash v: 5.1.16
  running-in: xfce4-terminal inxi: 3.3.27
  System install date:     2023-01-26
  Last full system update: 2023-06-28
Tow days ago I had a sudden power cut and when I restarted the computer there was no sound at all. I have had some issues for a while with getting the microphone to work and got it somehow to work a few days ago and was very happy for that. No nothing works at all on the sound level. I have checked the teh info in the sounds mixer and "Family 17h.... " does not show up anymore like it did before the power cut. I hav ebeen trying to read someinfo about this on Internet but I don't understand half of it, I'm not very technical, hence asking here. i have tried to restart the computer a couply of times but that did not help. Any advice please?
Install alsa-utils, if you don't already have it.
sudo pacman -S alsa-utils
Then run alsamixer from the terminal. See if you have any luck bringing up the master volume from there, or if not try toggling to a different sound card (F6).
Most likely not related to your issue, but, with a rolling release distro, you should get into the habit of updating more often. To do that, from a terminal, just enter
garuda-update
Well, this actually helped. and even the microphone works (still) so thank you very much and I will update more regulary (which I thought the system did it self). All good!
